IRO 5.5 crit path installed, have a new weird vibration.. - JeepForum.com
post #1 of 6 Old 04-23-2016, 12:26 AM Thread Starter
meximan
Ok...I have a new issue....AT IDLE and in gear driving i get a weird vibration from which feels like the transfer case forward.
I removed the transfer case and replaced the input and output seals....however prior to doing that i still had these similiar issues...
It almost sounds like a slight knocking sound, i can feel it in the pedal....you would think it would be rotational noise when you hear it at idle...almost like the driveshaft went out...however,....thats clearly not the issue at idle.
Any ideas??
97 5.2 limited
meximan is offline
post #2 of 6 Old 04-23-2016, 03:11 AM
PolkaPower
Any ideas??
97 5.2 limited
If it's at idle then you can eliminate drive train parts since they are not moving.
Does it also make it in neutral?
How are your motor mounts and transmission mount?
PolkaPower is offline
post #3 of 6 Old 04-23-2016, 05:44 AM
98318242
Pull the front shaft and drive it see if it makes a difference.
98318242 is offline
post #4 of 6 Old 04-23-2016, 06:54 AM
PolkaPower
How would the drive shaft cause a vibe at idle?
post #5 of 6 Old 04-24-2016, 11:42 AM Thread Starter
meximan
motor and trans mounts are new.
almost sounds like its coming from down by the transfer case, but like you said...drivetrain parts arent moving at a stop.
meximan is offline
post #6 of 6 Old 04-25-2016, 04:29 AM
PolkaPower
Rev it up in neutral. If the noise is gone then you can assume it's only under load and further narrow it down.
