jack points - JeepForum.com
post #1 of 25 Old 12-13-2007, 12:36 PM Thread Starter
BLACKzj52
jack points
i have a floor jack, and it doesnt even reach the frame rails, and barely gets to the axle tube..
iv heard of using the diff housing as a jack point but im skeptical about this..
what are your guys' insights about that??
yay or nay?
also, what are some other good jack points (on the unibody) to let the axle hang.
can you put a jack under the lower stock control arm mount?
any other areas that you can put a jack under that i would not think of?
thanks
BLACKzj52 is offline
post #2 of 25 Old 12-13-2007, 12:44 PM
nierace
nierace's Avatar
2003 WJ
buy a better jack.
Nickerdoodle
03 WJ 4.7 242HD Kolak/IRO 5" Clayton LA's
35" BFGoodrich KM2
North East Offroad Club
nierace is offline
post #3 of 25 Old 12-13-2007, 12:47 PM
ZJ_Dave
I've heard that you're not supposed to jack it from the pumpkin. I'm glad my school has lifts, I just bring it into the shop when I need it to be in the air. Here's what the manual says:
Is it summer yet?
'98 ZJ! 4.0L Laredo, with some upgraded stereo stuff.
Originally Posted by greasefingers
Great pictures! Now I know what she looks like naked.
ZJ_Dave is offline
post #4 of 25 Old 12-13-2007, 12:47 PM
sandman
ive heard that if you have the 44a nay, but every other axel housing is a great jack point. also bottom of control arms will work too.
ps. if you put a 2x4 between your 44a and the jack im sure you wont have any problems
1993 Jeep ZJ. 4.0
sandman is offline
post #5 of 25 Old 12-13-2007, 01:16 PM
ajmorell
ajmorell's Avatar
I don't think it is physically jacking on the pumpkin of the 44a that hurts it, but has more to do with the way in which the axle tubes are pressed into the pumpkin. You can jack from the pumpkin, but it's really not recommended. If you need to, you can use a couple of 2x4s (like 2, not 12) to make up the height difference to the unibody. I think are risking bending the crap outta the LCA mount by jacking on it. I believe you can also put a jack under the knuckle too if you need to, it is about as high off the ground as the pumpkin.
ajmorell is offline
post #6 of 25 Old 12-13-2007, 01:58 PM
alivenkickin28
i'd just use the frame rails.... how come yours wont work blackzj do you have a lift?
1995 JGC Limited 5.2 v8, black with gold trim
1976 Olds 98, 82 Olds 98, 84 Olds 98, 89 Trans AM
alivenkickin28 is offline
post #7 of 25 Old 12-13-2007, 02:03 PM Thread Starter
BLACKzj52
i wish..
it just doesnt go up high enough lol
so basically what im hearing is, if i am going to do it, use a 2x4, but dont make a habit of that?
post #8 of 25 Old 12-13-2007, 02:09 PM
Wiley
Wiley's Avatar
What the heck kind of jack do you have?
Justin
1993 ZJ Laredo
5.2 V8 4" lift 31s JKS f & r track bars JKS discos Cragar Soft 8s DT 3000s OME Stabilizer
K&N drop-in Dynomax Exhaust Hella 500s Westin Safari Bar KOR Radiator Support
Dark Rosewood Jeep Club Member #5
Wiley is offline
post #9 of 25 Old 12-13-2007, 04:01 PM
CMARJEEP
CMARJEEP's Avatar
so you have a ricer jack?? i got the one from walmart for $60 that goes 23". works great. just get a new jack.
Chrismas is right around the corner and theres no better present than car parts.
CMARJEEP is offline
post #10 of 25 Old 12-13-2007, 04:36 PM
nashmd454
nashmd454's Avatar
I got a typical 2 ton jack from the local auto parts store and have lifted from the pumpkin and the lower ca's and even the axels themselves...but I do hear it is not recommended for fear of bending and all stuff mentioned in earlier posts....don't follow me on this one...I have been lucky to not damage mine...so I may just get a better one that reaches the stars.
96' JGC V-8 5.2L ltd.
way too much to list.
Thought for the day:
If GOD gave HIS only son for us...can't we at least give HIM an hour of our time a day.
nashmd454 is offline
post #11 of 25 Old 12-13-2007, 05:30 PM
alivenkickin28
yeah i have regular floor jack as well but never hve had a problem...but haven't done much to mine to require it be higher...
post #12 of 25 Old 12-13-2007, 05:37 PM
CLNinja
CLNinja's Avatar
you can get a 23" floor jack from harbor freight for 45 bucks
just get a better jack cause yours obviously sucks and is made for jacking up a Saturn
dont jack from your pumpkin... is it really worth the risk?
would you rather buy a new axle or a new jack?
Matt
**September 2009 Grand Cherokee Of The Month**
CLNinja is offline
post #13 of 25 Old 12-13-2007, 06:55 PM
dickensheets
a 4x4 block of lumber is a good cushion between vehicle and jack.
99 WJ V8, 245/75/16 MT/R and Rusty's 2.5" coils and shocks, IRO trac bar, homespun end links, block heater!! 220V MIG w/75-25 and OXY/Acetalene rig if you need it! Just let me know
dickensheets is offline
post #14 of 25 Old 12-13-2007, 08:32 PM Thread Starter
BLACKzj52
lol the jack i got was in a kit with 2 1/2 ton jack stands all for $40.. i woulda thought it woulda gone higher than it does.
i got ripped off
post #15 of 25 Old 12-13-2007, 08:46 PM
ZJ_Dave
What about your factory jack, under the seat?
Is it summer yet?
ZJ_Dave is offline
Jack points and stands jeeper31 WK Grand Cherokee & XK Commander Forum 6 07-16-2013 07:06 PM
wj floor jack points? stupid i know PJNovinskee27 ZJ Grand Cherokee Forum 4 05-07-2008 05:47 PM
hi-lift noob - jack points? crozzer ZJ Grand Cherokee Forum 10 08-16-2007 06:34 PM
hi lift jack points canadia_driver ZJ Grand Cherokee Forum 9 01-28-2006 08:52 PM
WJ Jack points? jo8243 ZJ Grand Cherokee Forum 4 11-19-2004 08:53 PM
