IRO rear track bar drop bracket questions - JeepForum.com
post #1 of 9 Old 10-27-2011, 06:18 PM Thread Starter
nicklopic
So I'm planning on doing a 3.5 inch lift from iron rock probably just the foundation kit with a front adjustable track bar to center the front axle BUT I'm on a budget so I'm wondering about there rear drop bracket.
1. How it mounts. (it looks like it just bolts up)
2. Can i get away with this, just for a little, until i can get an adjustable rear?
(I will be looking in the classifieds here to see if i can find the adjustable bars here and not only save myself money. Also I'd rather not have to use a sort of rigged up method but the use of the bracket would only be temporary.)
Bracket: http://www.ironrockoffroad.com/Merch...egory_Code=PFZ
98' ZJ 4.0
4.5" short arm, 33" Courser MXTs, custom stubby bumper, skids, someother stuff
nicklopic is offline
post #2 of 9 Old 10-27-2011, 06:21 PM
PolkaPower
You can use it for a bit. I wouldn't rely on it for wheeling or indefinitely. I have seen pics of them sheered and ripped off.
PolkaPower is online now
post #3 of 9 Old 10-27-2011, 06:23 PM Thread Starter
nicklopic
i searched a little and saw ppl and mixed thoughts about them
id probably only use it for a month or two max though
98' ZJ 4.0
post #4 of 9 Old 10-27-2011, 06:23 PM
Freestyle713
1994 ZJ
the double sheer that comes with the benchmark is better than the adjustable in the front
Freestyle713 is offline
post #5 of 9 Old 10-27-2011, 06:38 PM
Technohead
The drop bracket is actually better than adjustable track bar from the perspective of maintaining factory roll center. Problem is that unless you weld them on and reinforce the nearby unibody structure then they fail.
On road, you can get away with the bolt-on bracket indefinitely. Off-road you need to weld it or go with adjustable track bar.
-Eric
Technohead is offline
post #6 of 9 Old 01-06-2012, 08:36 AM
Myusername1674
Sorta bringing this thread back after i just found it, but I'm looking at getting the 3.5 benchmark lift, and I thought I'd ask this, i plan to add the rear track bar:
http://www.ironrockoffroad.com/Merch...egory_Code=ZSC
It says you can get it as an adjustable track bar so that if i lift more later i won't need to buy a new one, does this weaken its strength? Because I would guess that it would.
Thanks, if anyone see's this it may be to old.
Myusername1674 is offline
post #7 of 9 Old 01-06-2012, 08:42 AM
PolkaPower
Adjustable track bars are fine as long as they are not Rusty's. Then they break apart and almost kill you. IRO is beefy and a solid product. You are going to need adj track bars front and rear to center your axles.
post #8 of 9 Old 01-09-2012, 08:24 AM
Myusername1674
Cool, i knew i'd have to be getting them, just wasn't sure what type, also i've been searching around and i found an Old Man Emu lift, wondering if its as good as they're trying to make it out to be, or if its all just marketing....
http://www.rocky-road.com/zjtrailblazer.html
post #9 of 9 Old 01-09-2012, 10:20 AM
biggoofy
I welded on a track bar bracket to my 44a and used it for 2 wheeling trips and it held up fine. I would definitely weld it though.
Zack
13 JKU Stock
93 ZJ F/R Long Arms, 4.56 gears
96 ZJ HP44 / 9" (RIP)
biggoofy is offline
iron , relocation bracket , rock , track bar
Track bar drop bracket for WJ jopolly3 ZJ Grand Cherokee Forum 12 07-27-2012 11:20 AM
coil rubbing on track bar drop bracket bigbluezj94 ZJ Grand Cherokee Forum 3 10-06-2008 06:59 AM
rear track bar bracket help crazydude2500 ZJ Grand Cherokee Forum 7 06-13-2008 10:34 AM
Well I used a tb drop bracket on the rear. BAD idea! bjl95mustang ZJ Grand Cherokee Forum 7 11-12-2007 10:43 AM
drop track bar bracket necessary? Casper4x4 ZJ Grand Cherokee Forum 39 10-24-2007 04:21 PM
