Interior roof liner - JeepForum.com
post #1 of 7 Old 10-16-2005, 03:28 PM Thread Starter
leton
Interior roof liner
I know this is not necessarily a Jeep question, but the liner on my Grand Cherokee is coming off a bit from driving with the window down. What type of adhesive would be best to tack that down?
leton is offline
post #2 of 7 Old 10-16-2005, 05:02 PM
Animal Mother
Animal Mother's Avatar
mine did that too so i just stuck a safety pin in it to keep it up.
96 5.2L ZJ Limited Forrest Green
Animal Mother is offline
post #3 of 7 Old 10-16-2005, 05:16 PM
driabyor
driabyor's Avatar
1994 ZJ
nothing works... it just make a nasty looking mess...... the glue will bleed thru....
i fixed mine with a knife.....
doesnt look great but looks way better than cloth hanging down everywhere
94 Grand Cherokee ... 332,000 miles
5.2 liter 242 :)
Rancho 5000 steering stabilizer
driabyor is offline
post #4 of 7 Old 10-16-2005, 05:18 PM
driabyor
driabyor's Avatar
1994 ZJ
i cut all the headliner out ,,then vacuumed the foam off
5.2 liter 242 :)
driabyor is offline
post #5 of 7 Old 10-16-2005, 06:04 PM
leftfield6
Where are my damn keys?
leftfield6's Avatar
DIY headliner
The only attractive way to repair this is to completely replace the headliner material. I've not done this on my JGC, but I have done it on my Volvo wagon. I gotta think it's pretty much the same process.
  • remove the headliner completely by removing any interior parts, panels, clip, including visors, overhead consoles, lights, etc.
  • take the entire panel out the rear door. be careful to not break the board, it's a fairly thin fiberglass/fiberboard type thing.
  • lay the headliner upside down on a sheet of plywood. Up on sawhorses keps it at working height. Upside down means soft, cloth side up, this is what you will be removing.
  • peel the cloth off, it will leave behind the deteriorating foam. the foam is what fails and makes the headliner fall in the first place.
  • using a wire or stiff plastic brush, "scrub" the foam off the headliner panel. This will be messy!! Scrub, vacuum, scrub vacuum, wear a mask. You will be able to get almost all of the stuff off, don't be surprised if whats left feels kind of gummy. Just get it fairly smooth.
  • Here's what you need to buy: headliner material at an upholstery shop, sold by the yard, and 3M Super Trim Adhesive, accept no substitute. The right adhesive is what will keep you from redoing this in 6 months. The "Heads-Up" brand you can get at the corner parts store is crap!!
  • lay the new fabric over the headliner panel and trim it to fit, leaving a little extra all the way around.
  • Okay, now the fun part. Fold the material back 1/2 way. In other words, from the front of the headliner, fold the cloth back so 1/2 of the board is exposed. You will now have 1/2 the board exposed and 1/2 of the back of the fabric.
  • Spray the exposed part of the board with the adhesive, and spray the back of the foam that's exposed. Coat heavily, but don't soak the cloth or it wil bleed through.
  • Folow the instructions on the can for the time to wait before you press these two together
  • When ready, begin foldingthe two "glued" halves together from the middle, smoothing as you go. Don't try to stetch the headliner material, it will only pull loose later. Take your time, you have more time than you think. Don't worry about cut-outs or anything now, you can do that later
  • Now fold back the other 1/2 and repeat the above steps.
  • Let it sit overnight, then trim the material fairly close around the outside, leaving about a 1/4 to a 1/2 inch extra. Now cut out holes such as overhead lights, visors, etc.
  • In the immortal words of Chilton manuals everywhere, installation is the reverse of removal!!
  • Should be it, except for putting up with the adhesive smell for a few days
  • If you have a sunroof, this is likely way more complicated!
I make no claim to know exactly how to remove which interior panels, just giving you the general steps to replacing the fabric.
Give it a shot, it's not that hard, and can save you a few hundred $ over what an upholstery shop wold charge you.
Doing a temp fix with the headliner material you've got to now is just that, temporary. Once the foam begins to seperate, it will continue. Even if you glue up the corner that's loose now, it will look like crap, AND it will droop somewhere else in a few months.
I'm a big advocate of doing it right once, not doing it wrong 18 times!
Jeepless for now, probably not for long
(former)
98 Grand Cherokee Limited 5.9
98 Grand Cherokee Laredo
77 CJ-5
75 CJ-5
leftfield6 is offline
post #6 of 7 Old 10-16-2005, 09:07 PM
Meerkat
If you go to Auto Zone or similar, they sell an arosol can of headliner adhesive. Assuming the foam backing is sound, simply spray the adhesive on, let it set as per instructions, then press the fabric back in place.
Voila!
HTH
Warren
Black 1996 5.2L ZJ Limited
Meerkat is offline
post #7 of 7 Old 10-17-2005, 05:47 PM
Airborne Lee
Airborne Lee's Avatar
new mod idea
over the weekend, one of the auto shows, (i can't remember which). i saw a carbon fiber head liner for a car. I wonder if there are for a jeep?
Good idea for a mod for some creative aftermarket company.
please buy this NEW IN BOX:
3 Previous Jeeps - 01 WJ Ltd, QD & UC - 01 WJ Ltd, QT II - 98 XJ Ltd
Airborne Lee is offline
Interior Roof Leak sunflash2012 ZJ Grand Cherokee Forum 28 10-06-2013 07:10 PM
rhino liner on zj wassy ZJ Grand Cherokee Forum 21 03-30-2009 02:41 PM
zj body liner 95grcher ZJ Grand Cherokee Forum 5 03-31-2008 04:09 PM
Spray on liner? 97 ZJ Steve ZJ Grand Cherokee Forum 14 12-08-2006 01:34 PM
How do I dismantle interior roof/headliner?? mikey3019 ZJ Grand Cherokee Forum 2 03-22-2006 11:29 PM
