Quantcast intake plenum gasket R&R on 5.9L - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > intake plenum gasket R&R on 5.9L
Rock Krawler Suspension's for BLOW OUT prices!!!Great deals on Mickey Thompson Tires @ Jeephut.comRCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.com
Old 12-04-2007, 12:36 AM   #1
Nurburgringer
This weekend I plan on installing the Hughs Engines upgraded plenum plate, intake gaskets and new bolts to hopfully cure the pinging under heavy throttle on my 140,000 mile 5.9.
I just bought it last weekend and haven't bought service manuals yet, so was hoping somebody here could share and tips and tricks learned when doing this.
I'm pretty handy with a wrench, but there are quite a few A/C hoses, throttle cables, etc running pretty much over the intake so taking it off looks to be just a bit tricky.
Couldn't find much about this by searching the archives for "5.9 plenum", and couldn't find the TSB that apparently specifies the optimum torque order for the bolts.
Do I need any special tools that I'll only discover the need for after I've got half the motor strewn about the garage? Is it possible to remove the intake plenum without removing any A/C lines (hope so...)
thanks in advance!
Kurt
Philly
'98 5.9 ZJ
Nurburgringer is offline   Reply With Quote
Old 12-04-2007, 01:01 AM   #2
10achik
I ate what?
10achik's Avatar
Check the FAQ's at the top of the page, I think there is a write-up on doing this on a 5.2 that might help you out.
Yep, it's post #2 in the FAQ's
Ken
99 GC Limited - 4.7L HO V8, 6.5" IRO HC LA lift, F&R D44s locked & trussed, 242HD, IRO TC Skid, KMA Bumper, 33" Yokohama Mud Rovers
2006 Saturn Redline -2.0L Eaton supercharged I4, GMPP Stage 2, Custom Tune, AEM CAI, Falken 912's (13.76 @ 103.85)
2006 Pontiac G6 GTP - (her's)
2001 Dodge Ram 1500 - CAI, Soft 8's, 31's
2000 SV650 - naked, integrated tail light, sliders, corbin, pilot roads, RK chain & sprokets, D&D full exhaust, FactoryPro Stage I jet kit, +4 Ignition Advancer, Barnett race clutch
2006 Triumph America 900 - Full Dresser
January 2009 Grand Cherokee of the Month (GCOTM)
10achik is offline   Reply With Quote
Old 12-04-2007, 08:21 AM   #3
Nurburgringer
thanks Ken - that didn't come up with the search but I should have looked there. Lots of great info there... now to print of all the hints and then off to Pep Boys at lunch to get a 190F thermostat...
cheers
Kurt
Old 12-04-2007, 09:59 AM   #4
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
Yes, move the compressor over to the passenger's side of the engine.
You will need a special tool for the fuel lines. Or you will need to remove the fuel rail and injectors.
HighLonesome is offline   Reply With Quote
Old 12-04-2007, 11:00 AM   #5
Nurburgringer
thanks 5 9 - just dropped over $200 at Pep Boys for new coolant hoses, water pump, thermo, sensors (and a nice little air compressor to carry around in the 5.9 .
Of course Sears doesn't sell just a 22mm stubby the FAQ says is needed to remove the EGR valve, so splurged on a really nice Craftsman short adjustable wrench that should do the job. Also a in-lb torque wrench for $69 - might see if Pep Boys rents these casue I'll probably use this once or twice... but I can imagine rental torque wrenches probably aren't calibrated that well...
Stopped in the Jeep dealer to get the throttle body gasket. Just for S&G asked the parts guy how much they got for a NP242 transfer case. He immediately said "You can't put that in your GC.". Offered to email him photos of lots of people with 5.9s who have, but he wouldn't admit that it would work, but said it'd cost around $1500. Silly little man
Old 12-04-2007, 11:57 AM   #6
Nurburgringer
thanks for the tips!
