Iser's Build Thread - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Iser's Build Thread
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.comBUMPERS by Rough Country! SOLD at ROCKRIDGE 4WD!! AWESOME
Unread 08-05-2012, 11:18 PM   #1
iser
ZJ Addict
iser's Avatar
Iser's Build Thread
CURRENT SPECIFICATION
Engine: 5.2L V8
Front Axle: D30
Rear Axle: D44a
Gear Ratio: 3.73
Transfer Case: NV242
Transmission: 44RE
Lift: Zone Offroad 4" Kit
Tire: Cooper Discoverer STT - 285/75R16
Armor: Factory Skid Plates
Bumper: Protofab Front Bumper
Recovery: Tabor 12k Winch / Hi-Lift Jack
VEHICLE LOG
6/8/2012 - 185760 miles
Vehicle Registration
Battery Purchase
6/16/2012 - 185820 miles
F/Passenger CV Axle Swap
Fuel Pump Swap
7/7/2012 - 186080 miles
Front Axle Swap
Front Differential Drain/Fill
7/14/2012 - 186160 miles
Transmission Fluid Drain/Fill
Engine Oil Drain/Fill
8/5/2012 - 186320 miles
Zone Offroad 4" Lift Kit
8/19/2012 - 186490 miles
NV242 Transfer Case Swap
Front Driveshaft Swap
8/20/2012 - 186510 miles
Cooper Discoverer STT 285/75R16 Tires
9/1/2012 - 186650 miles
Spidertrax 1.25" Wheel Spacers
Rear Differential Drain/Fill
Rear Driveshaft Swap
Re-Torque
9/8/2012 - 186700 miles
Seafoam TransTune
10/1/2012 - 186888 miles
Winterization
Engine Oil Change
Transmission Fluid Change
Transmission R/Band Adjustment
Muffler Crack Repair
10/3/2012 - 186709 miles
Transmission TV Cable Adjustment
10/5/2012 - 186709 miles
4.0L Disassembly
10/13/2012 - 187011 miles
Engine Oil Change (Due to Oil Filter Gasket Failure)
10/21/2012 - 187072 miles
Front Bumper + Winch
10/27/2012 - 187118 miles
Engine / Transfer Case / Fuel Tank Skid Plates
10/28/2012 - 187124 miles
Tip Over
11/04/2012 - 187176 miles
Coolant Flush
Thermostat Replacement
Window Repair
11/05/2012 - 187178 miles
Window Repair
HID Lights
11/09/2012
CB Radio
Dimmer Switch Repair
11/10/2012
1" Additional Front Coil Spacers
FUTURE PROJECTS
(non-prioritized)
- Install Hi-Lift Jack Mount
- Install Dual Battery Setup
- Replace Brake Rotors / Calipers
WISHLIST
- Roof Rack
- Spare Tire Carrier
- Autostart
- Air Locker
MAINTENANCE
- Head Gasket Repair
- Plenum Gasket Repair
- Dash Vent Repair
- Drag Link Adjustment
- Interior Lights Repair
- Heated Seats Repair
INDEX
18JUN2012 - First Ride
30JUN2012 - Camping Trip
05AUG2012 - 4" Lift
19AUG2012 - Xfer Case Swap + Misc
20AUG2012 - 33" Tires
25AUG2012 - Before/After Comparison
01SEP2012 - Spidertrax Wheel Spacers Installation
01SEP2012 - Rear Driveshaft/Differential Work
01SEP2012 - Random Musings
05OCT2012 - Round One
06OCT2012 - Round Two
13OCT2012 - Round Three
21OCT2012 - Front Bumper + Winch
27OCT2012 - Skid Plates
28OCT2012 - ROLLOVER!
01NOV2012 - Body Repair
04NOV2012 - Coolant Flush / Thermostat Replacement / Window Repair
05NOV2012 - Window Repair Continued / HID Lights
09NOV2012 - Heated Seats / CB Radio / Dimmer Switch
10NOV2012 - Coil Spacer Stack
MY BUILD THREAD LINK - Updated on MON 28JAN2013
Specs- 97 ZJ 5.2L - 4" Zone Lift - 285/75R16 Cooper STT
Upcoming Projects- Nothing until the spring. It is too cold in Alaska. Just making sure it doesn't fall apart.
