-   -   Interior Lighting Help! (http://www.jeepforum.com/forum/f13/interior-lighting-help-1247163/)
dmill33ZJ 08-01-2011 04:55 AM
hey guys,
So, yesterday i decided to fix my sagging headliner that gravity ruined. Went to Jo-ann fabrics, felt so odd to go in there, but got a some nice felt and heavy duty loctite adhesive. Started working on pulling the old headliner out, worked from rear to front to unbolt and pop things off. Once i got to my driver side visor i found a wiring harness that i COULD NOT disconnect. I figured i dont care for the lights to the mirror anyways and took the lazy way out and just cut the wires with cable cutters. and BOOM all my interior looks went out. i figured once im done and reconnect the wires the problem would be fixed but NO i was wrong.
So, my question is:
Is there any way i could fix this problem???
Any help would be awesome!
Thanks!
kahjeep 08-01-2011 05:12 AM
Yikes, that sucks. Goodluck to you. I am of no help.
TewSmooth18 08-01-2011 05:14 AM
positive you re wired it correctly? check all your fuses
MeanGreenZJ 08-01-2011 05:54 AM
Let me get this right. You felt Jo-ann and pulled your headliner then you couldn't disconnect your wire so you cut it? If that was me, I would of blown a fuse. So you might want to check that.
dmill33ZJ 08-01-2011 06:00 AM
haha i guess i should have read over that, sorry
Ill check the fuses, but does anyone know where the interior lighting fuse is in a 96?, thanks
MeanGreenZJ 08-01-2011 01:18 PM
red 10amp fuse in the passenger kick panel position 16.
dmill33ZJ 08-01-2011 10:43 PM
I got it working, everything is good now
Thanks Guys, much help!!!
kahjeep 08-02-2011 04:39 AM
What was it?
dmill33ZJ 08-03-2011 02:00 AM
Originally Posted by kahjeep (Post 11954537)
What was it?
The fuse
I guess thats what happens when i high school student gets lazy :D
The time now is 03:18 AM.
