Interior Lighting Help! - JeepForum.com
post #1 of 9 Old 08-01-2011, 04:55 AM Thread Starter
dmill33ZJ
hey guys,
So, yesterday i decided to fix my sagging headliner that gravity ruined. Went to Jo-ann fabrics, felt so odd to go in there, but got a some nice felt and heavy duty loctite adhesive. Started working on pulling the old headliner out, worked from rear to front to unbolt and pop things off. Once i got to my driver side visor i found a wiring harness that i COULD NOT disconnect. I figured i dont care for the lights to the mirror anyways and took the lazy way out and just cut the wires with cable cutters. and BOOM all my interior looks went out. i figured once im done and reconnect the wires the problem would be fixed but NO i was wrong.
So, my question is:
Is there any way i could fix this problem???
Any help would be awesome!
Thanks!
dmill33ZJ is offline
post #2 of 9 Old 08-01-2011, 05:12 AM
kahjeep
Yikes, that sucks. Goodluck to you. I am of no help.
kahjeep is offline
post #3 of 9 Old 08-01-2011, 05:14 AM
TewSmooth18
positive you re wired it correctly? check all your fuses
97 Grand Cherokee 5.2 V8 - 242 swap - everything else stock atm
TewSmooth18 is offline
post #4 of 9 Old 08-01-2011, 05:54 AM
MeanGreenZJ
Let me get this right. You felt Jo-ann and pulled your headliner then you couldn't disconnect your wire so you cut it? If that was me, I would of blown a fuse. So you might want to check that.
MeanGreenZJ is offline
post #5 of 9 Old 08-01-2011, 06:00 AM Thread Starter
dmill33ZJ
haha i guess i should have read over that, sorry
Ill check the fuses, but does anyone know where the interior lighting fuse is in a 96?, thanks
post #6 of 9 Old 08-01-2011, 01:18 PM
MeanGreenZJ
red 10amp fuse in the passenger kick panel position 16.
post #7 of 9 Old 08-01-2011, 10:43 PM Thread Starter
dmill33ZJ
I got it working, everything is good now
Thanks Guys, much help!!!
post #8 of 9 Old 08-02-2011, 04:39 AM
kahjeep
What was it?
kahjeep is offline
post #9 of 9 Old 08-03-2011, 02:00 AM Thread Starter
dmill33ZJ
Originally Posted by kahjeep View Post
What was it?
The fuse
I guess thats what happens when i high school student gets lazy
ZJ interior lighting issue. tedthefed ZJ Grand Cherokee Forum 1 10-12-2010 05:23 PM
Interior lighting questions flea620 ZJ Grand Cherokee Forum 4 11-19-2009 05:32 AM
Interior Lighting cutnaction ZJ Grand Cherokee Forum 5 05-02-2005 08:23 PM
interior dome lighting trekbuddy ZJ Grand Cherokee Forum 13 03-30-2005 07:21 PM
interior lighting?? errodri1961 ZJ Grand Cherokee Forum 1 08-21-2003 05:58 PM
