Interior Lighting - 1/2 work. - JeepForum.com
post #1 of 20 Old 07-20-2008, 01:23 PM Thread Starter
brntwood
Hi--1996 Grand Cherokee limited. When open any door (inc rear lift gate) - the only interior lights that come on are the ones on the front doors. The center dome light, light under the pass side dash do not come on. (Also - the rear carge light does not work.) Note - the push button center reading lights (And the front map lights) DO work. The rear carge (with the lens push switch does not light) I've checked all bulbs etc. Seems like there are two circuits for the interior lights. (Why do the interiort door lights come on - yet not the "other" interior lights (Center dome, under dash, rear cargo, etc.) not come on when open door. I checked and DO have 12V power (to ground) on a pink and yellow wire in the center dome assembly, and I do have ground condinuity from the black to chasis ground. I would assume this is correct - but most probably (cause it ain't workin. :-) This is not correct. Help.... :-( I'm confused. THANKS....
brntwood is offline
post #2 of 20 Old 07-20-2008, 02:14 PM
JCZJ
Try pushing the light over the cargo area, it acts as a switch turning the interior lights off and on when you open the doors. It might just be off.
1998 ZJ // 5.2L // Lifted!
1994 ZJ // 4.0L // 271,000 miles // Some cool stuff // RIP 5/25/08
1965 Ford Mustang 2+2 // Boss 302 Swapped // Locked 9" rear
Originally Posted by Shoey40 View Post
She can XJ my WJ whenever and however she wants. Hell, I'd let her CJ it, too.
JCZJ is offline
post #3 of 20 Old 07-20-2008, 05:18 PM Thread Starter
brntwood
Thanks for the idea - but no luck.
Unfourtantly - that wern't it. :-( Again - I have power ( think) --yet these lights don't light. (Tested the bulbs-there all good.) This is makeing me more nutso than I usually am. It has GOT to do something with this floating ground (which I admit - I don't totally understand or another switch somewhere. (Is this by any chance one of those "programable" items somewhere?
brntwood is offline
post #4 of 20 Old 07-20-2008, 05:20 PM Thread Starter
brntwood
brntwood's Profile
brntwood's Gallery Thanks for the idea - but no luck.
brntwood is offline
post #5 of 20 Old 07-20-2008, 05:37 PM Thread Starter
brntwood
OK---This is even getting more crazy - NOW the timer for the interior lights is not working. (The door lights used to stay on for 45ish seconds (after door was closed-now they go off instantly) This change happened after disconnecting (and re-connecting) the battery. I'm thinking these lights are "programmable" somehow. ????
brntwood is offline
post #6 of 20 Old 07-21-2008, 06:25 PM Thread Starter
brntwood
OK--the "timer" now seems to work again. (Must have had something to do with disconnecting the battery - ??) But the other lights still don't light. :-((
brntwood is offline
post #7 of 20 Old 07-22-2008, 07:01 PM
moparrr07
do your glove box lamp, key halo, underhood lamp and visor lamps work?
-Black Limited 1998 Jeep ZJ 5.2 nv3550 np242, 35s, lots of other stuff
moparrr07 is offline
post #8 of 20 Old 07-22-2008, 08:43 PM
elmer_fud
fuse?
i think the dome lights are on one fuse, and the doors on another
Brian
95 ZJ, 5.2 V8,160,000 miles
Colorado Jeep Club member Pi
Originally Posted by Speedycat View Post
I am not one to be changing lanes at 70 mph on a lifted truck on 33's, but since I am in Miami, I have to be prepared for the continuous influx of new drivers whose previous ride was a bicycle with wooden wheels.
Originally Posted by FPKites View Post
badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, Mushroom!!! :D
Originally Posted by ZeeJay1997 View Post
Or just tie a 12 lb fish to a one foot pipe.
elmer_fud is offline
post #9 of 20 Old 07-22-2008, 08:51 PM
nashmd454
nashmd454's Avatar
it was kind of funny letting him post and post and post...kind of like he was talking to himself...till you 2 had to chime in. I would check for shorts, relays and fuses. Also check the BCM. (body control module)
96' JGC V-8 5.2L ltd.
way too much to list.
Thought for the day:
If GOD gave HIS only son for us...can't we at least give HIM an hour of our time a day.
http://photobucket.com/albums/v639/nashmd454
http://groups.jeepforum.com/The_Dark_Side
nashmd454 is offline
post #10 of 20 Old 07-22-2008, 08:54 PM
moparrr07
the door moduals control the door lights, i want to know which lights work to decide which curcuit is bad
post #11 of 20 Old 07-24-2008, 05:38 PM Thread Starter
brntwood
Work/don't work
Sorry for the multiple posts--just trying to give all information. (Regarding talking to my self---yerp--after trying to figure this one out--I might be! The glove box and under hood lights WORK. The center dome, Under dash, Cargo and (discovered) the Halo lights do NOT work. As far as I can tell--they are all on the same circuite/fuse. (My logic is--if some of the lights on the circuit work (and some don't) it's not the fuse. (PS--I did check it--it's good. (fuse 16) THANKS for any assistance.
brntwood is offline
post #12 of 20 Old 07-24-2008, 09:50 PM
moparrr07
ok then, the cargo, under dash, halo all run through the courtesy lamp relay most other lamps dont, its located in the junksion box, second column, second one down, swap it out with another similar relay to see if its bad
post #13 of 20 Old 07-25-2008, 09:19 AM Thread Starter
brntwood
Will check it.
Thanks for the idea. (relay) I will check it this evening when get home. Will let you know. Thanks again.
brntwood is offline
post #14 of 20 Old 07-26-2008, 10:35 AM Thread Starter
brntwood
Relay is good....
Hi. I swapped the relay (from the cigar lighter) I know I had the cigar lighter relay etc. as I tried the lighter with it out. Swapped the relay (both have same number on them) Cigar lighter works with the dome relay (so relay is good)
One other thing I discovered....There is the slide dimmer switch on the dash to dim the dash lights etc. The full "up/on" position should turn on the dome lights. (correct?) It doesn't.
Is this problem by ANY chance a "programable" thing? I see many mentions in the oweners manual about "option can be programmed by your dealer" ??
Thanks again for the assistance.
brntwood is offline
post #15 of 20 Old 07-26-2008, 01:13 PM
moparrr07
check power to the relay and then power out to where it gos, if you have powers and grounds everywhere it needs a new body control module
Interior lighting problem dgoak ZJ Grand Cherokee Forum 4 03-25-2008 03:33 PM
Interior Lighting cutnaction ZJ Grand Cherokee Forum 5 05-02-2005 08:23 PM
interior dome lighting trekbuddy ZJ Grand Cherokee Forum 13 03-30-2005 07:21 PM
Interior Lighting question dylanemcgregor ZJ Grand Cherokee Forum 2 09-14-2003 09:29 AM
interior lighting?? errodri1961 ZJ Grand Cherokee Forum 1 08-21-2003 05:58 PM
