Jack slipped, crushed oil pan. - JeepForum.com
post #1 of 9 Old 08-22-2013, 01:38 PM Thread Starter
ZJMatt
Pulling the front axle out of my parts jeep. I noticed the jack stands were sinking into the driveway and leaning pretty bad. So I figured I'd jack it up before they tipped over and the jeep fell (possibly on me).
As I was getting the jack under to remove/reposition the stands, the jeep fell off of them. Landed on the LCA brackets and oil pan. There is a noticeable dent in the oil pan. I have it jacked back up and sitting on a 4x4 beam for the time-being.
I was planning on selling this motor, since it was a great running motor. Could landing on the oil pan have caused any damage, aside from to the pan itself? Is it something I could check by pulling the pan off?
The "Mall Crawler" - 1998 ZJ Grand Cherokee 5.2 V8, 5.5" LongArms, 32s, 12000lb winch & more.
ZJMatt is offline
post #2 of 9 Old 08-22-2013, 01:49 PM
zj97ltd
Maybe damaged the oil pump and/or pickup but I wouldn't think it would hurt the bottom end. Should be easy enough to see by pulling the pan.
zj97ltd is offline
post #3 of 9 Old 08-22-2013, 01:51 PM Thread Starter
ZJMatt
What will I be looking for in the pump/pickup?
ZJMatt is offline
post #4 of 9 Old 08-22-2013, 01:59 PM
zj97ltd
Look where the dent in the pan is, then when you pull it see what's in that area. The obvious would be a dented or badly kinked pickup tube or a dent in the pump itself.
zj97ltd is offline
post #5 of 9 Old 08-22-2013, 02:37 PM
erisbrow
1994 ZJ
Yeah, just pull the pan and inspect. See if the dent is near the oil pump and/or pickup. If so look for contact points/scuff marks inside the oil pan and on the pickup.
erisbrow is offline
post #6 of 9 Old 08-22-2013, 02:50 PM Thread Starter
ZJMatt
It's right in the middle of the lowest point of the pan. Where approximately is the pump/pickup?
ZJMatt is offline
post #7 of 9 Old 08-22-2013, 03:11 PM
erisbrow
1994 ZJ
On this particular motor im not sure, but traditionally it is towards the back of the motor and hangs out below your crankshaft...
erisbrow is offline
post #8 of 9 Old 08-22-2013, 03:16 PM
erisbrow
1994 ZJ
Here is a V8 with the pan pulled. The round guy towards the back is the pickup.
erisbrow is offline
post #9 of 9 Old 08-22-2013, 04:47 PM
dusterdude
The pump extends into the sump of the pan
dusterdude is online now
