IRO 4" Adj Long Arms Installed
#46 | |
SandSurfer
forced retirement I walk the park for exercise, the views are better than the neiborhood
![]() My right leg being paralyzed gets me on the rides without waiting in line BTW live life to the fullest, never know when a drunk drive in a dump truck will not see ya on a motorcycle ![]()
2004 Overland 4" KOR/IRO Long Arms 2004 Rubicon 6.5" RK X-Factor LA on 35" KM2s 488s Tom Woods & plenty of BTF Armor ORO U-Turn system 1995 Jeep Orvis 4.0 3" Rancho www.jeeporvis.com ... www.jeepartist.com ... www.kmaoffroad.org Virginia Beach ... www.obxbreakers.comOff season Jeeper Deals
#47 |
Where are the flex shots Kevin ?
I put my rear diff back together last night just gotta put gear oil in then I'll will flex the **** out of mine ![]()
Nickerdoodle 03 WJ 4.7 242HD Kolak/IRO 5" Clayton LA's 35" BFGoodrich KM2 sira4x4.net North East Offroad Club www.carolinadriveline.com www.ironrockoffroad.com kolak@aol.com |
#48 | |
SandSurfer
Do you have tourqe specs for the a-arm spacers??? maybe some flexer tomorrow!!
#49 |
I got my last two packages today. After laying everything out to check and see if it was there, I began the install.
I had everything prepped, and the first LCA bracket on while drilling the holes, when some wierd chit happened. I had this MASSIVE alergic reaction to something on the ground of my garage and my back broke out into HUGE hives. I had to send the GF to get benadryl and ended up takin a shower. Needless to say, that was as far as I got with the install tonight. Looks like I'll be finishing up tamorow.
Jay '94 YJ Sahara D44s F&R SOA 35''s BFG MTs 1-Ton HiSteer 4.7HO Limited WJ 4.5'' Clayton's 32''s For Sale |
#50 |
SandSurfer
that sucks, most I has was big freaking ANTS crawling all over my legs!!
RAID to the rescue Good luck man BTW what size wrench fits the big nuts on the LAs???
#51 |
I think I remember 21mm or 7/8'' I could be wrong though. Why?
BTW, whats the easiest method for adjusting your pinion angle?
#52 |
I use a jack on the bottom of the diff towards the pinion, but be careful doing that...I just use it to push it more towards the position desired..
But I left the LCA's bolted in place and did it on level ground.
#53 |
Theres no chance of the springs poppin out when doing it like that? Cause there is no UCA bolted on.
#54 | |
To change from the 2 setting to the 1 you're gonna have to put it on stands and let it droop. I was just adjusting the caster thingy majiggy on the back when I did that.
#55 |
Ah, I see. OK, Well I'm back to the alignment shop then. They kinda messed it up when they did it yesterday so I'm goin back to get it fixed. I'm gonna ask the guy if I can stay and watch, maybe I'll learn somethin.
Be back with reports after lunch and an alignment.
#56 |
They adjust the UCA????
#57 |
SandSurfer
Had mine alligned yesterday went fine, left it over night had them re torque and do the trans service and IAC moter.
Nick do you think an adj to the castor thing a magigeee would help with the vibes at 25mph?
#58 | |
#59 |
SandSurfer
Thanks guy, btw drink more coffee
and Im getting my replacement tires today![]() Been thinking hard on GY MTRs and Blains wheels
#60 | |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
