-   -   Iser's Build Thread (http://www.jeepforum.com/forum/f13/isers-build-thread-1401938/)
iser 08-05-2012 11:18 PM
Iser's Build Thread
http://i1325.photobucket.com/albums/...y/P1010703.jpg
http://imageshack.us/a/img546/1176/p1010579u.jpg
CURRENT SPECIFICATION
Engine: 5.2L V8
Front Axle: D30
Rear Axle: D44a
Gear Ratio: 3.73
Transfer Case: NV242
Transmission: 44RE
Lift: Zone Offroad 4" Kit
Tire: Cooper Discoverer STT - 285/75R16
Armor: Factory Skid Plates
Bumper: Protofab Front Bumper
Recovery: Tabor 12k Winch / Hi-Lift Jack
VEHICLE LOG
6/8/2012 - 185760 miles
Vehicle Registration
Battery Purchase
6/16/2012 - 185820 miles
F/Passenger CV Axle Swap
Fuel Pump Swap
7/7/2012 - 186080 miles
Front Axle Swap
Front Differential Drain/Fill
7/14/2012 - 186160 miles
Transmission Fluid Drain/Fill
Engine Oil Drain/Fill
8/5/2012 - 186320 miles
Zone Offroad 4" Lift Kit
8/19/2012 - 186490 miles
NV242 Transfer Case Swap
Front Driveshaft Swap
8/20/2012 - 186510 miles
Cooper Discoverer STT 285/75R16 Tires
9/1/2012 - 186650 miles
Spidertrax 1.25" Wheel Spacers
Rear Differential Drain/Fill
Rear Driveshaft Swap
Re-Torque
9/8/2012 - 186700 miles
Seafoam TransTune
10/1/2012 - 186888 miles
Winterization
Engine Oil Change
Transmission Fluid Change
Transmission R/Band Adjustment
Muffler Crack Repair
10/3/2012 - 186709 miles
Transmission TV Cable Adjustment
10/5/2012 - 186709 miles
4.0L Disassembly
10/13/2012 - 187011 miles
Engine Oil Change (Due to Oil Filter Gasket Failure)
10/21/2012 - 187072 miles
Front Bumper + Winch
10/27/2012 - 187118 miles
Engine / Transfer Case / Fuel Tank Skid Plates
10/28/2012 - 187124 miles
Tip Over
11/04/2012 - 187176 miles
Coolant Flush
Thermostat Replacement
Window Repair
11/05/2012 - 187178 miles
Window Repair
HID Lights
11/09/2012
CB Radio
Dimmer Switch Repair
11/10/2012
1" Additional Front Coil Spacers
FUTURE PROJECTS
(non-prioritized)
- Install Hi-Lift Jack Mount
- Install Dual Battery Setup
- Replace Brake Rotors / Calipers
WISHLIST
- Roof Rack
- Spare Tire Carrier
- Autostart
- Air Locker
MAINTENANCE
- Head Gasket Repair
- Plenum Gasket Repair
- Dash Vent Repair
- Drag Link Adjustment
- Interior Lights Repair
- Heated Seats Repair
INDEX
18JUN2012 - First Ride
30JUN2012 - Camping Trip
05AUG2012 - 4" Lift
19AUG2012 - Xfer Case Swap + Misc
20AUG2012 - 33" Tires
25AUG2012 - Before/After Comparison
01SEP2012 - Spidertrax Wheel Spacers Installation
01SEP2012 - Rear Driveshaft/Differential Work
01SEP2012 - Random Musings
05OCT2012 - Round One
06OCT2012 - Round Two
13OCT2012 - Round Three
21OCT2012 - Front Bumper + Winch
27OCT2012 - Skid Plates
28OCT2012 - ROLLOVER!
01NOV2012 - Body Repair
04NOV2012 - Coolant Flush / Thermostat Replacement / Window Repair
05NOV2012 - Window Repair Continued / HID Lights
09NOV2012 - Heated Seats / CB Radio / Dimmer Switch
10NOV2012 - Coil Spacer Stack
iser 08-05-2012 11:29 PM
Bought the ZJ about a week before this. The weather was nice, so I took it out for a ride. Upto this point, the ZJ was going to be my disposable ride. I am leaving Alaska in a year so I wanted a throwaway vehicle. But, I had so much fun off-roading that day that I got hooked and decided to keep it.
