Iser's Build Thread - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Iser's Build Thread
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!The Ruffstuff NOT Universal 4 Link Kit!
Unread 08-21-2012, 08:06 PM   #16
iser
20AUG2012 - New Tires!!!
Cooper Discoverer STT - 285/75R16
[B]- REST IN PEACE, RATMONKEY - [/B]
[URL="http://www.jeepforum.com/forum/f13/isers-build-thread-1401938/"][B]MY BUILD THREAD LINK[/B] - [I]Updated on THU 23MAY2013[/I][/URL]
[B]Specs[/B]- 97 ZJ 5.2L - 4" Zone Lift - 285/75R16 Cooper STT
[B]Upcoming Projects[/B]- Front Axle Swap. On the look out for HP30.
_______________________________________________
[B][I]"lead me, follow me or get the hell out of my way"[/I][/B]
- gen. george patton
iser is offline   Reply With Quote Quick reply to this message
Unread 08-21-2012, 09:10 PM   #17
Kevinyj95
Nice
Kevinyj95 is offline   Reply With Quote Quick reply to this message
Unread 08-21-2012, 09:27 PM   #18
iser
mehhh...too close in the rear. i really don't want to cut into the door. any advice?
Unread 08-21-2012, 09:33 PM   #19
sskilla
your rear suspsension tucks up and back, so you should be good.
only other option is all rear full adjustable CA's to push the axle back a bit.
'95 ZJ: 5.2 v8 / 231 Tcase / 46RH
sskilla is offline   Reply With Quote Quick reply to this message
Unread 08-21-2012, 10:00 PM   #20
booked101
Flex. Take picture. Report back.
good gas mileage is highly overrated.
(J)ust(E)mpty(E)very(P)ocket
booked101 is offline   Reply With Quote Quick reply to this message
Unread 08-21-2012, 10:25 PM   #21
Dyn0mitemat
Build looks good
When are the tons & 40's coming? :P
09 Rubi 2dr:MetalCloak2.5", 37"MTZ's/Slabs, EVO Stff, ORFab Cage, Chromo's, Driveshafts etc
Dyn0mitemat is offline   Reply With Quote Quick reply to this message
Unread 08-21-2012, 10:30 PM   #22
PolkaPower
More than enough room! I have had the rear tires with barely a finger widths space between them and the rear rockers and it doesn't rub. The suspension flexes backwards and up away from the door so as long as the tires are not touching it's fine.
Look how close it is here and there was no problem.
PolkaPower is online now   Reply With Quote Quick reply to this message
Unread 08-21-2012, 10:32 PM   #23
Dyn0mitemat
x2 you probably didn't need that much but extra clearance doesn't hurt.
Unread 08-26-2012, 02:46 PM   #24
iser
25AUG2012 - Before/After Comparison
Stock Lift + 30" Tires
4" Lift + 33" Tires
Unread 08-26-2012, 02:59 PM   #25
Montaska
Big Sky, Endless Beer
Montaska's Avatar
Looks great!
Montaska is offline   Reply With Quote Quick reply to this message
Unread 08-26-2012, 03:37 PM   #26
booked101
4" Lift + 33" Tires
Did u have to change out your control arms?
Sent from my MB870 using JeepForum
Unread 08-26-2012, 03:45 PM   #27
iser
the kit came with new fixed LCAs. i'm looking to get adj f/UCAs sometime soon in the future.
Unread 09-01-2012, 08:47 PM   #28
iser
01SEP2012 - Spidertrax Wheel Spacers Installation
getting my driveshaft and wheel spacers ready
the bolts were rusty and muddy so decided clean all the threads.
thread locker. i put some more on it after i took the pictures
unfortunately, even with 1.25" spacers, there is a slight rub on the front passenger tire against the lower control arm at full lock. this is probably due to the fact that my axle is not centered (it is off by 1/4" or so).
Unread 09-01-2012, 08:50 PM   #29
iser
01SEP2012 - Rear Driveshaft/Differential Work
when i swapped my transfer case from 249 to 242, i didn't realize that the driveshaft length was different due to the fact that my 249 had internal slip yoke and 242 had external slip yoke. installing that driveshaft was a real pain since, well, it is 1.5" longer than what it is supposed to be.
so, that driveshaft should've never gone in there and it's not coming out. after 15 minutes of frustration, i decided to just chop it off. it was the right decision.
fits perfectly now
finally decided to drain and refill the rear differential. i knew it had fluids and never had trouble from the rear so it was something i kinda put off until now. but since i have experience in destroying a differential by running it dry, i decided to drain/refill before any kind of trouble shows up.
when i drained it, i couldn't believe how great condition it is in. everything looks brand new in there.
done. simple half hour work.
Unread 09-01-2012, 08:51 PM   #30
iser
01SEP2012 - Random Musings
it's been over 2 weeks since i installed my lift kit and i have over 100 miles on them now. so decided that it would be a good time to re-torque.
so while retorque-ing my sway bar link....yea, the grade 3 bolt snapped. i cannot believe 2 weeks old bolt snapped. i am completely mind blown. it makes me question every single part that came with my lift kit. there is a part of me that wants to strip the lift kit, and demand a refund.
if a swaybar link bolt breaks while torque-ing, then what's next? is the track bar bolt next?
and i just cannot get the rear swaybar links to sit right.
i am totally paranoid (actually, it's probably not paranoia. it's actually a legitimate concern) about my track bar
oh, and does anyone know what this is? it is left unplugged on the front driverside behind the bumper.
so the latest pics of the jeep:
33 , build , build thread , jeep , zj
