interior and under hood lights not working - JeepForum.com
post #1 of 11 Old 06-11-2012, 05:40 PM Thread Starter
1998grand
ok so i got tired of my sagging head liner in my jeep so i pulled it out. i took the roof console out so i can take the headliner out. when i went to re-install the console none of the interior lights worked. the gas milage/compass display still works but not the lights. my dash lights all still work. i noticed that the light under the hood no longer works when the hood is up either. When i turn my alarm on/off via the keyless entry the parking lights used to blink but no longer do. no issues with the headlights themselves. im wondering if everything that is not working are all ran together and if maybe a fuse blew when i was removing and installing the console. has anyone had this issue that can shed some light? if they are all on 1 system do you know where the fuse might be for them?
1998grand is offline
post #2 of 11 Old 06-11-2012, 06:07 PM
JasonStebbins
There are quite a few wires above the console. If it happened after re-installation, I would take it off and make sure none of them ripped or are showing bare wire.
Best to pull all the fuses and check them. Only takes five minutes.
JasonStebbins is offline
post #3 of 11 Old 06-12-2012, 04:39 AM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
Mine had pinched wires in it to start with before headliner replacement. Check them out closely. If you have an ohm meter check each wire for continuity and shorts.
coralman is offline
post #4 of 11 Old 10-24-2012, 05:13 PM
GaJeepDriver
I took my headliner out this afternoon and I am having the exact same problem. I even tried them with the console down while checking/shaking wires to no avail. I will look more into it tomorrow since I ran out of daylight. If I figure out whats causing them not to work I will post back if you haven't beaten me to it.
GaJeepDriver is offline
post #5 of 11 Old 10-24-2012, 08:05 PM
Gr8Hondo
In the PDC up front you should have a 20amp fuse that is the Ignition Off Draw fuse and has likely blown.
Gr8Hondo is offline
post #6 of 11 Old 10-27-2012, 07:46 AM
GaJeepDriver
Found my problem. Maybe yours is the same. There is a small pull off cover in the passenger floorboard area, right hand side. The 10 amp fuse for the courtesy lights is in that fuse box. Mine was blown. There should be extra fuses and a fuse puller attatched to the cover so no need to go out and buy a fuse.
post #7 of 11 Old 01-20-2013, 11:22 AM Thread Starter
1998grand
that was the first thing i tried. still havnt figured it out. will have to use a meter to check and see which wire isnt getting power.
post #8 of 11 Old 01-20-2013, 11:24 AM Thread Starter
1998grand
"pdc"?
post #9 of 11 Old 01-20-2013, 11:34 AM
coralman
coralman's Avatar
power distribution center
Originally Posted by HighLonesome
coralman is offline
post #10 of 11 Old 01-20-2013, 02:12 PM
KoreaZJ
1994 ZJ
Verify +12v on both ends of Junction Block Fuse#16 (10amp). Nothing else common to hood/interior lamps unless JB problem.
KoreaZJ is offline
post #11 of 11 Old 03-29-2013, 08:53 PM
farmr550
same problem
I have the same problem with mine. The lights all worked until I installed the head liner. I have checked the fuse #16 and it is fine. Tomorrow I am going to finish checking but so far I can't find 12 volts anywhere on the courtesy circuits. Plus when I turn on the headlights now the dash lights are very dim and won't brighten. Wish I had a better diagram that Haynes provides. I hope you figure it out so I can!! By the way mine is a 98 limited with the 5.2.
farmr550 is offline
interior lights stopped working 98zjkidd ZJ Grand Cherokee Forum 7 10-08-2017 10:35 AM
Interior Courtesy Lights Not Working bahnstormer WK Grand Cherokee & XK Commander Forum 9 01-26-2012 05:35 PM
vic not working & interior lights stay on 4x4troy ZJ Grand Cherokee Forum 1 04-07-2010 10:06 PM
interior lights not working. highriskpb_nick ZJ Grand Cherokee Forum 8 01-08-2009 12:40 AM
Radio/HVAC interior lights not working dshannon ZJ Grand Cherokee Forum 1 07-09-2007 08:13 PM
