IRO 3.5 owners please stand up! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > IRO 3.5 owners please stand up!
Baseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft KiPoison Spyder DeFenders™ - "Tubeless" Jeep FendeJcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!
Unread 10-13-2008, 08:34 PM   #1
Reswob
I've seen a lot of threads come up lately asking questions about IRO's 3.5" F>R kit, so I thought we could start one comprehensive thread to point people to the next time the question comes up. Any ZJ owners currently running this lift, please post pro's/con's, suggestions, solutions, etc.
I'll start with some basic info from IRO's site:
http://www.ironrockoffroad.com/Merch...egory_Code=PFZ
ZJ 3.5" Lift Kit
$460
-3.5" front coil springs
-(4) Hydro shocks (upgrade to DT8000's $70, Bilstein $250, no shocks -$100)
-Adjustable front track bar
-Extended front and rear sway bar endlinks (upgrade to disconnects $80)
For those wondering where the rear springs are, your stock front springs are moved to the rear to (hopefully) achieve the appropriate amount of lift. The exact amount of lift to the rear will depend on how old your springs are, and if they are I6, V8, or UpCountry V8 springs.
If you're wondering where the rear track bar is, well, there isn't. To keep this kit as inexpensive as possible, IRO only included what was absoultely neccessary. Some people might feel that you don't need to do anything about the rear track bar. Some might want a relocation bracket(~$45). Some might feel the need to add a new fixed ($120) or adjustable ($140) rear track bar. Personally I think if you are going to get a new TB, spend the 20 bucks more for the adjustable.
With the kit installed, 31" tires fit without any trimming, but may rub on suspension components (such as the front LCA's) at full lock with stock rims. 32's should fit with a little bit of trimming. Of course if you're trigger-happy with a sawzall you could go 33+. Let's just say you went with 31's - your Jeep may look something like this:
My old front springs didn't quite give me the lift I needed in the rear, so I added some 3/4" BB spacers. To center the rear axle I got a rear track bar drop bracket made by Rough Country. A set of 1.25" wheel spacers from EZ Accesory keep the 31" STT's from rubbing on any part of the suspension. However, a little flexing with the wheels turned knocked a corner of the bumper cover off a few times, but as you can see from the pic I usually just take it off anyway.
Pro's:
-By far the cheapest way to lift your ZJ 3.5", no extraneous stuff to drive up the price (cough Rough Country cough Rubicon Express cough)
Con's:
-No rear track bar included (but then, this keeps costs down and lets you choose what you want to do about the rear axle)
'98 ZJ Laredo 5.2L Selec-Trac ~ Rock crawler on the outside, luxo-cruiser on the inside
3.5" IRO lift // 31" Cooper STT's // D44a Aussie Locker // NP242 swap // KOR Tow Shackles
'08 Kawasaki Ninja 250R ~ Daily Driver, 50 mpg Speed Demon
#27. Shirts get dirty. Underwear gets dirty. Pants? Pants never get dirty, and you can wear them forever.
Reswob is offline   Reply With Quote
Unread 10-13-2008, 09:36 PM   #2
spife7980
Here ya go.
LOL
3.5 F>R v8 upcountry in rear on well, look in my sig. ride is a little harsh without new longer control arms but that is to be expected. I rub on lower drivers control arm and full lock in reverse.
-James
Got to love an ORVIS guy...
IRO 5.5", Front LA & Double Sheer TB, Rear Adj SA and TB, JKS Quick Discos, Bilstein 5125, 265/75/16 Nitto Terra's, Cragar 16x& Soft 8s 4" bs
JCR Stage 2 Sliders, IRO Trans Skid, Carolina Drive shaft, IRO exhaust
spife7980 is offline   Reply With Quote
Unread 10-13-2008, 09:57 PM   #3
MoonyJohn
Jackstand Crawler
MoonyJohn's Avatar
Great write-up
ZJ - Sold
WJ- Sold
JK - :)
Oregonian Native
MoonyJohn is offline   Reply With Quote
Unread 10-14-2008, 05:23 AM   #4
Katesdad
Katesdad's Avatar
I have a 3.5 too but have ditched the rear springs and added RE rears. Still sits low in the back ...I think IRO sent me some 4.5s they just never sagged. I have a IRO straight trackbar ...avoid if you like full exhaust, get bent one. I have an addco rear swaybar and its stable as heck! RE mono shocks rock for sure.... I had a hydro leak and found a great deal on the RE monotubes new from a guy that changed his mind.
3.5 is great for 31s and doesnt give you any excessive lift.
Katesdad is offline   Reply With Quote
