Quantcast Jeep Error Code P1492 - Ambient/Battery Temp Sensor - JeepForum.com
Jeep Home Jeep Forum Jeep Classifieds Jeep Registry JeepSpace Jeep Reviews Jeep Gallery Jeep Blogs Jeep Clubs Jeep Groups Jeep Videos Jeep Events Jeep Articles
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Jeep Error Code P1492 - Ambient/Battery Temp Sensor
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineONBOARD-AIR.COM: Economy OBA System**Best prices on Yukon Axle & Gears**
JeepForum Membership Drive - Reduced Premium Membership For a Short Time Only
Old 12-29-2007, 08:19 PM   #1
headpro2
Hi Guys...I have a 2001 Jeep Grand Cherokeew/ 4.7 liter engine that runs very well. Have owned since new and never had any major issues with it (knock on wood). It currently has 140,000 miles, most of which are true hwy miles, and runs very strong. Doesn't use a drop of oil between changes either.
Problem is I get a P1492 error code and do not know what that means or involves. Like I said, the Jeep runs great...but I do need to get it inspected and can't until I get the light to go off. I did search and find another post about this very code, but no fix was provided.
Can anyone tell me what to look for and how to proceed? Thanks in advance!
Tom
headpro2 is offline   Reply With Quote
Old 12-29-2007, 08:51 PM   #2
magneticred
2008 WK
Check this link:
http://en.allexperts.com/q/Jeep-785/Ambient-temperature-sensor-engine.htm
magneticred is offline   Reply With Quote
Old 12-29-2007, 09:48 PM   #3
headpro2
Thanks magneticred! I checked the battery trey and found that my sensor was missing! The connector for the sensor was there...but no sensor! I guess that's what I get for letting the Advance Auto dude change my battery for me...not that I would have noticed...
I will purchase new sensor and post results.
Thanks again!
Old 12-29-2007, 10:06 PM   #4
headpro2
I'm curious...is there any way to bypass the bettery temperature sensor and fool the computer into thinking it's installed?
Old 12-29-2007, 10:39 PM   #5
blovingier
Sure there's a way to bypass the Battery Temperature Sensor just like everything else if you want to put the effort in. My question is why would you want to? That sensor is there to tell the PCM when to shut off current from the Electronic Voltage Regulator so your battery doesn't overheat.
[B][FONT="Arial"][SIZE="4"][COLOR="Blue"]"GRITZ"[/COLOR][/SIZE][/FONT][/B]
[B]99 Jeep Grand Cherokee Laredo[/B] - [COLOR="Red"][SIZE="4"]Totalled[/SIZE][/COLOR]
-3" lift w/Bilsteins - - - - - - - - - - - - - - - - - -30.5" Pirelli Scorpion ATRs
-[URL="http://www.jeepforum.com/forum/showthread.php?t=494045"]Clear Lenses[/URL] - - - - - - - - - - - - - - - - - - -[URL="http://www.jeepforum.com/forum/showthread.php?p=5229329#post5229329"]Cobra 75 CB w/Wilson 4' Antenna[/URL]
-[URL="http://www.jeepforum.com/forum/showthread.php?p=7008250#post7008250"]Home-Brew Discos[/URL]- - - - - - - - - - - - - - - - - -[URL="http://www.jeepforum.com/forum/showthread.php?t=734768&highlight=diamond+plate+hitch+cover"]Diamond Plate Hitch Cover[/URL]
[B]07 Compass (wife's ride)[/B]
-Stock
blovingier is offline   Reply With Quote
Old 12-29-2007, 10:45 PM   #6
greasefingers
1994 ZJ
Over charging on Jeeps is very rare and I doubt if the temp sensor can actually sense this. I have never ever seen a temp sensor on any vehicle except some jeeps. My ZJ did not come with one.
You would need a resistor of the correct ohms to fake it out.
Cheers Steve
Trained Professional Crack-pot
Go RU & WVU Football Teams
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
03 4Runner V8 (my wife's car)
94 Volvo 850 (my 16-yr old daughter's car) Five cylinder
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline   Reply With Quote
Old 12-29-2007, 11:01 PM   #7
headpro2
Just in case anyone ever has this problem...I found the following information...
the battery temp sensor part # is: 56027332 and should be around $30-$40
as far as i know that's a dealer only item.
here is a Description and Operation that i pulled from my alldata, and the last part of it also describes it's influence on your 1495 code.
The Battery Temperature Sensor (BTS) is attached to the battery tray located under the battery.
The BTS is used to determine the battery temperature and control battery charging rate. This temperature data, along with data from monitored line voltage, is used by the PCM to vary the battery charging rate. System voltage will be higher at colder temperatures and is gradually reduced at warmer temperatures.
The PCM sends 5 volts to the sensor and is grounded through the sensor return line. As temperature increases, resistance in the sensor decreases and the detection voltage at the PCM increases.
The BTS is also used for OBD II diagnostics. Certain faults and OBD II monitors are either enabled or disabled, depending upon BTS input (for example, disable purge and enable Leak Detection Pump (LDP) and O2 sensor heater tests). Most OBD II monitors are disabled below 20 °F
Thanks to this information, I now understand the purpose of the sensor...just as Blovingier has stated...it prevents overcharge and overheat...but more importantly, the BTS is also used for other diagnostics...so best not to tamper with.
Hope this helps the next guy/gal who runs into this problem.
Thanks again guys...TT
Old 12-29-2007, 11:02 PM   #8
muddyjgc
The temp sensor is there to help tell the PCM how much to charge the batt. If a batt is cold it's going to need more juice from the alt. to maintain a charge than if it is warm, and to prevent overheating a batt when it is hot.
On Edit: Dang it looks like headpro2 was typing at the same time and beat me to it!
muddyjgc is offline   Reply With Quote
Old 12-29-2007, 11:06 PM   #9
headpro2
It's just nice to be on the same page as you guys!!!
TT
Old 12-29-2007, 11:07 PM   #10
greasefingers
1994 ZJ
Yea I would have to agree with you after thinking about it once more. The reason is: if the PCM uses it as part of a calculation; then it is necessary for it to be there. I am just glad that mine does not have it. One more thing to possibly go awry.
Cheers Steve
Glock Forum
