Jeep Grand Cherokee Steering excessively loose - Page 2 - JeepForum.com
 1Likes
post #16 of 37 Old 05-31-2009, 04:50 AM
norm67
hi all, i have same problem, i have a year 2000 Grand Cherokee, steering has about 3 inch play before wheels move, was advised to adjust allen screw on top of steering box, does anyone know if this works and what size allen key is required? thanks
norm67 is offline
post #17 of 37 Old 05-31-2009, 06:52 AM
craddock01
This is probably not your problem but I had goofy steering couple of weeks ago found one rear tire was way low on air steering improved a lot steering kind of felt like a truck when you get it overloaded front end going side to side.
craddock01 is offline
post #18 of 37 Old 05-31-2009, 06:55 AM
newfieZJ
Yes it can help . Yes it can also wear out the box in short order . If it's not the problem , you'll soon find out when the steering binds up . If you want to know the condition of the str box , crawl under the jeep , look directly up at the shaft and have someone turn the steering wheel 1/2 turns . There should be a minimal amount of play , most cases have a leaking seal which is a good indicater of it's condition . If the seal leaks , there is usually excess play .
http://dodgeram.info/tsb/1997/19-10-97.htm
Before doing this , make sure the frt end has been thoroughly inspected . I agree with Jeff , pop them off and see how loose they are . I find the best quick inspection though is with channel locks squeezing the joint and having someone back and forth on the wheel , by compressing the joint , you load it . Alot of the times you can feel a clunking with a worn steering TRE , so have your hand on the bars or cloe to the suspect joints while inspecting , it might help .
Track bars , They can sure cause wandering . Back and forth on the steering wheel at 1/2 turns . 'Any' play in this area means replacement .
Any replacing parts warrants a fresh whl alignment , which , if off , can also cause wandering .
1995 Orvis build
1988 MJ build
1998 Slate 5.9 build
1998 Platinum 5.9 build
newfieZJ is offline
post #19 of 37 Old 05-31-2009, 08:42 AM
norm67
ive looked underneath and the steering box appears to have small leakage, what does this mean?
norm67 is offline
post #20 of 37 Old 05-31-2009, 11:58 AM
iluvtruenos
It means that your steering box is leaking.
iluvtruenos is offline
post #21 of 37 Old 05-31-2009, 12:30 PM
norm67
yes thanks i gathered that, does that mean a new steering box or something else?
norm67 is offline
post #22 of 37 Old 05-31-2009, 12:53 PM
craddock01
Are you losing pwer steering fluid like needing to top off frequently? Made sure leak is from steering box not just fluid that may have dripped onto box from pump? Cleaned it off with brake fluid to be certain ? Assumptions can be expensive if it turns out to be not the source of your problems.
post #23 of 37 Old 05-31-2009, 02:05 PM
norm67
it doesnt look like im losing fluid, since ive had the excess play in the steering i looked underneath and noticed some leakage, could these two problems be related? Is there some kind of seal that needs replacing?
norm67 is offline
post #24 of 37 Old 06-01-2009, 03:29 AM
norm67
does adjusting allen screw on top of steering box help with excessive play on steering? Any help would be appreciated
norm67 is offline
post #25 of 37 Old 06-03-2009, 04:51 AM
norm67
any help anyone?
norm67 is offline
post #26 of 37 Old 06-03-2009, 01:02 PM
Virmagicus
Virmagicus's Avatar
Yes, this is what the tightening does. Did you read this post ? http://www.jeepforum.com/forum/showp...4&postcount=18
Jeff
Virmagicus is offline
post #27 of 37 Old 10-08-2009, 02:56 AM
bassicaLee
ive got the same problem on my zj.
its stock. and the jeep rides fine. no bumpsteer. just lag and what feels like sloppy steering. the steering wheel turns 3-4" before the wheels turn.
however that link says "wandering" and i dont nessisarily have that soo much.
another idea i had is it might be air in the steering system.
but i dont think my wheel returns to center very quickly if you turn and let go.
how would you fix that?
bassicaLee is offline
post #28 of 37 Old 10-09-2009, 09:32 PM
bassicaLee
ok lol. maybe the problem is that i just noticed 2 lug nuts are broke off on the driver side rear wheel and 1 on each side in the front.
so i will fix that tommorow and see if that fixes it lol.
lucky i've been putting off driving the jeep till everything works on it. lol.
check your stuff to see if lugs are missing or broke off or if your wheels are loose or stripped threads.
post #29 of 37 Old 10-09-2009, 11:13 PM
Virmagicus
Virmagicus's Avatar
Good idea to fix those lug nuts/studs but i am afraid that that is not your problem.
Jeff
post #30 of 37 Old 12-03-2012, 08:03 PM
Fabbri
steering too loose
JGC steering sucks!
Fabbri is offline
01 Jeep Grand Cherokee Power steering & oil pressure problem jasoncrowley ZJ Grand Cherokee Forum 7 08-14-2011 06:34 PM
1993 jeep grand cherokee steering column swap jeep95xj87mj ZJ Grand Cherokee Forum 4 11-24-2008 08:25 AM
2001 Jeep Grand Cherokee Ltd power steering pump jmsanders ZJ Grand Cherokee Forum 0 11-27-2006 08:33 AM
03 Jeep grand Cherokee steering getwyred ZJ Grand Cherokee Forum 1 10-31-2006 08:12 PM
Steering Problem, 2005 Jeep Grand Cherokee BinaryTracks ZJ Grand Cherokee Forum 7 07-30-2006 10:55 PM
