Intermittent rough idle cold and hot. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Intermittent rough idle cold and hot.
Threaded Fixit Weld Washers!Why yes, we do still offer our Jeep Forum discount--code i2001 - 2004 Jeep Grand Cherokee Power Window Regulator wit
Unread 10-08-2009, 03:19 PM   #1
bjl95mustang
In the mornings I will stop for gas about 1 mile from my house. When I’m pulling out of the lot it will stumble when I accelerate. But on the highway it’s fine.
After I have been driving for a while and she is nice and warmed up I have some issues. When I’m sitting at a light my rpm’s will drop and I can my engine stumble. It seems like it’s miss firing. But once I’m moving she is just fine.
I just did a tune-up a couple months ago. Cap, rotor, plugs, and the wires are about 2 years old.
Where should I start checking? I have not had a CEL.
ZJ 98 5.2 LIMITED De-Badged
4.5" Lift: RE 4.5" springs,Iro rear 3.5 springs+1" spacer, RE shocks, All adjustable arms, IRO front track bar and HD bracket, Rear jks track bar, 1-Ton Steering, 242 tc, 33x12.5x15 GoodYear wrangler silent tires, 15" rock crawler rims, Aussie Locker For My 44A, 760X u-joint front axles.
Soon to come Lock Right Front Locker.
Jeep Inferno member #10
Texas Jeep Club Member #78
bjl95mustang is offline   Reply With Quote
Unread 10-08-2009, 03:46 PM   #2
melk
Have you cleaned the IAC? Checked out the TPS?
melk is offline   Reply With Quote
Unread 10-08-2009, 04:34 PM   #3
cmonson
when this starts happening, and you don't have any codes, I would start by taking your throttle body off and cleaning it so it looks like new. This could help, and the costs are free.
If that doesn't do the trick, then I would replace the IAC, then the TPS.
On a 98 (12 years old) the TB could be very carbonated and thus create problems. Clean out the small orface very well also.
cmonson is offline   Reply With Quote
Unread 10-08-2009, 04:55 PM   #4
gomes512
1994 ZJ
stumble upon acceleration usually indicates a tps that's on the way out. You can further diagnose by idling in park and very very slowly depressing the accelerator a little by little. Usually a bad tps will not notice this slow change until you've depressed the pedal a good bit. Then it will jump up to say 1K or so, so you should see a hesitation. When this jump occurs keep your foot at that position and release the pedal very slowly to the end, it will most likely cause a rough idle.
If changing the tps I would just get a new iac to go with it, two birds one stone.
gomes512 is offline   Reply With Quote
