Interesting things to note, upkeeping the 94 JGC - Page 4 - JeepForum.com
post #46 of 47 Old 10-14-2007, 06:16 PM
varithms
varithms's Avatar
I installed 2 of the "fail safe" and they stuck in the open position. The little teeth caught the edge of the valve. It left the thermo open and never warmed up. It threw a code after 200 miles. Both where brand new. I have a 180 deg. With mods the 195 pinged to bad.
2004 Special ED Silver 4.0. K&N, relocated IAT sensor, resistor trick, 1.7 roller rockers, 2 ba 4, 3.73 L.S.,
255/65/16, cross drilled / slotted rotors
varithms is offline
post #47 of 47 Old 04-17-2013, 04:09 PM
tucsonzj
Originally Posted by greasefingers View Post
Mine always ran between 200 & 210, then changed the thermostat (with two different 195 F ones as I was sure the first ran too cold) and it just seems to run much cooler than expected now.[below 182.5F]
Kind of going to revive this thread a little. This is exactly what my temp gauge reads all the time. Get hot air when it's cold (10 degrees out) within 10 minutes...was a desert vehicle and still in 100 degrees outside it still ran like this. During a day of wheeling I had 1 overflow of the coolant.
His:00 TJ "Fiona" stuff/stuff/stuff
95 ZJ 3.5" w/242 swap-Sold
Hers: 15 JK Sahara-3" Teraflex
tucsonzj is offline
Can a diesel exhaust note sound like a gas exhaust note? suzieque WK Grand Cherokee & XK Commander Forum 9 04-15-2011 08:20 AM
Note: on front brake service greasefingers ZJ Grand Cherokee Forum 6 05-10-2007 10:01 PM
Note to WJ owners. AgitatedPancake ZJ Grand Cherokee Forum 14 04-29-2007 12:47 PM
A note about RE Control Arm Bushings ArloGuthroJeep ZJ Grand Cherokee Forum 9 09-15-2006 12:33 PM
High Flow Injectors + A Side Note DrumBoy ZJ Grand Cherokee Forum 14 06-01-2005 03:43 PM
