Issues with ride - JeepForum.com
post #1 of 6 Old 04-08-2009, 07:26 AM Thread Starter
Poke
runtime error = 0
Poke's Avatar
2015 YJ Wrangler
Issues with ride
My WJ 89K has some issues....
The ride and steering seem loose. Its stock but rides like it is unstable. Wanders on corners and the steering seems very squirly for being stock. It drives more like my YJ not like an SUV.
What should I look at to stiffen up both the ride and the steering?
Originally Posted by ionakana
don't post threads that poke Poke!
Poke is offline
post #2 of 6 Old 04-08-2009, 07:41 AM
xJoshxx
2012 WK
I bet your Track bar Bushings are done and Possibly Check your Tie-rod ends any up down movement is bad rotational is ok.
and lookin into replacing the steer stablizer with a Heavy Duty one From like KOR or IRO
And replace rear Sway bar it's Piss poor to say the least.
Use a Addco Sway bar ur body roll wont happen anymore, then
Contact Kolak@aol.com or Kolak on here and PM him
Sold4" Hybrid lift TeraFlex coils IRO Adjustable LA's Jks tracbar 1.25spidertrax spacers 265/75/16 Dura-tracs
Originally Posted by moPowered View Post
The SRt-8's are a liberty design.
2011 WK2 ORA2 sold
2012 WK2 SRT8 - Current
99 WJ Limited Lifted.
2001 WJ stock 4.0 304k miles
xJoshxx is offline
post #3 of 6 Old 04-08-2009, 08:22 AM
coupleofjeeps
agreed... start with getting some fresh bushings on all the components, its the cheapest start and spend a few bucks to get a good steering stabilizer... other than that, depending on how well you know your jeep, get under there and look for oddities, even check for leaking shocks, may need a good alignment etc.
coupleofjeeps is offline
post #4 of 6 Old 04-08-2009, 09:25 AM Thread Starter
Poke
runtime error = 0
Poke's Avatar
2015 YJ Wrangler
Thanks! but please stay with me a second...
i have never messed with Track Bar or tie rods, or sway bar for that matter...
Can I put new bushings on the track bar with out any special tools?
what exactly am I looking for on the tie rod ends? Are there bushings? or might the tie rods need to be replaced?
I will look into ordering a new rear Addco sway bar, is this a simple swap?
Poke is offline
post #5 of 6 Old 04-08-2009, 10:02 AM
walter_da_jpr
4.0 Piston Skirt Victim
walter_da_jpr's Avatar
Its possible that you could need new ball joints as well.
WALTER
walter_da_jpr is offline
post #6 of 6 Old 04-08-2009, 10:10 AM
vosevichs
Grab the tie rods and check for looseness and make sure they twist. There's 4 of them. Put a jack under the axle and wiggle/lift the tire to check ball joints for looseness. With the tires on the ground have some one turn the steering wheel back and forth while you look at the front end components.
Scott Vosevich
vosevichs is offline
High RPM issues and tranny issues Jeep Kid ZJ Grand Cherokee Forum 3 01-26-2010 04:09 PM
04 GC hvac issues-blower motor and other issues nation1979 ZJ Grand Cherokee Forum 1 09-02-2009 09:47 PM
New Ride SRT8driver ZJ Grand Cherokee Forum 18 06-16-2006 09:46 AM
Fun Ride gunthagunth ZJ Grand Cherokee Forum 15 04-11-2006 09:53 PM
Need a better ride... JamesEric ZJ Grand Cherokee Forum 3 10-02-2005 10:33 AM
