Interior rhynoline project question - JeepForum.com
post #1 of 3 Old 04-30-2013, 10:29 AM Thread Starter
Firefight3312
So I just tore out all the carpeting and insulation on the floorboard of my zj to start prep work for rhynolining however once I pulle the carpet I hit two obstacles First wiring....I have big bundles of wires running down the floorboard that isn't covered by trim....can I rhynoline that too or should I try to relocate. Also my parking brake line runs over the hump in the back. Can I cover that too? Finally when I pulled everything ip there's like a quarter inch thick maybe sound deadiner on the floorboard. Any tips on how to get that up? The industrial glues crazy and won't budge. Thanks
Firefight3312 is offline
post #2 of 3 Old 04-30-2013, 01:02 PM
thetammon
I would just bed line over the stuff that's glued down. As for the wires, you could get some if the corrugated tubing to put the wires in so they're protected and still removable if need be. Then bed line right over that.
Sent from something using JeepForum
thetammon is offline
post #3 of 3 Old 04-30-2013, 03:20 PM
speedbucket
Just put some sheet metal over the wires and whatnot with some short self tappers. Hell, you probably could put some cardboard or paper over it and the liner would span them once dry
V8 zj at 6" . Double tri rear and true 3 link front. Stretched to 108"
speedbucket is offline
