Jeep Grand Cherokee '00 ABS/Brake Lights came on, then off? - JeepForum.com
post #1 of 4 Old 03-16-2007, 01:36 PM Thread Starter
prcoamo
HI,
Was driving along and my brake and ABS light came on. I pulled over to the side shut off the car and the started it again, this time the brake and ABS lights did not come on. I've since started the car a couple of times now for past hour and no brake or ABS lights came on.
Do you think I have something to worry about? What could be the cause?
I'm afraid to even move the car especially in this snow/sleet/icy weather we are having here
Many thanks
prcoamo is offline
post #2 of 4 Old 03-16-2007, 01:57 PM
DaJeep2B
When the light came on, were you applying the brakes hard enough for the ABS system to kick in? You may want to test your ABS system to see if it is working properly on snow or gravel and if the light comes on while the ABS is engaged.
DaJeep2B is offline
post #3 of 4 Old 03-16-2007, 02:15 PM Thread Starter
prcoamo
I don't believe so, i was driving slow since weather conditions are bad out here
so any force i applied was light/normal
prcoamo is offline
post #4 of 4 Old 03-16-2007, 05:07 PM
Cebby
Check your brake fluid level. Low fluid will make the lights come on.
2000 WJ Laredo 4.0 4x4 Taupe Frost - Stroker | Clayton LA w/3" Lift | 33's on JK 17's | Axles next
Cebby is offline
1996 jeep grand cherokee e brake problems potsiewebber ZJ Grand Cherokee Forum 6 02-04-2012 10:32 AM
93 grand cherokee brake lights rich123 ZJ Grand Cherokee Forum 0 02-02-2007 11:28 AM
2002 Jeep Grand Cherokee Larado OEM Fog Lights Jeep706 ZJ Grand Cherokee Forum 1 07-18-2006 01:07 PM
Jeep Grand Cherokee Brake pads mristea ZJ Grand Cherokee Forum 4 04-09-2006 01:53 PM
jeep grand cherokee brake change paraquat ZJ Grand Cherokee Forum 1 07-31-2004 05:38 PM
