Issues removing transfer case - JeepForum.com
post #1 of 12 Old 11-18-2012, 03:09 PM Thread Starter
antimorphisis
I sure someone has asked this before, but I cannot seem to get the transfer case to separate from the transmission. I have disconnected everything. Electrical connections, vent hose, shift linkage, both drive shafts, and all six nuts. Yet the damned thing will not come free. it's an np 242 i'm trying to remove because the rear of the case is cracked. I've tried pry bars, and even a come along, nothing is breaking this thing free. Any advice would be helpful, before i completely destroy something.
antimorphisis is offline
post #2 of 12 Old 11-18-2012, 04:43 PM
squazz
pb blast the studs one might be corroded I had this issue when doing my 94 or put the trans in neutral (i dont know if trans in neutral dose anything but i was in the same boat as you the damn tc would not come off.) i did both at the same time so I dont truly know wich solved the issue
squazz is offline
post #3 of 12 Old 11-18-2012, 04:44 PM
Rich93ZJ
I remember reading something about a dowel (locator) pin that get welded together over time due to galvanic corrosion. I think I read it in the transfer case swap thread in the FAQ section. Hope this is useful.
Rich93ZJ is offline
post #4 of 12 Old 11-18-2012, 05:01 PM
zarnold
Hmm.... That's strange, both of mine started moving once I got the six nuts loose. Are you sure you got the top nut (I know you said you did), that is the only thing that I can thing of. And, do you have it set up so that you can drop the transmission a little?
zarnold is offline
post #5 of 12 Old 11-18-2012, 05:19 PM
biggoofy
Wack it with a dead blow
Zack
13 JKU Stock
93 ZJ F/R Long Arms, 4.56 gears
96 ZJ HP44 / 9" (RIP)
biggoofy is offline
post #6 of 12 Old 11-18-2012, 06:02 PM
98GCLimited
Drop kick it.
98GCLimited is offline
post #7 of 12 Old 11-18-2012, 06:17 PM
Freestyle713
1994 ZJ
Just put the driveshafts back in and drive it around. It will fall out sooner or later
94 Grand Cherokee 5.2 33in. Federal Couragia M/T's on Procomp Steelies, np231 swap, IRO Hack n Tap SYE, Carolina Driveshaft, 4.5 in. lift, RE front upper/rear lower ca's, RC front lowers, Ironman rear uppers, IRO 4.5 coils in rear, 3.5 and 2" bb (no isolators) in front, Bilstein 5100's, Clayton/JKS adj. track bars, KOR rad support and SS, Magnaflow/Flowmaster exhaust, clear corners, custom light bar w/ Hella 500's
Originally Posted by elcorvino View Post
Yea... It's kind of like the fat chick who lives around the corner. You aren't trying to get caught with her, but you know she'd be a good time.
Originally Posted by ScottD16 View Post
I had a dream my entire family was attacked by a giant polar bear. The crazy part was he attacked us with a giant spoon. Best dream ever.
Freestyle713 is offline
post #8 of 12 Old 11-18-2012, 06:49 PM
xtremzj
Air hammer the part that's stuck.
98 ZJ 5.5in hybrid long arm/35"TSLs/4.7 Golen Stroker/Kevin's front bumper/TrailReady rear/hp30/d44/4.56/oba/dual battery/rocklights/milemarker9k.Way to much to list.
QuirkWorks Sponsored #44 subaru rally car
CHRYSLER CERTIFIED MASTER TECH. PM IF YOU HAVE QUESTIONS.
xtremzj is offline
post #9 of 12 Old 11-18-2012, 08:20 PM
sevenscrew
Make sure ur pulling it straight out and not on a down or up angle
1997 Limited 5.2L - SOLD
2016 2DR JK
sevenscrew is offline
post #10 of 12 Old 11-19-2012, 09:01 AM Thread Starter
antimorphisis
thanks guys, i'm going back at it today, i haven't tried the trans in netural yet, i'll try that and see what happens. it's almost there i can see light thorugh the top but it just doesn't want to let go. I'll let you guys know what happens.
post #11 of 12 Old 11-19-2012, 02:52 PM
Coog
1999 ZJ
We pulled and hauled at one for 30 mins before realising we had a bolt still done up. Double check them again to be sure. We even had day light coming through one bit lol
Coog is offline
post #12 of 12 Old 11-19-2012, 07:26 PM Thread Starter
antimorphisis
alright, finaly got it out, turned out it was the top passenger side stud. The stud was so corroded it actually had about a quarter inch of build up on it and that prevented it from sliding out. All it took was four hours and a bunch of varying size flat tip screwdrivers and wiggling the thing from side to side until it fell out. Now i got it apart and that thing is pretty busted up from being run dry. so now it's on to the rebuild. Once again thank you all for the help.
