jeep doesn't see the ice - JeepForum.com
post #1 of 14 Old 08-23-2013, 02:39 AM Thread Starter
Schem
1994 ZJ
I know it's weird in summer, but my question is about ice info.
Normally, if the temperature is below or ca. 32F, there should be the "ice" information displayed on the overhead console display.
In my case, there's not. I haven't seen it even once during my 3 years spent with jeep.
When I do display self-check, it highlights all, including "ice". So, it's not the display fault.
The temperature sensor seems to be OK, too. The temperature shown is more or less correct everyday.
What's wrong then?
Ahah, there is an ice on the road in winter, here
Schem is offline
post #2 of 14 Old 08-23-2013, 08:50 AM
sebian
I have owned a 93 Laredo, and currently a 95 Limited. I have never seen mine display 'ICE' in the winter. Mind you, this was in MN where every year we had -30F temps for nearly a month straight. Maybe this is a feature on the Euro version of the ZJ?
1995 ZJ 5.2L V8 318. 230,000 miles and still rollin.
List of parts not replaced yet:
sebian is offline
post #3 of 14 Old 08-23-2013, 10:33 AM
ejschultz
ejschultz's Avatar
Mine flashes "ICE" for about 10 to 15 minutes after I start it when the temperature is at like 35 or less, I believe. I know the temp at which it should be displayed is not the melting point of water. I think it's actually a little higher to account for possible ice conditions when things start to melt. If it doesn't display it, I wouldn't worry about it. IIRC, there was a thread about this a couple years ago on here and some people never saw the "ICE" message while others did.
01 TJ - 4.0L, NV3550, 2" Skyjacker budget boost, Trail Gear front bumper, 31" Duratracs on 15x8s
ejschultz is offline
post #4 of 14 Old 08-23-2013, 12:24 PM
KJK
Mine also flashes "ice" at around 35 degrees or less after starting.
5.9 ZJ SCT tuned PCM/ KJK CAI/ Thorley headers with 3" Magnaflow cat and muffler/ Modded kegger/ TransGo shift kit/ Vanco brake kit/ Braided steel brake lines/ Mopar cupholder insert!
KJK is offline
post #5 of 14 Old 08-23-2013, 12:39 PM
ROFLwaffles
Mine will sometimes flash 'ICE' when it is 40 and raining. lol.
ROFLwaffles is offline
post #6 of 14 Old 08-23-2013, 12:42 PM
JeepNicholson
Yes, I believe the ice warning only shows up temporarily when the temp is just above freezing as a reminder to watch out for black ice and icy bridges. It was never meant to sense actual ice, and it doesn't show up below freezing because ice being possible below the freezing point is obvious to most folks.
JeepNicholson is offline
post #7 of 14 Old 08-23-2013, 04:10 PM
airwolf9090
I know i seen it on mine every winter and i live in Savannah! lol
1996 Jeep ZJ Orvis
airwolf9090 is offline
post #8 of 14 Old 08-26-2013, 02:03 AM Thread Starter
Schem
1994 ZJ
OK, thank you guys. Good to know it's not only me
I was thinking something is broken, and can be fixed. If I would know what's wrong.
Maybe it's software, then...
Doesn't matter - I know when it's slippery, don't need such an info
Schem is offline
post #9 of 14 Old 08-26-2013, 02:34 AM
zachjf
its not just you or Jeep, its pretty much every companies mirror and/or sensor. I've driven factory equipped temp display mirror Jeeps as well as Gentex swapped mirrors/sensors from GM models into a few Jeeps now and the "ICE" display is hit or miss at best, case in point, the current compass/temp mirror and sensor I have in my 5.9 is out of a newer model Tahoe and I can be sliding sideways drifting on a sheet of black ice at 37 degrees with no "ICE" warning from the mirror yet the exact same swap I added to my TJ showed the "ICE" warning at exactly 36 degrees like clockwork. The setup I added to my TJ was literally dead on with the outside temperature yet the exact same setup in my 5.9 is off by exactly 3 degrees all the way from 28 to 90+ degrees regardless of the sensor I use or where I locate it. I pretty much just use the reading as a baseline and adjust my driving style based on how wide the slide is and call it good!
Needs parts?
PM
or
zachjf is offline
post #10 of 14 Old 08-26-2013, 03:03 AM
Timo_90xj
Timo_90xj's Avatar
I didn't even know there was supposed to be such a thing on the screen My outside temp readings are correct to within two degrees which IMO is a good result in vehicles. However, I've never seen the ice warning on my niner and we get that kind of weather (temps hovering around freezing point) couple months a year in autumn/ early winter, and early spring.
***Under construction***
Timo_90xj is offline
post #11 of 14 Old 08-26-2013, 03:31 AM
Uniblurb
Uniblurb's Avatar
I've seen the "ICE" warning fairly frequently on my 96 4.0 during the winter months. Don't know why it isn't given when heading up my steep/curvy long drive in the woods when conditions are just right and it turns into a glacier. Lol.
96 4.0 ZJ Laredo, 2004 4.7L WJ Limited, 93 4.0 XJ (spare), 96 4.0 XJ (son's)
Uniblurb is offline
post #12 of 14 Old 08-26-2013, 05:34 AM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
Off topic kinda, but how do you go about installing the Gentex. zach?
Originally Posted by HighLonesome
coralman is online now
post #13 of 14 Old 08-26-2013, 10:37 AM
zachjf
Here's my write up I did from back in my TJ days. I added it to my 5.9 so I can keep the fuel economy on the overhead console and have the compass/temp on the mirror
http://www.jeepforum.com/forum/f9/co...o-pics-952705/
Needs parts?
PM
or
zachjf is offline
post #14 of 14 Old 08-26-2013, 12:50 PM
coralman
coralman's Avatar
Thanks! On my list of stuff to do.
