intermintent bogging, sputtering and popping - JeepForum.com
post #1 of 21 Old 07-12-2011, 07:33 AM Thread Starter
MFay52
good morning everyone, This all started off yesterday on my way home from work when my check engine light came on and the jeep would not hold cruising speed. So i come to a stop at the next red light and found the idle to be smooth and consistent, then the light turned green and it became very hesitant almost like it was running out of fuel (had half a tank at the time) It seems the problem is mainly between aproximately 10 and 75% throttle, as when it is idling it is fine, and when more then 75% throttle is applied it seems to fight through the bogging sputtering and popping sounds that it would otherwise make.
Any ideas guy?
MFay52 is offline
post #2 of 21 Old 07-12-2011, 07:44 AM Thread Starter
MFay52
sorry i almost forgot, Its a 97 ZJ 4.0 I6 with 229k on the clock, its never had an issue like this before besides the IAC over a year ago. Thanks in advance!
MFay52 is offline
post #3 of 21 Old 07-12-2011, 08:09 AM
newfieZJ
You have a CEL , what's the code ?
JIC , you turn your key to the on(not start) position , then off-on-off and on again . This should work on all years except 98
newfieZJ is offline
post #4 of 21 Old 07-12-2011, 08:21 AM Thread Starter
MFay52
yes the check engine is on... If i use that sequence with the key, will the MIL flash to show me the code?
MFay52 is offline
post #5 of 21 Old 07-12-2011, 08:40 AM
newfieZJ
it should flash via the check engine light itself . It will start with 12/blink....blink blink , and end with 55/blink x 5.......blink x 5
Your looking for anything in between
newfieZJ is offline
post #6 of 21 Old 07-12-2011, 08:45 AM Thread Starter
MFay52
Thanks i will try that in a little while and post what i find on here
MFay52 is offline
post #7 of 21 Old 07-12-2011, 09:04 AM
newfieZJ
You can also get a more specific code using a OBDII scanner . This should be free at your local parts store in many cases .
newfieZJ is offline
post #8 of 21 Old 07-12-2011, 09:14 AM Thread Starter
MFay52
Yeah.. im aware and know how to use the scanner, im just stuck at work with no access to anything like that. I just want to be able to get the code, somewhat hoping its the tps that i may be able to disconnect and get it home (35miles) in limp mode
MFay52 is offline
post #9 of 21 Old 07-12-2011, 09:31 AM
phitmein
phitmein's Avatar
a bad cat. converter acts a little like that execpt for the over 75% part ...
phitmein is online now
post #10 of 21 Old 07-12-2011, 09:42 AM Thread Starter
MFay52
i was also thinking that, but i replaced the cat, both O2's, muffler and tailpipe back in may with mopar O2's, walker cat and dynomax catback...
The popping sound it makes while bogging down is making me think its a lean condition maybe a fuel pump, filter or both?
Id rather find out before pulling down the tank and doing all that though
MFay52 is offline
post #11 of 21 Old 07-12-2011, 09:53 AM
newfieZJ
I'm thinking throttle position sensor . I just had a little issue with my 97 Cherokee , rather , bought with it . Symptoms sound the same . My cat's toast to the point of annoying rattle . Works fine with the TPS issue resolved . Maybe a little harder on gas than it should be Cat's next on the list
newfieZJ is offline
post #12 of 21 Old 07-12-2011, 10:06 AM Thread Starter
MFay52
im really hoping that it is the TPS, fuel pump and filter assemblies are expensive... even on rockauto
MFay52 is offline
post #13 of 21 Old 07-12-2011, 10:30 AM
phitmein
phitmein's Avatar
Next step then is do a fuel pressure test and see what you got going on ...
Phit
post #14 of 21 Old 07-12-2011, 10:37 AM Thread Starter
MFay52
Phit
would low fuel pressure cause a MIL? Without checking the code yet im guessing that it is going to be a lean code, judging by the popping sound you can hear in the exhaust during the sputtering.
MFay52 is offline
post #15 of 21 Old 07-12-2011, 11:39 AM Thread Starter
MFay52
I tried the key sequence and nothing happened with the CEL any other suggestions?
MFay52 is offline
Intermintent starting problem lionsfan808 WK Grand Cherokee & XK Commander Forum 2 03-14-2011 10:06 PM
jeep bogging down irishluck ZJ Grand Cherokee Forum 5 02-19-2011 12:10 PM
Jeep bogging down Kellan ZJ Grand Cherokee Forum 2 03-15-2009 11:17 PM
bogging?? scarbound ZJ Grand Cherokee Forum 0 03-16-2008 09:41 PM
93 GC bogging down spankyway ZJ Grand Cherokee Forum 12 08-14-2007 02:01 PM
