interior lights stay on - JeepForum.com
post #1 of 15 Old 03-31-2013, 10:55 AM Thread Starter
Missyj81
1994 ZJ
So im gettin ready for spring......fixin all the little stuff that annoyed me. My interior lights always stay on, had pull the bulbs out, it was the only way. This includes the rear hatch light, the dome ceiling light. Ps i hate electrical so try to explain in the most simplistic way possible
Missyj81 is offline
post #2 of 15 Old 03-31-2013, 11:01 AM
Mlarv
2014 JK Wrangler
Well most likely it will be a door switch or the lift gate switch. On mine it is caused by the Lift gate switch. I have to rebuild it one of these days
What Would Scooby Do?
Mlarv is online now
post #3 of 15 Old 03-31-2013, 11:24 AM
classicmetalman
X2 on what Mlarv said. Don't dig electrical myself, but if your gonna address, gonna have to pull off some panels n check. As long as you can deal with the bother of no interior lights and your battery is not draining.......
Robert
93 Laredo 4.0
96 Limited 4.0
Originally Posted by murphydajeep View Post
I say you should still hit something just to let it know you mean business, or shake a hammer at it in a menacing fashion
classicmetalman is offline
post #4 of 15 Old 03-31-2013, 11:47 AM
BigJohn96ZJ
Not trying to be a smartazz but why didnt you just pull the fuse?
96 ZJ Laredo 4x4, 5.2l, 2.25" budget boost, 31 bfg m/t KM2
BigJohn96ZJ is offline
post #5 of 15 Old 03-31-2013, 12:10 PM Thread Starter
Missyj81
1994 ZJ
Did that too
Missyj81 is offline
post #6 of 15 Old 04-03-2013, 07:45 PM
jeepyard
What model is your jeep? Check a thread I wrote titled "interior lights wont go off on 98 grand cherokee" I worked on mine on and off for bout two years abd finally got the interior lights on mine fixed. Read up on that post I mentioned earlier and see if any of that info helps!!
jeepyard is offline
post #7 of 15 Old 04-03-2013, 08:39 PM
newfieZJ
Some times the door switch needs just a little extra help . One easy fix is to get those little pads you put on the legs of chairs at Wal-Mart . Just stick them on the door where the switch contacts it . Works like a charm .
You can hold the switch manually with your finger , see if the lights go out after a minute or just out them on all 4 doors . My issue was on the drivers door .
Post back if it works or , doesn't
newfieZJ is offline
post #8 of 15 Old 04-03-2013, 09:00 PM
capcyclone
capcyclone's Avatar
+1 on this ^^^
I had a similar issue, though my interior lights would seem to randomly come on as I was driving down the road, then off, then back on after a few moments, etc. I found all I needed to do was lubricate the switch and voila! Works like it did when it rolled off the assembly line.
"The Jeep is America's only real sports car" - Enzo Ferrari
'98 Jeep GC 5.2L "ZJ" - Sold
'02 Jeep GC 4.7L HO "WJ" - Daily driver
capcyclone is offline
post #9 of 15 Old 04-03-2013, 09:43 PM
jabba974
I had this problem too... I bet dolars to doughnuts that the hinge pin bushings on your door are worn out and the door is lower at the switch...If the lights go out when you push in the switch I bet thats your problem.. Try replacing those and see how that works
jabba974 is offline
post #10 of 15 Old 06-18-2013, 09:47 AM
patricknotstar
Ok so I have a 98 jeep grand Cherokee laredo and the interior lights won't go off unless I pull the fuse under the glove box, I checked the door switches and even unplugged some of them and nothing happened, I'm not sure but could it have somthing to do with the onboard computer. On a side note my gauges won't come on when I start it somtimes and last night, hitting it seemed to do the trick. So any help on either of these isues would be appreciated
patricknotstar is offline
post #11 of 15 Old 06-18-2013, 10:46 AM
Xpress
My issue happened to be the purple/yellow stripe wire that goes into the BCM. Seems like it was traced over to the passenger side alarm switch that clips onto the back of the lock cylinder. Snipped it and the lights go off like normal, however this opened up a can of worms with the alarm.
All about that unibody life.
Xpress is offline
post #12 of 15 Old 07-04-2013, 06:20 PM
patricknotstar
k so I Had a problem recently with interior lights staying on and having to pull the relay under the glove box and my remote unlock for the drivers side door would not work, so anyway I took the panel off the door to see if it might be sticking and noticed a loose connection near the door latch so plugged it all the way in and now both interior lights and drivers side lock work.. I think because the wire was not connected all the way the system thought it was being unlocked therefore keeping the lights on.. hope this helps somone else in need
post #13 of 15 Old 07-04-2013, 08:58 PM
jzoomer
Not trying to be a smart a$$ but have u tried turning off the rear cargo light, when I bought my zj the int lights stayed on while driving no matter the time, after some research I found out the rear most cargo light is actually a button and push it and it "clicks" off and on, when its clicked on every light in the jeep stays on, when clicked off they operate as designed...
jzoomer is offline
post #14 of 15 Old 07-06-2013, 07:34 PM
jeepin87
My door hinges were worn and the door struck low When I closed it, bad enough it cracked under the door switch and would push in not letting the switch work correctly. Kicked my *** for 2 weeks figuring out why the lights would sometimes stay on and other times not. I even shimmed the switch. So I eventually found the root cause of the problem and replaced the hinge pins, then welded the crack on the door. Good as new.
1978 J10 Honcho Truggy project 401/Tons/???
1983 J10 Honcho Stepside I-6 add a leaf/33"s
1988 Grand Wagoneer 401 4"/34"s
1998 ZJ 5.9 Limited 4.5" LA/33"s
1999 WJ 4.0 Limited
2003 Ram 1500 w/built 12v cummins
2004 Ram 2500 Cummins tow rig
jeepin87 is offline
post #15 of 15 Old 07-06-2013, 08:29 PM
Rich93ZJ
^^^THIS^^^....Found this out the hard way also. One other thing is make sure the dimmer switch is not all the way up. That will turn the lights on also.
Rich93ZJ is offline
