Jeep dies after tossing belt - JeepForum.com
post #1 of 25 Old 09-16-2013, 11:27 AM Thread Starter
cbr900
1993 XJ Cherokee
As it says mine is dying just as it tosses a belt not too worried about the belt as im sure its just a bad pulley somewhere. But what would cause it to die? I was thinking battery but have had zero problems starting so im guessing battery is good. Any thoughts?
cbr900 is offline
post #2 of 25 Old 09-16-2013, 11:42 AM
WhiteOut
WhiteOut's Avatar
What year/engine?
Does it start up and then die after a second or two?
WhiteOut is offline
post #3 of 25 Old 09-16-2013, 02:16 PM
caseyliffick
I'd check the bearing on the alternator? If it starts up fine, battery is fine.
I was always told that when you throw a belt off, turn all of the pulleys on the system. If one grinds, the bearing I'd bad.
caseyliffick is offline
post #4 of 25 Old 09-16-2013, 03:10 PM Thread Starter
cbr900
1993 XJ Cherokee
Originally Posted by WhiteOut View Post
What year/engine?
Sorry forgot to add this one to my profile
1996 4.0
I never actually tried to restart it after it tossed the belt as it was late and not in the mood after about 4 times of the belt jumping on me. It would start right up after I put the belt on how ever as I said I never tried to start it with the belt off.
After work tomorrow ill take the belt off and try and start it.
cbr900 is offline
post #5 of 25 Old 09-16-2013, 03:13 PM Thread Starter
cbr900
1993 XJ Cherokee
I check all the pulleys everything spins fine with little play except the power steering pump there is enough resistance that if I try to spin it the wheel wont make one complete 360. Also there is a crack running across that same pulley im guessing thats what is causing it to jump. Not the factory gap where it was made but an actual crack.
cbr900 is offline
post #6 of 25 Old 09-18-2013, 06:01 PM Thread Starter
cbr900
1993 XJ Cherokee
Ok im at a loss here I replaced the power steering pulley but I still have the same problem. The jeep will randomly die and toss the belt.
-A/C off and on when it dies and tosses belt
-It always tosses the belt when it dies
-Never tosses a belt without stalling out
-It starts right back up with belt off as well as if I put belt back on
-Idles great, drives good
-All pulleys spin freely
-Check gauges light comes on when it dies
Since it dies and tosses the belt im guessing they are connected So the only thing that I can come up with that connects the 2 is the alternator. Maybe it locks up which causes the belt to jump and at the same time the jeep dies because of sudden loss of power. Kinda lie when you pull the battery cable with motor running it bogs down for a second.
Any thoughts? Id hate to buy an alternator only to have same problem.
cbr900 is offline
post #7 of 25 Old 09-18-2013, 07:26 PM
jabba974
Sounds like something is not algined properly...Check to make sure that your ps pulley is seated all the way...check your harmonic balancer, see if it is bad...check all your tensioner(s)
jabba974 is offline
post #8 of 25 Old 09-19-2013, 04:40 AM Thread Starter
cbr900
1993 XJ Cherokee
I dont think a pulley would cause the jeep to die, something is causing it to die and toss the belt at the same time
cbr900 is offline
post #9 of 25 Old 09-19-2013, 05:39 AM
newfieZJ
How well do all the pulleys line up ? Harmonic balancer going bananas ?
Is the belt being tighten enough ? Maybe check the adjuster to make sure it's not cracked , stripped or damaged in some way that it works loose .
Have the battery checked out just so it can be confirmed not the issue
newfieZJ is offline
post #10 of 25 Old 09-19-2013, 07:46 PM Thread Starter
cbr900
1993 XJ Cherokee
Battery is good as I can start the jeep with no problem and even run it on battery only, belt brand new adjusted to about 1/4" of play between PS and pulley to left
cbr900 is offline
post #11 of 25 Old 09-19-2013, 09:32 PM
newfieZJ
What about the pulleys ? ALL lined up ?
Broken bracket somewhere ?
Warped pulley ?
Double check all electrical connections , sensors , and even the PCM connection . You shutting down sounds like a temp loss of signal .
newfieZJ is offline
post #12 of 25 Old 09-20-2013, 03:48 PM Thread Starter
cbr900
1993 XJ Cherokee
Ok update I swapped my tensioner pulley (guess you cant buy idler pulley) belt has stayed on for about 40 miles of driving. Alternator is good but the connections at the computer are bad when I wiggled the connections the jeep would shudder. Cleaned them up and put Dielectric grease around the outside and Noalox on the pins. Wait and see I guess
Found a 2 wire connector just to teh left of computer about 6" long wasnt plugged in anyone know what it is? I know pics would help but its raining like crazy here right now.
Yet another update...finally saw the tensioner pulley was about 1/8" in to far allowing the belt to ride on the rounded lip. Bought a few washers to space it off of the bracket and all seems well now....at least I hope. The jeep kept dying so I used every last zip-tie I had on the computer to hold everything tight.
Let it idle for 45 mins with zero problems dont want to take it on the rode just yet.
All I know is the guy I bought it from must have sold his sole to the devil to keep the Jeep running while I test drove it.
cbr900 is offline
post #13 of 25 Old 10-05-2013, 08:30 AM Thread Starter
cbr900
1993 XJ Cherokee
My jeep keeps tossing the belt at random I replaced the tensioner pulley but it looked like it sat too far back so I spaced it out with a few washers. With engine off the belt sits square on the pulley but with engine on it pulls the belt towards the edge. It doesnt wobble back and forth it just stays in the same position. Any ideas?
You can see in the pic and vid how the belt is being pulled off at an angle slightly
cbr900 is offline
post #14 of 25 Old 10-05-2013, 09:24 AM
dnuccio
if everything else is aligned but its walking off the tensioner, theres something wrong with the tensioner
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #15 of 25 Old 10-05-2013, 11:05 AM Thread Starter
cbr900
1993 XJ Cherokee
The only thing i cane think of because it sits square with engine off is that with the engine on it places more tension on the belt which pulls the pulley down at an angle. Is it normal to require the tensioner pulley to be spaced off about 3/4". When I bought the jeep it had about 6 washers behind the pulley, which doesnt look right to me. Do any of you all know if there is some type of spacer behind your tensioner pulley?
cbr900 is offline
