Is this Jeep a good deal? - JeepForum.com
post #1 of 9 Old 08-31-2010, 12:40 AM Thread Starter
ShellyMisfit
So I want to buy this Jeep...
Specs:
1996 Jeep Grand Cherokee Laredo 4X4
Color: Olive green
Interior: Grey Cloth
Miles: 197,XXX
Problem(s)
1) The A/C needs recharge, but Walmart sells that for like $25 so that's no big deal. And fall is right around the corner.
2) The Emergency Brake doesn't work... regular brakes are fine.
THE SCOOP: My first car. I only have $1000. He wants $1800 obo
I'm using this jeep for a Daily Driver and an occasional off-road truck.
My Questions: how do i fix the e-brake and how does that break? what should i offer him? When i go see it, what should i look for? Thanks
ShellyMisfit is offline
post #2 of 9 Old 08-31-2010, 12:41 AM
rickyantanies
what kind of engine?
2000 XJ sport 4.5 inch Rough Country Series X lift Cooper Discover M+S 31X10.5 15x8 uniques Dana 30 front Chrysler 8.25 rear Stock gears
Colorado jeep club member #1992
http://www.jeepforum.com/forum/f22/patriot-blue-build-1179435/#post11126000
rickyantanies is offline
post #3 of 9 Old 08-31-2010, 09:11 AM
LordHobbit
The park brake has numerous ways of braking. It could be a cable, or might be under the drum ...
What you should look for:
- start the vehicle, and listen carefully to the engine. If there are any questionable sounds, ask about them.
- Ask for maintenance/service records.
- Slide underneath while the engine is running and look for leaks.
- Look at the exhaust, not the system but the actual gases, is it colored blue or white? That indicates problems.
- Get in shift through all the gears and make sure the tranny feels tight. Shift through all transfer case options, make sure to do this correctly, and make sure it works all right.
- play with all the interior options. See which work and which don't.
- check all the lights even interior and the dash.
- above all, take a notebook, and take notes. Write down anything you think significant. These will all help you decide what to offer. Check out New Car Prices, Used Car Values, New Car Reviews & Car Buying Guides - NADAguides.com Official Site for a decent idea of what might be offered for it. Use it as a baseline, not a definitive.
93 red ZJ 190k 4.0. Spent more money than I should have ...
Isn't red the only color a vehicle should be?
If at first you don't succeed, use more speed.
LordHobbit is offline
post #4 of 9 Old 08-31-2010, 11:18 AM Thread Starter
ShellyMisfit
its a straight 6
post #5 of 9 Old 08-31-2010, 11:21 AM Thread Starter
ShellyMisfit
and thank you lord hobbit for the tips i have more pics im uploading right now so if you wana look at them and tell me what you think?
post #6 of 9 Old 08-31-2010, 11:50 AM Thread Starter
ShellyMisfit
4.0l
post #7 of 9 Old 08-31-2010, 12:09 PM
OneW1ckedXJ
If he takes $1k for it and it runs and drives with no problems id say go for it, ebrake isnt that big of a deal and you might be able to fix it yourself, but if you cant it wont brake the bank having a mechanic do it
Good luck!!
-Shawn-
2000 Cherokee Limited - RC 2" BB, 31x10.5 General Grabber SRL's, CB, Homemade Quick Disco's, Trimmed and bedlined!
OneW1ckedXJ is offline
post #8 of 9 Old 08-31-2010, 02:17 PM
Craft95ZJ
1986 MJ Comanche
I would say $1,250 max on the price E brake usually goes out due to inactive use on automatics. My 95 is a 1 time use when I pull it I have to break the rear brakes loose. Make sure the clutch engages on the A/C compressor or make sue all you have to do is charge the A/C. Good luck!
Daily driver '01 TJ 3" RC lift
'86 MJ 3.4L interior rebuild in progress.
Craft95ZJ is offline
post #9 of 9 Old 08-31-2010, 05:18 PM
LordHobbit
upload away. I like to look at jeep pictures.
1996 , brakes , fix , problem , zj
Is this a good deal? RedEye ZJ Grand Cherokee Forum 16 02-05-2008 02:27 PM
Buying my first Jeep tomorrow.. is this a good deal? udsweetpea WK Grand Cherokee & XK Commander Forum 5 09-01-2007 09:58 PM
GOOD DEAL or BAD DEAL????? rlj WK Grand Cherokee & XK Commander Forum 7 09-28-2006 08:29 PM
Is this a good deal? OrvisOwner ZJ Grand Cherokee Forum 1 09-03-2003 11:52 AM
good deal Big Dumb White Guy ZJ Grand Cherokee Forum 0 01-04-2002 04:51 PM
