IRO 5.5 inch kit - Page 2 - JeepForum.com
post #16 of 21 Old 07-19-2011, 01:25 PM
squazz
Originally Posted by 98gczj View Post
What do u mean upgrade your steering what did u have to do ?
Well in the instructions it says to bend 5 angel in the draglink well tye shop ****ed that up so I ended up going with IRO's heavy duty steering (with heims). Then I blew 2 durango steering boxes so now I added steering stops and installed a grand wagoneer box with a steering box brace form fortcollinszj.
squazz is offline
post #17 of 21 Old 07-19-2011, 01:45 PM
biebs53
I'm running this suspension on my 5.9 but i had them swap in 4.5" coils. Mine is all adjustable and I got JKS disconnects and ordered bilsteins from another vendor. Very happy with it. Just make sure everything is tight. I was getting a noise when I turn and the front frame side track bar bolt wasn't tight. I had a clunk on the left front when hitting bumps and my coil spring was catching on the bumpstop extension so I grinded that down and it's all good. Also, I installed it with the TCase drop and that popped out my transfer case linkage. It was making noise too. Eliminated the TCase drop and popped the bushing back.in and no more noise and I got 4Lo back. And my exhaust was clanking against the new crossmember. Cut and welded the hanger and it's all good now.
The 3-link front long arm is my favorite. Offers massive flex with no chance of binding. I would definitely do it again and I plan to do a triangulated 4-link in the rear. The ride is very good. Got no vibes or noises (after I fixed the small problems) and best of all, no death wobble. Very easy install except for the steering. I would buy OTK if that's possible. Stock steering will work but mine still contacts the sway bar link on pass side but it's not a big deal. Took a couple days to get the steering to work tho, that doesnt happen in most cases tho.
Let me know if u have any questions or see my build thread. Good luck.
1998 Jeep Grand Cherokee 5.9 Limited
Build thread:
biebs53 is offline
post #18 of 21 Old 07-19-2011, 03:46 PM
-HH-Racer
Say if you order the kit with no shocks right, beacause you are planning on buying foxracing/king shocks, how would you know how much travel to get in the schocks, is it like 12" in the front? And im planning on running the rear shocks through the body for more travle, so im
Thinking 16" in the rear, does that sound right?
-HH-Racer is offline
post #19 of 21 Old 07-19-2011, 04:00 PM
biebs53
Talk to cAcHe about that, he runs kings and has em thru the rear. I have bilsteins for a 6" lift for a little extra downtravel. Mine are 12" travel up front. Not sure about the rear cuz they're a little shorter, probably about the same tho.
Build thread:
biebs53 is offline
post #20 of 21 Old 07-19-2011, 04:22 PM
-HH-Racer
Yeah i love his set up, im plannin on getting that iro 5.5 kit, i might just get the bilsteins
post #21 of 21 Old 07-19-2011, 04:24 PM
biebs53
I'm very happy with the bilsteins. Coilovers would be nice tho with a triple bypass up front
Build thread:
biebs53 is offline
Torn between 4 inch and 4.5 inch lift for my ZJ givemeazj ZJ Grand Cherokee Forum 21 08-07-2011 09:42 PM
4 inch springs on a 3 inch lift?? zj333 ZJ Grand Cherokee Forum 8 12-20-2009 05:02 PM
3 inch lift.. 1 inch bb? coopdc78 ZJ Grand Cherokee Forum 8 11-09-2009 07:03 PM
11.5 inch tire on 7 inch rim trailblazr81 ZJ Grand Cherokee Forum 5 01-15-2009 02:09 AM
2 Inch lift vs. 2 Inch Spacers jeep_05 WK Grand Cherokee & XK Commander Forum 19 06-06-2008 01:57 PM
