Quantcast Ironrock vs Clayton - JeepForum.com
jeeppartsdept.com
Get your jeep parts here. Full line Jeep dealer. HUGE DISCOUNTS!
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Ironrock vs Clayton
TJ WW2WW rockers on sale with free gaskets this month.DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-JcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!
Old 12-09-2008, 02:18 PM   #1
Jones
Infowars.com
Jones's Avatar
Ironrock vs Clayton
Ok, I'm buying my long arms after my next pay check but I still don't know which one to get. I know the IRO will be cheaper then Claytons but I want the best. I have been wondering for a long time why Clayton uses square long arms, is this better? I also noticed that the IRO arms go straight back then bend to go around the old short arm brackets. I am a noob when it comes to long arms so can someone please give me some insight on the two brands and guide me to the right decision. Thank you!
What is it about Ron Paul?
Jones is online now   Reply With Quote
Old 12-09-2008, 02:23 PM   #2
-Shoey-
On Mallcrawlin they're heavy advocates of Claytons. They just seem alot beefier than IRO's.
2002 Grand Cherokee Limited
2004 Chevrolet Tahoe Z71
USN Jeep Club #115
-Shoey- is offline   Reply With Quote
Old 12-09-2008, 02:25 PM   #3
QuadraTokn
1930 WJ
The squre tubing is stronger. But IRO warranties and it would take a whole lot to bend one anyway. There is also much better pinion adjustability with claytons.
How much more can you get the claytons for?
I have a modified 1999 WJ and a stock 2001 WJ
Tread Lightly
Pictures
PARTED OUT 8 WJ Grand Cherokees ! ! ! ! ! !
QuadraTokn is offline   Reply With Quote
Old 12-09-2008, 02:30 PM   #4
WJChris
If you are planning on cutting out the factory control arm mounts then get the high clearance long arms.
WJChris is offline   Reply With Quote
Old 12-09-2008, 02:35 PM   #5
CLNinja
whats the warranty on IRO arms?
[color="#003300"]Matt[/COLOR]
[color="white"][CENTER][size="1"]
[url="http://www.jeepforum.com/forum/showthread.php?t=434081"][color="white"]Click Here For My Build Thread[/COLOR][/url]
[/COLOR][/SIZE][B]**September 2009 Grand Cherokee Of The Month**[/B]
[SIZE="2"][url="http://www.jeepforum.com/forum/forumdisplay.php?f=123"][color="white"]Colorado Jeep Club Member #88[/COLOR][/url][/SIZE][/CENTER]
CLNinja is offline   Reply With Quote
Old 12-09-2008, 02:40 PM   #6
Jones
Infowars.com
Jones's Avatar
I got a quote from IRO and Fullsizexj and I'm going to get a quote from KOR as well because I like to deal local. The Clayton shipped free for $200 more.
Old 12-09-2008, 02:40 PM   #7
QuadraTokn
1930 WJ
http://ironrockoffroad.com/IRORguarantee.html
Tread Lightly
Pictures
Old 12-09-2008, 02:42 PM   #8
QuadraTokn
1930 WJ
I would spend $200 more for Claytons for sure.
Tread Lightly
Pictures
Old 12-09-2008, 02:42 PM   #9
Jones
Infowars.com
Jones's Avatar
Does the High clearance long arms for IRO go around the old brackets? I am planning on cutting the old brackets off.
Old 12-09-2008, 02:45 PM   #10
QuadraTokn
1930 WJ
The HC arms will mash the stock CA brackets when flexing. Thats why you cut them off. So you need to get the HC ones.
Tread Lightly
Pictures
Old 12-09-2008, 02:59 PM   #11
skain8
Clayton's actually offers a better warranty that IRO, as it covers failures of the arms, if any, from abuse, not just warranty against manufacturer defect.
'02 WJ: 4.7L, 5", 231HD w/SYE, 35's, Clayton's, locked, chopped & armor
'06 XK: 65th Anniversary Edition
'98 XJ: Stolen
www.endlessmtnfab.com
skain8 is offline   Reply With Quote
Old 12-09-2008, 03:06 PM   #12
QuadraTokn
1930 WJ
ok well Claytons FTW in that case. I would have bought them if i didnt get this kit (used) for $900: http://www.ironrockoffroad.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=IROR&Product_C ode=IR-W_6LK&Category_Code=PFW
Tread Lightly
Pictures
Old 12-09-2008, 03:29 PM   #13
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
Claytons is beefier and includes a subframe (two big perks IMHO) - also more pinion adjustability.
Claytons requires welding to the unibody and cutting off of the LCA mounts.
IRO is bolt on and can either have the high clearence or low clearence.
IRO has less adjustability and isn't as strong.
To me, if you don't mind cutting off the LCA brackets, get Claytons. If you want to ever return to stock, get IRO.
I have Claytons and am very happy with it.
Square tubing is better for lateral hits such as those that you'll see when dropping off of ledges onto the control arms. Round tubing looses all of its strength the second it is dented. But denting it is hard to do...they are much more likely to bend.
ArloGuthroJeep is offline   Reply With Quote
Old 12-09-2008, 03:46 PM   #14
Jones
Infowars.com
Jones's Avatar
This will never go back to stock as long as I own it. Cutting parts off and welding is not a problem. Really my only concern was the square arms because I have always seen round tubing.
Old 12-09-2008, 03:47 PM   #15
QuadraTokn
1930 WJ
Then Claytons are for you.
Tread Lightly
Pictures
Glock Forum
