IRO double shear track bar kit - JeepForum.com
post #1 of 7 Old 08-09-2011, 03:11 PM Thread Starter
ilive4cars0122
Is anyone running the Iron Rock Offroad double shear track bar for 1"-5" lift? I ask because the installation instructions do not say a recommended length to have it adjusted to for anything below a 3.5" lift. Before buying it I also want to know if the 1"-5" bar will work for me because the instructions also say you need at least one inch of thread engagement. If the bar is only 33 3/4" center to center and the recommended length for a 3.5" lift is 33 5/8" center to center, doesn't that only leave 1/8" thread engagement? I contacted the company but failed to ask these questions and now they are closed. I am in desperate need of a track bar and wanted to bite the bullet and get the upgraded one now. Any help is appreciated Thanks
ilive4cars0122 is offline
post #2 of 7 Old 08-09-2011, 05:36 PM
ravinsaend
I don't have an answer but I do have a question so thought I'd add it as I hate making new threads for everything i read and find questions about(would be an awful lot of threads if I did that)
I've seen all sorts of threads about track bars but have yet to find this answer: What is the difference between a regular adjustable track bar and the double shear track bar?(<--I have no idea what that means)
ravinsaend is offline
post #3 of 7 Old 08-09-2011, 05:57 PM
melk
Double shear refers to the mounting bracket. It passes through two mounting holes and is much stronger than just 1 mount point.
melk is offline
post #4 of 7 Old 08-10-2011, 06:45 AM
speedbucket
double shear has a rubber bushing (like you have on your axle side) on both ends with a new frame bracket
V8 zj at 6" . Double tri rear and true 3 link front. Stretched to 108"
speedbucket is offline
post #5 of 7 Old 08-10-2011, 08:02 AM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
I'm almost certain you'll be fine with it at 3.5"
HighLonesome is offline
post #6 of 7 Old 08-10-2011, 10:51 AM
AlphaLorde
I have both of their tbars.
@ 3.5" you will have about 1-1.5" or so of the threads showing w/ most of the threads inside of the tbar.
Could always call em today
1998 ZJ Laredo 5.2L 139k 231 w/SYE artec trussed 8.8 4.25"F/5"R lift
AlphaLorde is offline
post #7 of 7 Old 08-11-2011, 03:35 PM
AlphaLorde
I love their shop and the customer service!!!
IRO double shear or tie rod track bar? SUfan ZJ Grand Cherokee Forum 12 02-16-2011 01:47 AM
IRO Double Shear Track Bar Questions ZJ5point2GCL ZJ Grand Cherokee Forum 1 06-08-2010 10:41 PM
double shear upgrade 96liftedzj ZJ Grand Cherokee Forum 1 03-07-2010 10:43 PM
JKS adjustable front trackbar or IRO Double shear conversion kit? Travis873o ZJ Grand Cherokee Forum 3 08-26-2009 10:51 AM
WJ caster with front double double cardan DS doublejz ZJ Grand Cherokee Forum 3 07-30-2009 10:48 AM
