Installing used but good AC compressor - JeepForum.com
post #1 of 19 Old 08-14-2009, 07:24 PM Thread Starter
drespecki
1983 CJ7
My 96 ZJ with the 4.0 has bad compressor so I found a good used one (I felt it running ice cold) to swap over.. Putting on a new accumulator/drier also. Should I drain the 'new' compressor and add a new quantity of oil? Also, should I take it in first and have everything in the line vacuumed out first before I switch anything over? Any details would be greatly appreciated.. (I am going to have it professionally refilled when I have the new parts finally on..)
It only hurts while you're breathing..
drespecki is offline
post #2 of 19 Old 08-14-2009, 07:39 PM
melloyello
Just open the system and let what's in it out. Replace the drier and compressor. If you want then go ahead and replace all o-rings in the system, check your belt, etc. Then take it in to get it filled. If you have a vacuum and some gauges then do it yourself. Don't just go adding r134a to it.
melloyello is offline
post #3 of 19 Old 08-14-2009, 07:52 PM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
Umm...NO...don't do that. That's just ignorant in so many ways (not to mention illegal).
Have the system evacuated by a shop. A good shop will have an evacuation/recycling system that will print out exactly how much was evacuated, and will store that refrigerant in their tank.
Then, after your system is back together, they should credit you the amount evacuated when they recharge it.
'09 JK Rubicon
'01 XJ Sport
'10 Fusion
Kruzin is offline
post #4 of 19 Old 08-14-2009, 09:29 PM
melloyello
Ignorant you say? Some people would say climbing rocks in a SUV was ignorant too but it ain't stopping you. Let me guess, I am ruining the ozone? And illegal? It's not illegal if he happened to ACCIDENTALLY cut the hose attached to the drier.
I was just trying to save him some money by changing the parts himself.
So, you want him to go to the shop so they can evacuate the system then return home and change the compressor and drier, only to return to the shop again to charge the system? The folks at the shops around where you live must be a lot nicer than here. If you asked for this kind of service here you would get a good chuckle out of them.
I truly hope he can find a shop to do that for him. I really didn't think it would be an option though.
post #5 of 19 Old 08-14-2009, 09:36 PM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
No additional reply beyond this needed to accent this type of ignorance.
'09 JK Rubicon
'01 XJ Sport
'10 Fusion
Kruzin is offline
post #6 of 19 Old 08-14-2009, 10:20 PM
melloyello
Dude, seriously, wake up. If it leaks out through a pin hole in a hose, past an o-ring, past the seal, or if you cut the hose; what the heck is the difference? Oh no, the ozone police might come and snatch me up. I think I spilled a couple of drops of oil the last time I threw my oil filter into the woods. Lock me up.
I can't let a little refrigerant loose in the air but big companies can dump harmful pollutants into the air everyday. Gimme a break.
I bet you still have the tags on your pillows too don't you?
post #7 of 19 Old 08-14-2009, 10:33 PM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
There is a difference, and if you can't understand that, then again, I say you're ignorant. Not going to defend against intentionally releasing refrigerant into the atmosphere. I don't need to.
And with 134a costing at best ~$0.75-$1.00/oz (I charge $1.50/oz)...and a full recharge taking 48-64oz...where's the harm in doing it right? Recycle it. Save yourself a few bux while preserving the environment. Where is the wrong in this?
'09 JK Rubicon
'01 XJ Sport
'10 Fusion
Kruzin is offline
post #8 of 19 Old 08-14-2009, 10:47 PM
SaturnICL
A pinhole is different than taking a pair of sidecutters to the line to the tune of a fine of $20000.00 It is called intentional venting!
I see that if big companies jumped off a cliff you would to! (hint - hint)
It amazes me how people will try to justify committing a crime because you are saving a few bucks.
SaturnICL is offline
post #9 of 19 Old 08-14-2009, 10:54 PM
xxxflhrci
xxxflhrci's Avatar
I don't know that I would have gone the used route unless it was dirt cheap. I just bought a remanufactured compressor, drier, o-rings, and oil as a kit off eBay for my Mercedes. It was 172 bucks shipped to my door. I did not install it myself. I paid a pro to do it. The total for installing it and charging the systems was 174 bucks.
The vendor that I got my kit from sells nothing but AC compressors on eBay. He has 7k+ positive transactions.
xxxflhrci is offline
post #10 of 19 Old 08-15-2009, 05:33 AM
melloyello
I never said it was wrong to recycle it. I think you misunderstood that part. I said that I didn't know any shops around here that would evacuate then let you go home and come back at another time to recharge.
post #11 of 19 Old 08-15-2009, 09:33 PM
ZJcrawler45
WHoA! so $64 + shop fees/labor just to evacuate and refill the AC system. That's a RIP! And so is $174 to install a AC compressor. Sorry but i wouldn't pay the $100+ dollars just to have the AC system evacuated and recharged legally. Besides all that ozone stuff is BS.
Captain Nate
ZJcrawler45 is offline
post #12 of 19 Old 08-15-2009, 09:42 PM
xxxflhrci
xxxflhrci's Avatar
I thought 174 bucks was pretty darn fair for an install and charge. Due to the compressors location, you couldn't hardly do the swap without a lift. I figure it was at least a 2 hour job. I was glad to drop it off, comeback, pay the guy and know it was done correctly. I've driven about 1k with my new AC and stayed cool as a cucumber. I'm happy.
post #13 of 19 Old 08-15-2009, 09:59 PM
j.love
j.love's Avatar
1994 ZJ
you need a lift to change your ac pump??? man you must be short.
David.
94 ZJ laredo 5.9 V8 swap D44a posi
Originally Posted by ratmonkey View Post
I wouldn't drive down a driveway on that.
''If we do everything right, if we do it with absolute certainty, there's still a 30% chance we're going to get it wrong.''
Joe Biden
j.love is offline
post #14 of 19 Old 08-15-2009, 10:03 PM
xxxflhrci
xxxflhrci's Avatar
Did you bother to read that is it on a Mercedes? It is on the bottom. It bolts up from underneath the car.
post #15 of 19 Old 08-15-2009, 10:09 PM
j.love
j.love's Avatar
1994 ZJ
this is a Jeep forum.. why are you talking Mercedes?
besides, who reads the entire thread anymore... pffft!
David.
Joe Biden
j.love is offline
installing gears, good or bad idea? BradBurdett ZJ Grand Cherokee Forum 9 07-07-2011 10:30 AM
A/C compressor plubber ZJ Grand Cherokee Forum 0 11-25-2007 07:56 PM
ac compressor alivenkickin28 ZJ Grand Cherokee Forum 7 04-11-2007 09:12 AM
1994 grand cherokee good price and good base for offroading? DirtAddsHP ZJ Grand Cherokee Forum 8 01-24-2007 04:26 PM
A/C Compressor Always Trying to be ON mtnrunner ZJ Grand Cherokee Forum 3 01-07-2006 10:29 AM
