Introduction and question - JeepForum.com
post #1 of 6 Old 06-03-2004, 11:28 AM Thread Starter
Serstylz2
What's up everyone, I got a 94 GC Limited 5.2 V8 gas guzzler. I'm handin it over to my dad in a few days, but it has some mods on it already and there's one last thing I want to do. The passenger side headlamp is terribly dull compared to the driver's side lamp, because the driver's side lamp was repaired due to an accident about a year ago. I want to remove my passenger side lamp to clean it up and try to match it with the driver's side lamp. My dad said that the lamps are connected to the same parts that hold the RADIATOR in. Is there an easy way for me to get to it? Thank
Also, has anyone lost all power to their fog lights? I tried replacing the bulbs and got nothing.. I noticed that some wire was exposed on the driver side fog lamp so I removed the rusted area and reattached the wires and still got nothing. Thanks in advance.
www.cardomain.com/id/serstylz <-- pics of the Grand.
Serstylz2 is offline
post #2 of 6 Old 06-03-2004, 11:50 AM
greasefingers
greasefingers's Avatar
1994 ZJ
The head lamps on a 94 GC are held in by a type of ball & socket connector(s). They pop forward by pushing from behind the lamps with a lot of force. When I did mine, I broke one of the connectors. New head lamps can be found on ebay for half the cost that the dealer would charge. The lenses are plastic with a thin film of plastic on the front. Mine are pealing. Maybe they can be buffed-out? I removed mine to glue the two halves together because they would fill up with water.
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
post #3 of 6 Old 06-03-2004, 11:57 AM
greasefingers
1994 ZJ
Maybe I misunderstood you…if you need to replace only the bulb, then rotate the locking ring counterclockwise (about an 1/8th of a turn) and pull the bulb straight back & out.
Cheers Steve
post #4 of 6 Old 06-03-2004, 11:58 AM
PlatinumZJ
Senior Moment Member
PlatinumZJ's Avatar
Did you check the fuse?
Doug
Doug
When all is said and done, more is said than done.
Platinum '97 ZJ LTD, I6 (see profile) Paid for!
Links:
for ZJ & WJ stuff,
for performance stuff. I6 performance info at
Other stuff: Kevin's Roof Rack. KOR sliders, Bored 62mm TB, Blaupunkt Bermuda w/ ipod, Brembo Slotted rotors,
OME steering stabilizer, H4 headlight upgrade...
PlatinumZJ is offline
post #5 of 6 Old 06-03-2004, 12:41 PM Thread Starter
Serstylz2
Thanks for the replies, I'm gonna go yank at the lamps now. I noticed that Jeep uses a lot of connectors like that; they are all around the doors too; small yellow ones that break easily. I haven't checked the fuse yet either, I'll look there too. Thanks again - Arel
post #6 of 6 Old 06-03-2004, 01:24 PM
acitydweller
i'd definitely look at the fuses first before yanking stuff out.
acitydweller is offline
Introduction =D JeepCherk98 ZJ Grand Cherokee Forum 3 09-09-2008 07:16 AM
Introduction and Tire Question bergx7 ZJ Grand Cherokee Forum 3 08-31-2006 04:29 PM
Introduction and some questions siriusjeep ZJ Grand Cherokee Forum 3 03-08-2006 08:43 AM
Introduction JeremyBelnap ZJ Grand Cherokee Forum 13 06-24-2005 02:53 PM
my introduction and first question OverlandMan69 ZJ Grand Cherokee Forum 3 06-06-2003 11:54 AM
