Iron Rock OTK steering questions - JeepForum.com
post #1 of 9 Old 05-24-2011, 11:05 PM Thread Starter
Redfire03
Hey guys,
The steering on my Jeep needs to be tightened up and I am trying to explorer all my options. Right now my Jeep has a 3.5'' lift, 32'' tires, adjustable control arms and track bars. My Jeep is my daily driver, so I still want to keep it quite as in no popping or clanking.
I am either thinking about just getting new tie rods, etc. or upgrading to the heavy duty OTK setup from Iron Rock.
If you have had some personal experience with the OTK steering can you please share it. Does it make any odd noised (popping, squeaking, clanking?), did it tighten up the steering, how durable has it been, any maintenance required with it?
Thanks,
Joe
Redfire03 is offline
post #2 of 9 Old 05-24-2011, 11:09 PM
freakinheep89
You dont have enough lift to warrant running the OTK setup, IMO.
Look into currie, they have HD steering setups that dont require much, if any, modification. Also a KOR steering box brace would help greatly.
TJ-
95 ZJ 5.2- D30/XJ shafts/D35 Yukon alloys,249, 2"BB, 30x9.5"Wildcat EXT,lots of motor mods, rancho shocks & stabilizer.
Originally Posted by slayercr23 View Post
How would i go about Stroking it?
freakinheep89 is offline
post #3 of 9 Old 05-24-2011, 11:25 PM Thread Starter
Redfire03
post #4 of 9 Old 05-24-2011, 11:34 PM
lateralus3
1994 ZJ
yes like that and x2 on the steering box brace
Jacob
1994 grand cherokee laredo 4.0 IRO 5.5 critical path long arm kit and OTK steering 35x12.50x15 BFG KM2's
high pinion dana 30 and 8.8 in garage
FOR SALE ONE SET OF ZJ D44A AXLE SHAFTS $150 SHIPPED
lateralus3 is offline
post #5 of 9 Old 05-24-2011, 11:51 PM
dlvsdh
x3 on the brace and currie or iro
95, ZJ, ORVIS, 1 tons, 37's etc.
2002, WJ, overland, daily driver
dlvsdh is offline
post #6 of 9 Old 05-25-2011, 12:20 AM
lateralus3
1994 ZJ
looking at ironrocks site it doesnt say anything about a minimum amount of lift, it just say it will not work with stock backspacing
edit:Biggoofy is at 3.5 and 33s and is running the IRO OTK steering
Jacob
post #7 of 9 Old 05-25-2011, 12:35 AM
ZJ5point2GCL
i don't see why lift height would really matter, its a great set up, the steering is really tight, and its nice not having the toe change every bump i hit.
it does like to squeak really bad after driving long distances in the rain or really wet wheeling, but a couple shots of penetrating lube fixes it right away.
I would also recommend getting a steering box brace. It tightens everything up really nice.
Its a great set up, just make sure you can run heims/ don't have inspections where you live.
98 Deep Slate Niner- 6''s on 35's ---11 F150 Platinum Pearl White- Modded Tiny V6 with Two Turbos. ---93 Black 5.2 limited- Slowly dying in my Parents Driveway
ZJ5point2GCL is offline
post #8 of 9 Old 05-25-2011, 12:14 PM
freakinheep89
I was under the impression from a local off road shop that you needed to be at a decent lift height for your steering geometry to stay correct, but i stand corrected.
TJ-
post #9 of 9 Old 05-25-2011, 12:25 PM
ZJ5point2GCL
for steering geometry it would be dependant on your track bar drop, as the track bar and drag link should be parallel.
iron rock Iron Y lateralus3 ZJ Grand Cherokee Forum 5 05-02-2011 07:57 AM
Installed Iron Rock ZJ OTK steering, drag link making loud noise? 1sportsdoc ZJ Grand Cherokee Forum 19 04-29-2010 02:48 PM
Iron Rock :-) yasika116 ZJ Grand Cherokee Forum 10 08-17-2009 05:19 PM
Iron Rock Offroad 6" lift questions SSnipes ZJ Grand Cherokee Forum 34 04-02-2009 10:04 AM
iron rock lift questions nuey302 ZJ Grand Cherokee Forum 15 11-16-2008 05:50 PM
