Jeep Enthusiast Forums banner
Iser's Build Thread
40K views 186 replies 44 participants last post by  Myusername1674
#1 ·
CURRENT SPECIFICATION
Engine: 5.2L V8
Front Axle: D30
Rear Axle: D44a
Gear Ratio: 3.73
Transfer Case: NV242
Transmission: 44RE
Lift: Zone Offroad 4" Kit
Tire: Cooper Discoverer STT - 285/75R16
Armor: Factory Skid Plates
Bumper: Protofab Front Bumper
Recovery: Tabor 12k Winch / Hi-Lift Jack
VEHICLE LOG
6/8/2012 - 185760 miles
Vehicle Registration
Battery Purchase
6/16/2012 - 185820 miles
F/Passenger CV Axle Swap
Fuel Pump Swap
7/7/2012 - 186080 miles
Front Axle Swap
Front Differential Drain/Fill
7/14/2012 - 186160 miles
Transmission Fluid Drain/Fill
Engine Oil Drain/Fill
8/5/2012 - 186320 miles
Zone Offroad 4" Lift Kit
8/19/2012 - 186490 miles
NV242 Transfer Case Swap
Front Driveshaft Swap
8/20/2012 - 186510 miles
Cooper Discoverer STT 285/75R16 Tires
9/1/2012 - 186650 miles
Spidertrax 1.25" Wheel Spacers
Rear Differential Drain/Fill
Rear Driveshaft Swap
Re-Torque
9/8/2012 - 186700 miles
Seafoam TransTune
10/1/2012 - 186888 miles
Winterization
Engine Oil Change
Transmission Fluid Change
Transmission R/Band Adjustment
Muffler Crack Repair
10/3/2012 - 186709 miles
Transmission TV Cable Adjustment
10/5/2012 - 186709 miles
4.0L Disassembly
10/13/2012 - 187011 miles
Engine Oil Change (Due to Oil Filter Gasket Failure)
10/21/2012 - 187072 miles
Front Bumper + Winch
10/27/2012 - 187118 miles
Engine / Transfer Case / Fuel Tank Skid Plates
10/28/2012 - 187124 miles
Tip Over
11/04/2012 - 187176 miles
Coolant Flush
Thermostat Replacement
Window Repair
11/05/2012 - 187178 miles
Window Repair
HID Lights
11/09/2012
CB Radio
Dimmer Switch Repair
11/10/2012
1" Additional Front Coil Spacers
FUTURE PROJECTS
(non-prioritized)
- Install Hi-Lift Jack Mount
- Install Dual Battery Setup
- Replace Brake Rotors / Calipers
WISHLIST
- Roof Rack
- Spare Tire Carrier
- Autostart
- Air Locker
MAINTENANCE
- Head Gasket Repair
- Plenum Gasket Repair
- Dash Vent Repair
- Drag Link Adjustment
- Interior Lights Repair
- Heated Seats Repair
INDEX
18JUN2012 - First Ride
30JUN2012 - Camping Trip
05AUG2012 - 4" Lift
19AUG2012 - Xfer Case Swap + Misc
20AUG2012 - 33" Tires
25AUG2012 - Before/After Comparison
01SEP2012 - Spidertrax Wheel Spacers Installation
01SEP2012 - Rear Driveshaft/Differential Work
01SEP2012 - Random Musings
05OCT2012 - Round One
06OCT2012 - Round Two
13OCT2012 - Round Three
21OCT2012 - Front Bumper + Winch
27OCT2012 - Skid Plates
28OCT2012 - ROLLOVER!
01NOV2012 - Body Repair
04NOV2012 - Coolant Flush / Thermostat Replacement / Window Repair
05NOV2012 - Window Repair Continued / HID Lights
09NOV2012 - Heated Seats / CB Radio / Dimmer Switch
10NOV2012 - Coil Spacer Stack
See less See more
2
#174 ·
Five miles down the highway in first gear, bent a rod and cooked the tranny.
#175 ·
oh man, i would be sooooooo p*ssed off. i would have had him buy me a new one.
#176 ·
Really, jet chip ...like a fat bobs budget boost
#182 ·
the weather is finally getting really nice in alaska. kinda in a financial bind right now, but as soon as i can afford to, i'm gonna work on swapping my front axle AGAIN (diff seized up which led to my t-case cracking). i'll make sure to make a full-blown tutorial thread for swapping an axle when i work on it.
found a guy on my post who has a lifted xj (he has a really nice build. as soon as i saw his xj, i knew he and i would have a loooooot to talk about). we hit it off well right away. we are gonna be exploring alaska together in the summer. so excited!
heh, thanks. i haven't worked on my jeep in the past 6 months or so since the alaskan winter hit. it should warm up significantly here in the next month or so. can't wait till i continue this thread. it's like looking at a baby photo album, lol.
Since you did so good on your flop damage maybe ill send my wife's up to you. Lol
dude, no ****, you can easily straighten that out with a hilift jack since it seems like it only has one spot that it got crushed. straightening out will be easy. but replacing the glass will be where you will have to fork over some money. i don't think you want to lexan the front windshield.
#184 ·
hello jf! the dark long winter of alaska is gone and the beautiful summer is here now, and i am back to making love to my zj again! here are some updates:
1) next to my barracks, there is a service road that has been flooded. people don't realize how deep it is and drive through it, wanting to get a little dirty. well, let's just say that i pulled out 8x various vehicles in the past two weeks (including a full-sized van, lol). i saved the day for the many and every time, they can't stop rambling about how thankful they are and how awesome my jeep is.
2) man, my zj looks sexy covered in mud.
3) so my jeep has gone through some pretty terrible luck this winter and it was quite a struggle. but i persevered. it is in a good running condition. my front diff is still seized up so it's only in rwd. i really need to put in a new front axle so i can fully explore alaska this summer. i am on the lookout for HP30. and when i swap my axle, i will make sure i make a full blown tutorial thread.
4) my cv axle shaft broke AGAIN. this is my third cv in a year. i am done with cv; i will be using u-joint axles. i will probably swap it out tomorrow.
5) so i never got my wheels aligned after lifting it, putting the tires on and most importantly, stacking spacers. it drove like garbage for about two months or so. i guess everything settled and it just aligned itself. drives great now. lol. who said not to stack spacers? lies! vicious lies!
6) did i mention that my jeep looks sexy covered in mud? yes. yes i did.
#186 ·
replaced the cv axle shaft with u-joint axle shaft
lol. look how completely shredded the cv-joint is. i don't even have balls in there anymore.
u-joint axle shaft in. hopefully, these will last me longer than cv. took me about 30 minutes total while bs-ing around with some friends that stopped by to check out what i'm doing. after i started working, 5-6 other guys crawled out of the barracks to work on their cars also. put some music on and we had a lot of fun helping each other with vehicles.
Top
