Interior lights flashing / blinking - JeepForum.com
post #1 of 8 Old 05-13-2008, 12:53 AM Thread Starter
Louie619
This is happening to us --'97 Jeep GC.
While driving the interior lights flash and door locks cycle lock and unlock.
HELP!
Tonight, the interior lights would not go off when parked.
I pulled the interior light relay.
The door lock cycling when driving is hard to figure out.
...very hard to trace down.
Louie619 is offline
post #2 of 8 Old 05-13-2008, 01:03 AM
dcvance87
The interior lights could be a result of a bad headlight switch. a bad sauder joint on the unit often leads to lights flickering either on the dash or above. the locks...no clue.
06' TJ, 4" Rough Country lift, 2" body lift, 35 BFG all-terrains.
dcvance87 is offline
post #3 of 8 Old 05-13-2008, 07:36 AM
merlinTec
merlinTec's Avatar
Hi
I take you have auto door lock/ unlock on? I would say you have a door switch shorting or wiring to it is faulty and it's shorting out.
UK Chrysler Jeep Master Tec.
merlinTec is offline
post #4 of 8 Old 03-17-2011, 06:45 PM Thread Starter
Louie619
Interior Lights flashing 97 Jeep GC
REPLACE the door switch !!
We have seen many posts that say that the door needs to be slammed shut
so the lights will go out.
Part source: Dealer $16, or Autozone or Rock Auto $4-to $6-
HELP!
Louie619 is offline
post #5 of 8 Old 03-17-2011, 06:53 PM
Mark05059
just need to figure out which door isnt shutting all the way or that the switch is bad in.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #6 of 8 Old 03-18-2011, 12:18 AM
jvick920
X1 bad headlight switch. Try NOT using the auto-on headlight setting.. just the on and off settings. I had the same problem with lights and odometer blinking, my headlight switch has an open circuit.
1996 Grand Cherokee Limited 4.0 185,xxx miles- Recreation and for the kids.
2004 Civic Hybrid 102,xxx miles- daily driver.
jvick920 is offline
post #7 of 8 Old 01-17-2013, 12:26 PM
konorza
Solved !!!
Basically you just remove the " Window Liftgate Ajar Sensor ", snap back in place using pliers, and care fully crimp metal edges to hold down from poping out of place again. P.S. some dealers and auto parts has discontinued this part and it can only be found at a junk yard but this will fix it guaranteed.
konorza is offline
post #8 of 8 Old 01-17-2013, 06:14 PM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
Good writeup and excellent pics! Not sure which switch it is but I referenced all liftgate switches and it looks like they are still available but they are not cheap. Added your fix to my favorites.
Originally Posted by HighLonesome
coralman is offline
Interior lights flashing during driving...? MyZJ98 ZJ Grand Cherokee Forum 10 06-05-2012 03:46 AM
Headlights and Interior lights keeps flashing bull_blaster WK Grand Cherokee & XK Commander Forum 3 01-15-2009 09:10 PM
Flashing interior light with indicator craigd ZJ Grand Cherokee Forum 1 09-13-2006 10:31 AM
Flashing Interior Lights jajujeep ZJ Grand Cherokee Forum 4 11-04-2004 12:58 PM
Flashing Interior Lights? jplush76 WJ Grand Cherokee Forum 5 11-04-2003 12:45 PM
