installing tow hooks - JeepForum.com
post #1 of 13 Old 09-19-2005, 07:24 PM Thread Starter
gil220zj
i got tow hooks from ebay for my 97 jeep gc but i don't how how to put them on .can anybody show me a few pic to show me how to install them
gil220zj is offline
post #2 of 13 Old 09-19-2005, 07:27 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Did you get the brackets also or just the hooks?
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #3 of 13 Old 09-19-2005, 07:35 PM Thread Starter
gil220zj
tow hook
i got the brackets and everything new in the box
gil220zj is offline
post #4 of 13 Old 09-19-2005, 08:22 PM
PlatinumZJ
Senior Moment Member
PlatinumZJ's Avatar
here is a write up ZJ Tow Hooks
HTH
Doug
When all is said and done, more is said than done.
Platinum '97 ZJ LTD, I6 (see profile) Paid for!
Links:
for ZJ & WJ stuff,
for performance stuff. I6 performance info at
Other stuff: Kevin's Roof Rack. KOR sliders, Bored 62mm TB, Blaupunkt Bermuda w/ ipod, Brembo Slotted rotors,
OME steering stabilizer, H4 headlight upgrade...
PlatinumZJ is offline
post #5 of 13 Old 09-19-2005, 08:41 PM
jeeptorino68
1992 XJ Cherokee
hmmmm the PO bolted mine onto this bolt that is kinda on each side of the radiator and drilled his own hole or somethign for the second. the hook is between some of the openins below the bumper where some stock ones are. is this safe or not? it looks stout do i need the bracket? or can i just buy the bracket, cuz these are the standard hoows with the two holes so ya
Thanks
jeeptorino68 is offline
post #6 of 13 Old 09-19-2005, 08:59 PM
goodolboy71
Thanks
wtf did you just say?
if he didnt make brackets or use brackets designed like Rustys or Jeeps OEM then i am willing to bet he just bolted them to the tin can frame rail....which is not safe and can cause death or serious injurys...dont skimp on the recovery gear
93 ZJ, 4.0, np242, 4 in F>R , 33's, Arb Bumper, Warn XD 9000, Home depot Rack, lightfoce 170's and some blingy shny 5 star rims,8.8 lsd, d30 /ox locker, JCR Rock Rails
74 CJ5- total restoration from ground up, 3 spd, 304 V8, 32's
goodolboy71 is offline
post #7 of 13 Old 09-19-2005, 09:36 PM Thread Starter
gil220zj
Installing Factory Tow Hooks
it is a Factory Tow Hooks kit for a 97 gc
gil220zj is offline
post #8 of 13 Old 09-19-2005, 09:44 PM
jeeptorino68
1992 XJ Cherokee
ya he did just bolt them on no brackets. can i make a bracket or backing plate or what not? or is it just best to buy one
post #9 of 13 Old 09-19-2005, 09:57 PM
PumaZJ
youd wanna buy the brackets. i tried making some once and it was a super PITA! If you don't get those holes JUST right it won't come close to fitting. 1/4" plate doesn't bend much if you know what i mean.
1998 ZJ - 36's & bent unibody - RIP
2004 WJ - Expedition build
2011 A4 - DD
PumaZJ is offline
post #10 of 13 Old 09-20-2005, 12:39 AM
jeeptorino68
1992 XJ Cherokee
who the best deal on them? anyone have a set maybe that they want to sell, or maybe i will check out the junck yards for some
post #11 of 13 Old 09-20-2005, 12:55 AM
goodolboy71
rustys was running a sell on them the other wk www.rustysoffroad.com
post #12 of 13 Old 09-20-2005, 10:07 AM
jeeptorino68
1992 XJ Cherokee
thanks that is the bestdeal i have found so far. i will probably get those ones i have read some good things about them on other posts
post #13 of 13 Old 09-20-2005, 10:11 AM
gregmondro
gregmondro's Avatar
bet it wasn't from the XJ guys whose stuff has fallen off huh? :P
just kidding, if you need a pic of how they're mounted and can't find one on the internet, I might be heading back to the junkyards this weekend. There was a ZJ there with the front ripped off where you could see the tow hooks + brackets pretty clear.
But with the internet directions you should be set to go
- NP231, SYE, 4.56's, Rear D44 w/ Detroit SoftLocker and a RockCrusher Diff Cover, 35x12.5 BFG A/Ts, RE 5.5" XD Lift, Skidrow TC Skid, ORT Rear Bumper + Carrier, Rigidco Front Winch Bumper + Steering Box Plate, Milemarker 8000 Winch, Rock Sliders, HD Currie Steering, Control Arm Skids, Goferit Tie Rod Flip Insert, Optima Red Top and a few other goodies...
gregmondro is offline
Installing front tow hooks on WJ chezmoose ZJ Grand Cherokee Forum 10 11-24-2007 07:08 PM
Installing Tow Hooks and trailer hitch? Nonni WK Grand Cherokee & XK Commander Forum 6 11-11-2007 07:55 PM
Installing Toe Hooks countertop ZJ Grand Cherokee Forum 12 06-21-2005 08:47 PM
tow hooks grandman97 ZJ Grand Cherokee Forum 15 01-26-2005 05:25 PM
