IRO 4.5 Guys - JeepForum.com
post #1 of 10 Old 11-23-2008, 10:10 PM Thread Starter
MichiganZJ
IRO 4.5 Guys
I put a set of front and rear IRO springs under my ZJ. I measured before and after the lift to discover I gained 6.25" of lift. All measurements were taken with the same wheels and tires on. I did a search and found there were a few others that stated the IRO springs yield a little more lift than advertised, but nearly 2"? Could you other IRO 4.5 guys measure from the ground and the hubs to the wheel openings and post your results please. I have my measurements wrote down at work, so I don't know the exact numbers at the moment. I'm just curious as to what everyone else comes up with. I'm not worried at all about the height I got, just wondering what to expect after they settle in.
Thanks.
MichiganZJ is offline
post #2 of 10 Old 11-23-2008, 10:28 PM
10achik
I ate what?
10achik's Avatar
They normally yield an extra 1" or so, but your's sounds like a lot. Could be that since you have the 4.0 you are getting more, because it's lighter. Whatever the height, I can't see them sagging more than 1" over time. Usually when they give a spring height to a spring, it's what they will eventually settle at after weight and wheeling.
Ken
99 GC Limited - 4.7L HO V8, 6.5" IRO HC LA lift, F&R D44s locked & trussed, 242HD, IRO TC Skid, KMA Bumper, 35's
2006 Saturn Redline -2.0L Eaton supercharged I4, GMPP Stage 2, Custom Tune, AEM CAI, Ebiach Pro Kit w/ swaybars, EVO Ventus V12s (13.76 @ 103.85)
2006 Pontiac G6 GTP
2012 Nissan Juke - (hers)
2000 SV650 - naked, integrated tail light, sliders, corbin, pilot roads, RK chain & sprokets, D&D full exhaust, FactoryPro Stage I jet kit, +4 Ignition Advancer, Barnett race clutch
2006 Triumph America 900 - Full Dresser
January 2009 Grand Cherokee of the Month (GCOTM)
10achik is offline
post #3 of 10 Old 11-23-2008, 10:39 PM
ben_wagner
ben_wagner's Avatar
1994 ZJ
I have a 4.0 as well, and my final lift settled to 5 1/8" in the front and 5" in the back.
1994 Grand Cherokee Laredo 4.0 I6 4x4
4.5" IRO, 32" BFG A/T KOs
ben_wagner is offline
post #4 of 10 Old 11-24-2008, 03:31 AM
sandman
they will settle. my RC springs which is what IRO uses were over 6" when i installed them they settled down to about 4-4.5" a few months later.
1993 Jeep ZJ. 4.0
sandman is offline
post #5 of 10 Old 11-24-2008, 05:08 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Yes, you can expect to have your springs settle 1 to 1.5 inches.
Hunter
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #6 of 10 Old 11-24-2008, 08:52 AM Thread Starter
MichiganZJ
Alright, sounds good.
Thanks guys!!!
post #7 of 10 Old 11-24-2008, 11:37 AM
gabrod72
Michigan, are you using adjustable long LCA and UCA or just the stock ones? I'm really interested in adding a bit more lift than my 3" but I'm not ready for the added cost of adjustable LAs. Thoughts?
gabrod72 is offline
post #8 of 10 Old 11-24-2008, 11:41 AM
redhatman
redhatman's Avatar
They will settle. But then again, I am at 3.5" spring plus 2" BB which should be 5.5" lift....yet I am at 6.5"in the front settled and 6" in the rear.
-Pat
I am now a dealer for Iron Rock Off Road
I offer the same great products you already know about,
the same low prices you have been seeing, and with
the same experienced customer support, but I can offer it nearly 24/7
5.9 ZJ 7" IRO, 35s, 8.8, hp30, locked, blah blah
Originally Posted by CMARJEEP View Post
Those tires look freakin awesome Redhat... took the ZJ up a notch in my book. Now you're at notch 2.
redhatman is offline
post #9 of 10 Old 11-25-2008, 02:00 PM Thread Starter
MichiganZJ
I do still have the stock control arms all the way around. I'm gonna add rear lowers first, and then uppers. I can't afford to do them all at once. I'll do the the same to the fronts as money allows. So, I'm on the lookout for some used control arms.
post #10 of 10 Old 11-25-2008, 02:51 PM
MoonyJohn
MoonyJohn's Avatar
so when you adjust your track bar at 6.25" of lift, then when it settles, will you need to re-adjust it then?
MoonyJohn is offline
what do you guys think? zaq123 ZJ Grand Cherokee Forum 5 06-05-2008 11:55 PM
Hey Guys I need a little help... 93JeepGCL ZJ Grand Cherokee Forum 16 05-26-2008 09:47 AM
Hey Guys CNY750Rider ZJ Grand Cherokee Forum 12 11-14-2006 04:54 PM
Ok Guys...you Win nashmd454 ZJ Grand Cherokee Forum 5 04-14-2005 05:03 AM
WJ Guys laxwarriors21 ZJ Grand Cherokee Forum 3 03-15-2005 05:13 AM
