Jeep GC Noob - Unidentified Noise - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Jeep GC Noob - Unidentified Noise
Amsteel Blue Synthetic Winch line Free ShippingRing & Pinion's, Lockers, 4340 Axles, Install Kits, BaRaceline/Allied Wheels on Sale NOW !
Unread 01-24-2007, 07:47 AM   #1
KAB 04 WJ
Ok guys, I have been trying to track down a rather annoying engine noise.
Background - 2004 Grand Cherokee Laredo 4.0 I6, 45k
- I have been hearing a motor related noise coming from what I estimate is the front accessory drive. It only occurs at 2,000-2,300 rpms when the vehicle is in drive and under load.
- I can not replicate the sound when the truck is parked and I raise the rpms to to 2,000-2,300 rpm.
- To me it sounds like those older cars that have a screeching belt when it is really cold or wet outside. I can hear the noise everytime on the highway when I accelerate up through that rpm range.
- There is no noise when I let off the gas, so I assume that it is not drivetrain related. I am guessing it could be power steering or a water pump?
- There are no leaking fluids anywhere under the vehicle.
- The other odd thing in my mind is that I started hearing this noise after taking off my throttle body and cleaning it with throttle body cleaner.
Thoughts?
KAB 04 WJ is offline   Reply With Quote
Unread 01-24-2007, 08:04 AM   #2
gunthagunth
My throttle body is pretty noisy right around where it shifts gears. If I'm on the highway and shooting along and the transmission is about to shift I get a nice whistle and if I'm going uphill and the transmission is struggling to shift it will whistle for a long time. Not sure what it is. I didnt know if it was my K&N or throttle body but I replaced the K&N with a tee shirt and the sound was still there.
97 ZJ 5.9L 242/4.5" RE Coils/1.75" Spacers/Clayton arms/Addco's/RE brake lines/35x12.5 bfg muds/Currie steering/K&N/Claytons Front Drop tracbar/Dropped pitman/Bilstein 5125's/JKS BPE/JKS loop conversion/JKS Sliders/ZJilla rear bumper/Clayton front winch bumper/durango steering box/warn 9000i/Hambek Customs carbon fiber cowl hood #2of16/Hp30-8.8 4.56/ARB f+r
gunthagunth is offline   Reply With Quote
Unread 01-24-2007, 01:54 PM   #3
KAB 04 WJ
I was reading the FSM and it says to use a new gasket when removing / installing the throttle body. I am going to pick one up on the way home and see if that gets rid of the noise.
Unread 01-25-2007, 08:31 AM   #4
KAB 04 WJ
Luckily a $3.00 throttle body gasket did the trick. The noise is gone! When all else fails, read the service manual.............before taking anything apart!
