IRO 3.5" kit - JeepForum.com
post #1 of 10 Old 02-24-2008, 09:59 AM Thread Starter
Dillonzj
IRO 3.5" kit
1 Does this kit I include everything I would need?
2 and is moving the front springs to the rear an ok thing to do?
3 also would it sit level with this I would not want the back to sag or something lol
4 oh yeah and would my current tires look ok with this lift?
Thanks
Dillon
http://www.ironrockoffroad.com/Merch...egory_Code=PFZ
98' JEEP GRAND CHEROKEE LIMITED 5.9
149k 5.9L v8 White
Crane Cam shaft and Crane, Roller Rockers, bored .030 over, edelbrock performer heads, M1 Intake manifold, Fasstman throttle body, magnacore wires, platinum plugs, K&N FIPK, dough thorley headers,3" high flow cat, 3" magnaflow mandrel bent exhaust, SCT tuned
***future mods -5.5 IRO LA - KOR sliders -KOR roof rack -
SOLD-
95' JEEP GRAND CHEROKEE LIMITED
188k 5.2L v8 White 98 ZJ rims
Originally Posted by nashmd454 View Post
...we all know they empty our pockets...yet they fill our hearts...
Dillonzj is offline
post #2 of 10 Old 02-24-2008, 10:06 AM
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
yes, the kit has everything you need.
lots of people to the F>R swap, so it has to be OK.
i wont promice you that it will sit level, but you can do sacers to level it out.
your current tires will look a little funnny, but not that bad.
hard working private first class in the United States Marine Corps.
Originally Posted by shift_grind View Post
It's threads like this that make me wonder why people lift there jeeps
its comments like this that make me wonder why some people are jerks.
build thread:
5.9 ANDY is offline
post #3 of 10 Old 02-24-2008, 10:11 AM Thread Starter
Dillonzj
so just moving the front springs to the rear you get 3.5" lift in the rear? do you think it would be like the front sitting a little lower or the rear? or could it go either way? and what about side to side? that would be level right?
Thanks a ton
Dillon
149k 5.9L v8 White
SOLD-
Dillonzj is offline
post #4 of 10 Old 02-24-2008, 10:45 AM
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
yea dillon, the rear springs are about 3-3.5 inches shorter than the fronts. so by putting the longer springs in the rear you get lift.
as far as it being level side to side.... i would be supprised if the jeep wasnt level, to fix it, you could do a spacer, or get a fat chick to sit on the high to level it out.
build thread:
5.9 ANDY is offline
post #5 of 10 Old 02-24-2008, 10:51 AM
GraKee99
Rapist Wit
GraKee99's Avatar
But how is that to work because it will lifted and fat chicks can't jump.
Brian
WJ, WK, CJ5
GraKee99 is offline
post #6 of 10 Old 02-24-2008, 10:52 AM
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
steep stool.
build thread:
5.9 ANDY is offline
post #7 of 10 Old 02-24-2008, 12:40 PM
Reswob
Thanks a ton
Dillon
Not quite. I'm sitting at about 3" lift in the rear, and that's with .75" spacers. I would also suggest getting either a relocating bracket (IRO can hook you up with one from Rough Country) or an adjustable rear track bar, in addition to the 3.5" kit. I've been driving on stock tires for almost a year now, yeah, you'll look a little funny
'11 WK2 Limited 5.7
Looking for a WK2 full size spare tire and 18" rims
Reswob is offline
post #8 of 10 Old 02-24-2008, 01:01 PM Thread Starter
Dillonzj
well it does not look lower in the back it looks good
149k 5.9L v8 White
SOLD-
Dillonzj is offline
post #9 of 10 Old 02-24-2008, 01:55 PM
2LIFE2
2LIFE2's Avatar
Is there advantage or disadvantage to using new front springs for the rear as opposed to the old front ones?
Should a guy leave the 2" BB in at the same time or would that be too much?
Either way you'd need to push the front wheels far forward and realign to avoid DW right?
Matthew
A hawk followed me home
2LIFE2 is offline
post #10 of 10 Old 02-24-2008, 02:27 PM
Schwarzy
I have the IRO 3.5 kit and I had to use 2.25 spacers in the rear to get a reasonable level look, because i used my i6 springs but I also didn't get 3.5" of lift, closer to 5" of lift for me.
1998 ZJ Jeep Grand Cherokee Limited I6
Lifted LA 7", Goodyear MTR's 33", Winch, Bumpers, Sliderz, 4.10, Locked, and Loaded.
Schwarzy is offline
"xenon" or "true white" headlight bulbs .. exist? sanboy ZJ Grand Cherokee Forum 16 10-12-2010 09:23 PM
Front Calipers "Teves" or "Akebono"? jimmy328 ZJ Grand Cherokee Forum 10 07-25-2009 09:48 PM
"Grand Cherokee" and "Limited" emblems? jdwiseman ZJ Grand Cherokee Forum 14 02-04-2009 06:49 PM
burning "smell" issue and "gas pedal vibration" issue in 07 gc laredo beepbeep13 WK Grand Cherokee & XK Commander Forum 4 01-08-2007 06:06 PM
Chirping/Squeaking only when in "Park" or "N" 3D-Dave ZJ Grand Cherokee Forum 1 05-01-2004 03:05 PM
