intake manifold help - JeepForum.com
post #1 of 11 Old 05-18-2005, 04:42 PM Thread Starter
tbone31
long story short, top end of my engine was taken apart and the guy screwed off, ive got everything back but i just noticed today after having the manifold cleaned that where it bolts to the exhaust manifold on of the bolt holders dont know how to explain is broken off. if i can post a picture later maybe someone can help. is there any solution to this its only half broke off will a bolt and washer still be able to hold it, being aluminum can it be welded? or what am i looking at for a new part?
White 2001 Grand Cherokee Limited, Tan Leather, Alpine Deck, 1001 bd and 851x RF amps, Diamond Audio components, 2 12inch RF Subs. 3inch Exhaust.
1993 zj laredo FOR SALE, check the for sale section for details. or email
tbone31 is offline
post #2 of 11 Old 05-18-2005, 08:06 PM
-Joe-
-Joe-'s Avatar
a picture would be really helpfull..
If you have a 4.0, theres bolts, then 2 studs that are on the very ends of the exhaust manifold. (They are screwed into the cylinder head but are removable)
You can get a new bolt/stud set for like $10 at any autoparts store..
- Joe -
'95 Jeep Grand Cherokee Laredo I6 4.0L
242TC - Extreme Engineering 2" Front Lift/1.75" Rear Lift - ES9000 Shocks + JKS BPEs
Moog Cargo Control Springs
Magnaflow Converter - Dynomax Muffler
235/75/15 AT Uniroyal Liberator Tires
-Joe- is offline
post #3 of 11 Old 05-19-2005, 08:01 AM
Brian's 97 ZJ
Brian's 97 ZJ's Avatar
tbone31,
From your description, it sounds as if part of your intake manifold has broken off where one of the bolts/washers holds it on? I'm not certain if it could be fixed or not...
but...
I have a used 1997 4.0L intake manifold that I can ship tomorrow for $20 if you are interested. Would be nice to get it out of the garage.
- Brian
For some reason, being a member of the
just isn't as cool... Member #1
Brian's 97 ZJ is offline
post #4 of 11 Old 05-19-2005, 08:30 AM Thread Starter
tbone31
brian that sounds like what i need i will post a pic for final prognosis then u guys can let me know its what u described where the aluminum has broken off will the manifold work with my 93 ?
tbone31 is offline
post #5 of 11 Old 05-19-2005, 08:46 AM
Brian's 97 ZJ
tbone31,
I'm 98% certain that it will bolt right up to your '93.
Post the pic(s) when you get a chance. You may still be able to use your current manifold as it is.
- Brian
post #6 of 11 Old 05-19-2005, 09:04 AM Thread Starter
tbone31
allright heres some pics sorry u gotta follow the link hope it works for ya.
http://www.sounddomain.com/memberpage/508203/3
know anyone with a valve cover too lol
tbone31 is offline
post #7 of 11 Old 05-19-2005, 09:20 AM
Brian's 97 ZJ
Sorry for the big picture. :(
tbone31,
The part that is broken mates up with a locator pin on the head and not a bolt/washer. Your intake is still fine to use.
Here is a shot of my '95 head. The square holes are the intake ports; numbered 1 to 6, left to right. The locator pins are between and below intake ports 1 & 2 and 5 & 6. The holes for the pins are not threaded so it is possible that the pins could be missing.
HTH
- Brian
post #8 of 11 Old 05-19-2005, 09:47 AM Thread Starter
tbone31
ohh okay so it will still bolt up fine then no problems or what? and i started another thread about putting the top end back togheter maybe u can give me some tips/ help cause all i have is the reapair book and some average mechanical skill.
tbone31 is offline
post #9 of 11 Old 05-19-2005, 10:46 AM
Brian's 97 ZJ
Yep, it will still bolt up fine but you will need the locator pins in place to make sure it is in proper position. If the pins are missing you could replace them with smooth metal rod of the same diameter. Should be able to find the rod at home improvement stores.
- Brian
post #10 of 11 Old 05-19-2005, 11:29 AM
Ds4x4
Ds4x4's Avatar
you could always look for that alumaloy? or w/e it is called, I use to see it in infomercials and they had exactly what you had except on a bracket and rebuilt it.
1996 ZJ Orvis Edition,V8 5.2L
Tow & Skid Package, FM 40,44a - 3.73, NP249
265/75/16 Destination M/T's, JKS Discos, UC; Dual Intake;Red Top;
OME Stab.; Rustys 2" BB + shocks, xtreme hi-lift, Kennesaw Rear MultiCarrier
Proud To Be A FF/EMT/Police/Military Club Member #15
Ds4x4 is offline
post #11 of 11 Old 05-20-2005, 10:09 AM
Ruffy
come and do that to my engine... i need a few rebuilds...
1993 Grand Cherokee Laredo - White - 236k Miles
4.0L I6, Monroe GCY Shocks, BFG 235/75/R15 Tires
Ruffy is offline
5.9l intake manifold alexrule123 ZJ Grand Cherokee Forum 11 02-07-2012 12:09 AM
99+ Intake Manifold LovinLifeZJ ZJ Grand Cherokee Forum 1 05-31-2008 05:18 PM
4.7L HO Intake manifold galeanaparts ZJ Grand Cherokee Forum 1 02-20-2007 12:33 PM
wj intake manifold byrdmanzoner ZJ Grand Cherokee Forum 2 12-20-2006 10:33 AM
Intake Manifold? seggerty ZJ Grand Cherokee Forum 5 03-26-2005 08:10 PM
