Interior lights stay on & no power to VIC please help! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Interior lights stay on & no power to VIC please help!
2014 Spartan Locker Special - While Supplies Last! Dana 3OPTIC ARMOR WINDOWS all sale now !!!!!!!!Rockridge 4WD IS Taking Zone Offroad Suspension Lift Kits
Unread 01-12-2014, 07:48 AM   #1
EastCoast
Ok here is the rundown...
98 grand cherokee laredo...
interior lights are staying on when doors are closed.
yes I tried the adjustment slider, it is not all the way up...
Also the VIC has not had power for a while but it hasn't been a problem before but now I am afraid it is somehow related...
Also once you put the key in and turn it to acc the lights turn off so I'm not sure if it could be the door switch or not... my thinking is if it is the door switch, the lights would stay on even once you turn it to acc..
I have done a good amount of research before posting this thread...
the general consensus is a bad BCM.. which is a very expensive part unless bought used, and from what I have read if you replace with a used BCM it can be very risky if you don't get a matching one...
idk I am out of ideas. I would love to hear what you guys have to say.
Thanks...
I will try to add in any more info that is needed....
EastCoast is offline   Reply With Quote
Unread 01-12-2014, 07:20 PM   #2
ZeeJay1997
All interior lights? dome. courtesy?
ZeeJay1997 is offline   Reply With Quote
Unread 01-12-2014, 08:03 PM   #3
boogie102786
I just signed on to ask about the same problem. Same year as well. All interior lights as well as the little ring around the ignition are lit up. What are you calling the Vic?
Wait... Instrument cluster? If so mine does work.
boogie102786 is offline   Reply With Quote
Unread 01-12-2014, 09:27 PM   #4
JasonStebbins
Obv
JasonStebbins's Avatar
I tried hunting mine down for the first six months I had my ZJ, then I got sick of it and installed a toggle switch.
Check the door jam buttons, wiring in the door boot, rear hatch switch, and the relay.
Common ZJ problems and how to fix them by JasonStebbins
http://www.jeepforum.com/forum/f13/c...x-them-1432264
12 things to do when your ZJ stalls by ZeeJay1997
http://www.jeepforum.com/forum/f13/1...talls-1407423/
JasonStebbins is offline   Reply With Quote
Unread 01-13-2014, 05:22 AM   #5
EastCoast
yeah courtesy lights, my bad...
I tried going to all the door jam switches and manually pushing them in and that didn't seem to be the problem...
I then tried to check the relay but the owners manual did not exactly match up to what I was seeing...
I haven't tried the rear hatch yet, that might be an idea..
could you elaborate on "wiring in door boot"?
thanks everyone for the responses, got more responses here then in electrical sub-forum!
Unread 01-13-2014, 05:25 AM   #6
boogie102786
I also tried pushing in all the door switches. For some reason I couldn't finds one on the hatch.
Unread 01-13-2014, 07:35 AM   #7
ZeeJay1997
that's because the electrical forum fights the general populace of gremlins. we fight the ones who attack zjs... special forces so to speak.
for the courtesy lamps, it's going to have to be one of four things:
1) closed door ajar switch (these are normally open) or wire to bcm is shorted to ground. These wires will be tan with a stripe.
2) bcm is sending constant ground on brown/ light green wire or the output wire from the bcm (brown/ light green)to the courtesy lamp relay is shorted to ground
3) bad courtesy lamp relay
4) bad bcm
For the VIC, check power at the connector. 10 is ground. 2 is hot from battery. 16 is hot from switch.
Unread 01-13-2014, 08:31 AM   #8
boogie102786
Is any of this wired into the radio? I ask because I installed an aftermarket CD player a few weeks before this started.
Unread 01-13-2014, 09:08 AM   #9
ZeeJay1997
the panel lamp driver from the bcm is tied to the radio. it may be better to start your own thread. doesnt sound like the same problem