_______________________________________________
"lead me, follow me or get the hell out of my way"
- gen. george patton
iser is offline   Reply With Quote
Unread 08-05-2012, 11:29 PM   #2
iser
ZJ Addict
iser's Avatar
Bought the ZJ about a week before this. The weather was nice, so I took it out for a ride. Upto this point, the ZJ was going to be my disposable ride. I am leaving Alaska in a year so I wanted a throwaway vehicle. But, I had so much fun off-roading that day that I got hooked and decided to keep it.
the problem is that i ended up flooding it. and i guess the previous owner had a cat. the smell didn't come out until things got wet. then the entire jeep smelled like cat piss so i had to rip everything out.
Unread 08-05-2012, 11:31 PM   #3
iser
ZJ Addict
iser's Avatar
At about 10pm one night, I was bored. So I packed my things and went camping. I find a cool spot but eventually I couldn't go any further and turned around. I vowed to lift my jeep asap. Found a nice spot by the river, started fire and read for awhile. It was a nice relaxing night.
Everything was fun and I had a great time, until the ride back. There was a leak in the differential, and I drove it dry for about 50-60 miles at highway speed. Not good. My differential got grenaded so i had to pull an axle from a junkyard.
Unread 08-05-2012, 11:34 PM   #4
iser
ZJ Addict
iser's Avatar
5AUG2012 - Lift
i didn't bring the camera the first day, so i didn't get any 'before' pictures in.
also, new tires coming soon!!!
Unread 08-05-2012, 11:41 PM   #5
WhiteOut
WhiteOut's Avatar
Looks good, now that I see it I would grab a set of 1.25" Spidertrax spacers and run JK Rubi takeoffs on it.
IMO it would be a perfect fit and look.
WhiteOut is online now   Reply With Quote
Unread 08-05-2012, 11:49 PM   #6
Canyon411
Did you power wash your carpets (I assume you knew what urinefor) or did you buy a new carpet kit from somewhere? How did things end up?
Canyon411 is offline   Reply With Quote
Unread 08-06-2012, 12:07 AM   #7
iser
ZJ Addict
iser's Avatar
how are spacers for off-roading? someone was telling me that it adds additional point of failure and it's just better to get new wheels.
also, i took it by the hose and got on my hands and knees with a scrub brush and carpet soap. scrub and rinse and repeat several times. got the smell out. and i actually got to learn a lot about the wiring under the carpet. also took the opportunity to paint the center console and it turned out better than i expected.
Unread 08-06-2012, 12:09 AM   #8
WhiteOut
WhiteOut's Avatar
Properly torqued with lock-tite, they are 100% fine. No more stress than a wheel with more backspacing. I ran mine for about 20k or so and no issues.
Unread 08-19-2012, 10:44 PM   #9
iser
ZJ Addict
iser's Avatar
19AUG2012 - XFER CASE SWAP + MISC WORK
finally swapped my 249 with 242 today!
then i decided to trim my fenders a little bit to get ready for my 33"
Unread 08-20-2012, 09:05 AM   #10
Kevinyj95
Looks good cant wait to see the 33s on there.
Kevinyj95 is offline   Reply With Quote
Unread 08-20-2012, 09:55 AM   #11
iser
ZJ Addict
iser's Avatar
picking them up as soon as the i receive the wheel spacers from kolak. hopefully that will be thu/fri.
Unread 08-20-2012, 10:00 AM   #12
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
You're gonna love the Coopers.
Mine are in there 3rd year, finally showing some wear and making a bit of noise on the freeway.
HighLonesome is offline   Reply With Quote
Unread 08-20-2012, 10:19 AM   #13
Myusername1674
Myusername1674's Avatar
Lookin good man! I myself LOVE black Zj's, and black vehicles in general, just flat out the best imo. Have any more pics of your fender trimming? I need to do some so that When i flex out my suspension my sidewalls don't rub on any jagged edge.
5.2l V8 ZJ, High Flow cat, 2" BB, 31" Guards, Black 8's, Kor Rad support, cowl snorkel, interior blue LEDs, Front bumper fascia delete, Custom Rear Bumper Trim, smoked heads and tails, Alpine Sound System+Kicker12" and Polk10" etc...
My Free Jeep Build
Myusername1674 is offline   Reply With Quote
Unread 08-20-2012, 11:35 AM   #14
Montaska
Hermagerd.
Montaska's Avatar
Awesome looking Jeep! Are you at Wainwright?
My Slow Build: www.jeepforum.com/forum/f13/montaskas-build-thread-1409578/
11b (OIF)
Montaska is offline   Reply With Quote
Unread 08-20-2012, 12:06 PM   #15
iser
ZJ Addict
iser's Avatar
yep on FWA. i'm with 1-24in.
33 , build , build thread , jeep , zj