Originally Posted by ratmonkey
you don't have an egr system in the 98...it's all computer controlled by the o2 sensors.
are you sure? Both write-ups mention the EGR tube going into the back of the plenum, like this in the FAQ:
"About wrenching on the EGR tube: This was the hardest part by far. A standard length wrench will not fit because of the firewall. I needed to run to the store and buy a stubby 22mm wrench (about 6 inches long) just to be able to get a wrench on the nut. The nut is VERY stubborn and less than 6 inches of leverage crammed into a tight space makes things very difficult."
Earlier this morning I actually looked up "EGR" because I couldn't remember what it stood for:
http://en.wikipedia.org/wiki/Exhaust_gas_recirculation
pretty sure all cars made in the last 2 or 3 decades have an EGR system
Kurt
Old 12-04-2007, 12:08 PM   #7
ratmonkey
Living dead mod
ratmonkey's Avatar
96+ jeeps do not have an egr. emissions are controlled by the computer on OBDII vehicles.
ratmonkey is offline   Reply With Quote
Old 12-04-2007, 12:14 PM   #8
Nurburgringer
alrighty then! one less thing to bust my knuckles on!
cheers
Kurt
Old 12-04-2007, 01:00 PM   #9
HighLonesome
cheers
Kurt
It's a bear too. Dealer only gasket required where the tube meets the exhaust manifold. Feel lucky.
Old 12-05-2007, 02:33 AM   #10
Colorado 5.9
I would recomend a new set of intake manifold bolts from the dealer. The old ones will be stretched & won't torqe to the right specs. You do NOT want to pop any threads on the intake. It can be done way to easy if your not carefull.
Get a good inch lbs torqe wrench & follow the torqe specs to the letter. Oh, I nent number. That includes the thumostat housing bolts.
Don't forget a new thurmostat if no one said it yet.
Also don't forget that little hose & new O-ring off the right side of the water punp along with the larger hose off the top of the w-pump to the intake manifold. Since they are right there & easy to get to replace them.
Keep track of which bolts go where. Use little bagies & lable them. Good luck!!!!
ZJ 98 5.9 LTD. Lots of mods. 7" T&T's Long Arm Lift ,BFG KM2"s,35X12.50x16's,4:56's, Vanco brake upgrade, M1intake,Holley52mmTB,MikeLeach Headers,, Arb'ed HP D30,Aussie Locked rear,Procomp MX6 Shocks,Arb front,RearTR bumpers,ECT.ECT.
Latest Pics
Colorado 5.9 is offline   Reply With Quote
Old 12-05-2007, 04:55 AM   #11
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
I'm going to tackle this when I get home.
Hunter
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
http://www.kevinsoffroad.com/
602.841.3355
For your performance needs:
kolak@kolakperformance.com
480.998.3661
Texas ZJ1 is offline   Reply With Quote
Old 12-05-2007, 08:34 AM   #12
Nurburgringer
thanks CO 5.9 - I did buy a craftsman in-lb tq wrench, and new bolts are on the way with the gasket and al. plenum plate from Hughs Engines.
I see the new water pump has a large gasket for the housing and a small rubber o-ring, this must be what you're referring to.
TXZJ - good luck, let us know how it goes!
Kurt
Old 12-09-2007, 04:21 PM   #13
Nurburgringer
Texas - I don't know how yours went, but mine was a success (but took a bit longer than I thought).
Wrote some tips and linked some pics here:
http://www.jeepforum.com/forum/f13/gc-5-9-air-sucking-problem-493177/index2.html
thanks everyone for the advice! The 5.9 breathes fire again
cheers
Kurt
Old 12-09-2007, 04:30 PM   #14
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Kurt,
I'm in Iraq, it'll be a long time before I get to it.
Hunter
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
480.998.3661
Old 08-17-2010, 02:28 PM   #15
SoWfPaW
Quick question I noticed on the stock manifold it says do not torque over 12 ft lbs. All ive heard is measurments in inch lbs Are they referring to the intake bolts?
SoWfPaW is offline   Reply With Quote
Glock Forum
