jeep about left me stranded @ Mcdonalds on my lunch break - JeepForum.com
post #1 of 9 Old 11-22-2010, 11:53 AM Thread Starter
djustice
96 JGC 4.0 4x4 My jeep died on me @ Mcdonalds and it took a good 5 minutes to get it cranked...while on my way back to work it was spitting and sputtering and dying the whole way back.It did throw a CEL.. So i left the jeep at work that night and the next day i came back to take it to Autozone,it made it there fine no problems...They printed something off the computer to give to me because they couldnt make any sense of it so here it is Troubleshooting P1391 Definition: CMP or CKP signal intermittent condition. Explanation: The ECM detected the actual CMP position disagreed with the expected CMP level. Probable cause: 1. Timing belt or chain stretched or jumped. 2. Defective CMP sensor It would really help to know what the CMP or CKP sensor is
djustice is offline
post #2 of 9 Old 11-22-2010, 12:41 PM
colinzj
2006 WK
CMP's the Camshaft Position sensor, CKP's the Crankshaft Position sensor.
2006 WK Laredo 4x4 4.7L
1993 ZJ Laredo 4x4 4.0L Dead, sold, and rolling again
colinzj is online now
post #3 of 9 Old 11-22-2010, 12:43 PM
biggoofy
if its the crank have fun replacing it. its a tight fit right on top of the transmission bell housing
Zack
13 JKU Stock
93 ZJ F/R Long Arms, 4.56 gears
96 ZJ HP44 / 9" (RIP)
biggoofy is offline
post #4 of 9 Old 11-22-2010, 01:14 PM
sadass
I would bet on the cam shaft position sensor. It is under the distributor cap and rotor.
5NineZJ,35mtr/k IRO 7" LA F/R Detroit F/HP-4.56 R/Aussie 44A. ARB Snorkel/JRC Sliders/ Protofab w/9500S./Bushwhackers. Novak242 TCcable.
sadass is offline
post #5 of 9 Old 11-22-2010, 02:16 PM
Technohead
That's what you get for eating at McDonalds.
-Eric
Technohead is offline
post #6 of 9 Old 11-22-2010, 10:21 PM Thread Starter
djustice
thanks guys looks like i can test both sensors to make sure their bad....gonna get to that tomorrow...ill keep ya posted
djustice is offline
post #7 of 9 Old 11-22-2010, 10:23 PM
The_Blacksmith
1993 XJ Cherokee
they will hire anyone at autozone. I was the only person at mine who actually knew **** about cars.
The_Blacksmith is offline
post #8 of 9 Old 11-23-2010, 07:38 AM
straight-pipe
does it fire up when it is cold and get worse as you drive? if so it's your crankshaft sensor at the top of your tranny bell housing.
to test the crank sensor, boil water stick it in the water and test it when hot. the heat from your torque converter damages those things. They are only made of plastic and is susceptible to heat damage. They will usually work when cold and flake out when hot.
I just reread your post and yes, it sounds exactly like a crank sensor issue, had this happen twice in my life time.
94 ZJ 5.2L
07 JK 3.8
straight-pipe is offline
post #9 of 9 Old 11-23-2010, 06:30 PM
JesseOR
hahaha!!! That is what I thought as soon as I read the title!
-Jesse-
GO DUCKS!
www.facebook.com/jesse.whitehargrove
JesseOR is offline
Please Help, Car Left Me Stranded?!?!? AlbertN83 ZJ Grand Cherokee Forum 11 01-06-2009 07:48 PM
left rear tails do not work--left signal, backup and left stop do kenific WK Grand Cherokee & XK Commander Forum 10 12-07-2008 01:38 PM
spring break Jeep goin too Dillonzj ZJ Grand Cherokee Forum 31 03-07-2008 01:43 PM
Jeep Left Me Stranded 93JeepZJ ZJ Grand Cherokee Forum 18 12-30-2007 01:07 PM
Well Crap, she left me stranded JohnnyD ZJ Grand Cherokee Forum 2 08-29-2006 02:46 PM