http://img29.imageshack.us/img29/2182/p1010043zy.jpg
http://img820.imageshack.us/img820/7991/p1010039fk.jpg
http://img577.imageshack.us/img577/1163/p1010031xt.jpg
http://img29.imageshack.us/img29/1497/p1010030on.jpg
the problem is that i ended up flooding it. and i guess the previous owner had a cat. the smell didn't come out until things got wet. then the entire jeep smelled like cat piss so i had to rip everything out.
http://img135.imageshack.us/img135/4025/p1010052o.jpg
iser 08-05-2012 11:31 PM
At about 10pm one night, I was bored. So I packed my things and went camping. I find a cool spot but eventually I couldn't go any further and turned around. I vowed to lift my jeep asap. Found a nice spot by the river, started fire and read for awhile. It was a nice relaxing night.
http://img824.imageshack.us/img824/2115/p1010056ok.jpg
http://img850.imageshack.us/img850/7231/p1010058yf.jpg
http://img853.imageshack.us/img853/1451/p1010062n.jpg
Everything was fun and I had a great time, until the ride back. There was a leak in the differential, and I drove it dry for about 50-60 miles at highway speed. Not good. My differential got grenaded so i had to pull an axle from a junkyard.
http://img43.imageshack.us/img43/2668/p1010082tdc.jpg
iser 08-05-2012 11:34 PM
5AUG2012 - Lift
i didn't bring the camera the first day, so i didn't get any 'before' pictures in.
http://img35.imageshack.us/img35/6985/p1010093ox.jpg
http://img836.imageshack.us/img836/6499/p1010091p.jpg
http://img811.imageshack.us/img811/32/p1010088j.jpg
http://img846.imageshack.us/img846/2255/p1010095c.jpg
http://img444.imageshack.us/img444/4365/p1010096j.jpg
also, new tires coming soon!!!
WhiteOut 08-05-2012 11:41 PM
Looks good, now that I see it I would grab a set of 1.25" Spidertrax spacers and run JK Rubi takeoffs on it.
IMO it would be a perfect fit and look.
Canyon411 08-05-2012 11:49 PM
Did you power wash your carpets (I assume you knew what urinefor) or did you buy a new carpet kit from somewhere? How did things end up?
iser 08-06-2012 12:07 AM
how are spacers for off-roading? someone was telling me that it adds additional point of failure and it's just better to get new wheels.
also, i took it by the hose and got on my hands and knees with a scrub brush and carpet soap. scrub and rinse and repeat several times. got the smell out. and i actually got to learn a lot about the wiring under the carpet. also took the opportunity to paint the center console and it turned out better than i expected.
WhiteOut 08-06-2012 12:09 AM
Properly torqued with lock-tite, they are 100% fine. No more stress than a wheel with more backspacing. I ran mine for about 20k or so and no issues.
iser 08-19-2012 10:44 PM
19AUG2012 - XFER CASE SWAP + MISC WORK
finally swapped my 249 with 242 today!
http://img585.imageshack.us/img585/2515/p1010115lk.jpg
http://img688.imageshack.us/img688/5427/p1010121xy.jpg
http://img854.imageshack.us/img854/7168/p1010117ey.jpg
http://img42.imageshack.us/img42/4928/p1010118xj.jpg
then i decided to trim my fenders a little bit to get ready for my 33"
http://img835.imageshack.us/img835/9554/p1010123j.jpg
http://img38.imageshack.us/img38/5428/p1010125nz.jpg
http://img651.imageshack.us/img651/8057/p1010126tr.jpg
http://img805.imageshack.us/img805/9512/p1010130d.jpg
http://img846.imageshack.us/img846/5876/p1010132a.jpg
http://img163.imageshack.us/img163/7849/p1010131du.jpg
Kevinyj95 08-20-2012 09:05 AM
Looks good cant wait to see the 33s on there.
iser 08-20-2012 09:55 AM
picking them up as soon as the i receive the wheel spacers from kolak. hopefully that will be thu/fri.
HighLonesome 08-20-2012 10:00 AM
You're gonna love the Coopers.
Mine are in there 3rd year, finally showing some wear and making a bit of noise on the freeway.
Myusername1674 08-20-2012 10:19 AM
Lookin good man! I myself LOVE black Zj's, and black vehicles in general, just flat out the best imo. Have any more pics of your fender trimming? I need to do some so that When i flex out my suspension my sidewalls don't rub on any jagged edge.
Montaska 08-20-2012 11:35 AM
Awesome looking Jeep! Are you at Wainwright?
iser 08-20-2012 12:06 PM
yep on FWA. i'm with 1-24in.
The time now is 02:47 PM.
