Is itNormal for the front tires on the NP249 to slip on wet pavement ? - JeepForum.com
post #1 of 7 Old 09-08-2011, 11:07 PM Thread Starter
Candymancan
I noticed when i drive my 5.9 on dry roads that have tar or sealant on them and im turning my wheel that my front wheels always seem to slip or make skidding noises. They do this on wet roads also. I recently replaced my viscous coupler and i hadnt noticed this before until recently when they put that sealer on the roads in my neighborhood and also the gas station lot. Like when i back out of my parking spot and turn the wheels almost fully locked to get outa there after i go back in drive the front wheels makes skidding noises like the wheels are grabbing and sliding.
Also tonight when i made a u-turn on the wet pavement outside from all the rain we've been getting. Just curious if this normal in these conditions cause it has me questioning this new viscous coupler. Its probably nothing but i want to know if you guys get the same noises on these types of road conditions. Like also when i make a full lock u-turn i dont really get wheel hopping (altho that is unavoidable even with a working VC on full lock) but my tires sound like they are shredding on the road, specially if i give it good gas the rear tire that is on the inside of the turn sounds like its slipping.
Candymancan is offline
post #2 of 7 Old 09-08-2011, 11:16 PM
punisher65
punisher65's Avatar
2006 WK
i had the same problem and i looked around and someone mentioned that i needed some special fluid from mopar instead of atf so i put that in and most of the "slipping" went away
2006 5.7 WK
OME HD, 265/70-17 Duratracs on Level 8 Strike 5, Aspen Creek Shackle Mounts,
Airaid CAI, Superchips Flashpaq, Gibson 3" catback, Steel Armadillo Engine Skid Plate
BT Catch Can, TB ground, Cree LED Reverse Lights, Interior LED upgrade
1993 4.0 ZJ
BB and 31" Bighorns SOLD :(
punisher65 is offline
post #3 of 7 Old 09-08-2011, 11:23 PM Thread Starter
Candymancan
Like the noise is the skidding noises you hear in concrete parking garages when people make sharp turns and there tires slip, as for the fluid, that shouldnt do anything as its a closed system. The special fluid is what lubricates the couplers in the Quadra drive and Quadra trac transfer cases in the Wj's
post #4 of 7 Old 09-09-2011, 01:03 AM
Falkon
Sounds like your new coupler is bad.
Falkon is offline
post #5 of 7 Old 09-09-2011, 03:34 AM Thread Starter
Candymancan
Well i dunno its wierd, cause my tires arent wearing out like they were with the old bad VC, and i dont have issues making u-turns like i did before. Basicly my front tires squeel when i make turns on slippery surfaces like concrete, or aspalt thats had tar put on, or wet roads
post #6 of 7 Old 09-09-2011, 06:58 AM
Dyn0mitemat
x2
09 Rubi 2dr:MetalCloak2.5", 37"MTZ's/Slabs, EVO Stff, ORFab Cage, Chromo's, Driveshafts etc
Dyn0mitemat is offline
post #7 of 7 Old 09-09-2011, 07:37 AM
Newb1995jeepgc
1994 ZJ
Mine does the same thing when i pull in to like mcdolnalds because its that slick tar coating. ive found all the 249 jeeps ive drove make that noise.. even my 242 does it sometimes even if in 2wd.
1995 Jeep ZJ Limited V8- 213k- sold
2000 Jeep WJ I6- 185xxx-sold
1994 Jeep ZJ Limited Red I6- 210k
Newb1995jeepgc is offline
Torque Split NP249 & front driveshaft removal rlcii77 ZJ Grand Cherokee Forum 18 05-24-2011 01:46 PM
Front DS Slip Yoke Help Please! Jsun ZJ Grand Cherokee Forum 3 08-18-2010 03:04 PM
np249 w/o front ds dlvsdh ZJ Grand Cherokee Forum 6 07-10-2010 05:49 AM
How much slip in front driveshaft? -Joseph ZJ Grand Cherokee Forum 1 10-21-2009 12:43 PM
Can you drive a NP249 w/o a front drive shaft? branman444 ZJ Grand Cherokee Forum 13 08-21-2007 10:55 AM
