IRO 3" lift measurement needed - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > IRO 3" lift measurement needed
4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE NeededBead Lock Wheels! Raceline, Trail Ready, & Trail-GearJcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!
Unread 06-22-2009, 01:38 PM   #1
fast_man58
Im currently running a 2" bb lift with up country springs on my WJ. The springs are 125K old, and are probably sagging some. The BB is also just shy of an actual 2 inches, so im thinking of putting some 3" IRO springs on it.
Im wondering if anybody with this lift could give me a measurement from the axle center to the lip of the fender? Im curious as to how much lift i would actually get by going with the 3 inch springs, of if i should just go with the 4" ones.
Thanks in advance.
All of us could take a lesson from the weather. It pays no attention to criticism
night crew #078
fast_man58 is offline   Reply With Quote
Unread 06-22-2009, 03:56 PM   #2
GraKee99
Rapist Wit
GraKee99's Avatar
Stock WJ measurement from hub to fender is 18". You can do the math for lifts.
Brian
WJ, WK, CJ5
GraKee99 is offline   Reply With Quote
Unread 06-22-2009, 04:14 PM   #3
fast_man58
thanks much
night crew #078
Unread 06-22-2009, 07:12 PM   #4
robiec04wj
i have an 04 freedom laredo with the 2 in budget boost which came factory with the up country springs, it has roughly 121000 miles on it and i am at 21 inches hub to fender, therefore if the factory measurement is 18, you won't be getting much from 3 inch springs, if anything at all
robiec04wj is offline   Reply With Quote
Unread 06-22-2009, 07:48 PM   #5
jamnjeep
my iro 3'' lift measures 21.25 front and 21 back, its about 3 years old.
1994 YJ under construction....
jamnjeep is offline   Reply With Quote
Unread 06-22-2009, 07:48 PM   #6
herrmy
With 3" IRO coils, hub to fender is 22".
ROLL TIDE!!!
2002 Grand Cherokee 4.7 HO
3" IRO Coils, MX6's, JKS Adj Trackbar, Rancho SS, KOR Dual SS, Addco rear, BBK 70mm TB, K&N CAI, Magnaflow catback w/ high flow cat and 265/75 M/T MTZ's on 16" M/T Classic II's
herrmy is offline   Reply With Quote
Unread 06-22-2009, 08:01 PM   #7
fast_man58
thanks for the measurements guys. im at a touch over 20" with my current setup, so the 3" springs should get me a little over 21" from what it sounds like.
i'd go with a 4" LA kit, but i just dont have the funds as of now. im gona get some coils and JKS track bar on order.
night crew #078
