Quantcast Installing my BB tomorrow... - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Installing my BB tomorrow...
Old 05-01-2007, 12:02 AM   #1
Casper4x4
And because i do not know what i am doing i am waking up early to start it and hopfully end mid afternoon. Whats probably the hardest part in the whole install? Something i should look out for, what not to do etc...
Alonzo "Casper" Gonzalez
1993 Jeep Grand Cherokee Laredo
4.0L Engine w/ 231 TC
IRO 4.5" Lift on Kumho 31" MT
IRO frnt adj. track bar w/ mount
Bilstein 5150 shocks
JKS Quick Disconnects
JCR 1 Ton steering
Addco Front Sway bar
Flowmaster muffler
K&N air filter
2 Pro Comp 2 KC lights on KOR light bar
Coleman roof rack
Coming Soon! Gears and locker!
Casper4x4 is offline   Reply With Quote
Old 05-01-2007, 12:24 AM   #2
QuadraTokn
1930 WJ
hardest part prolly disconnecting the sway bar...?
I have a modified 1999 WJ and a stock 2001 WJ
Tread Lightly
Pictures
PARTED OUT 8 WJ Grand Cherokees ! ! ! ! ! !
QuadraTokn is offline   Reply With Quote
Old 05-01-2007, 01:27 AM   #3
ericheineman01
1994 ZJ
Location: Kent, Washington -- 20 miles south of Seattle
I say rusty and stuck bolts are the worst. Make sure to have some lube or pb blaster... Good luck!!!
[SIZE=3][B][COLOR=DarkGreen] [URL="http://ericsjeep.googlepages.com/"]--Green 94' ZJ-- [/URL][/COLOR][/B][/SIZE]
[SIZE=2][B][/B][/SIZE]
5.2 V8, 249 :( , K&N FIPK Gen II Intake, Flowmaster 40 Series,
(2) 80w Walmart Fogs, (4) 100w roof lights, (2) 50w rock lights, Upgraded back up lights,
3" Teraflex Lift, OME SS, 265/75/15 Toyo Open Country A/Ts, Taurus E-Fan conversion, 150A ND Alternator, Kevin's Radiator Support/Tow Points, T-Case Skid Plate
[url]http://ericsjeep.googlepages.com/[/url] (not quite ready yet...) and [URL="http://www.cardomain.com/ride/2155760"]http://www.cardomain.com/ride/2155760[/URL]
ericheineman01 is offline   Reply With Quote
Old 05-01-2007, 01:28 AM   #4
Casper4x4
Any pointers anyone would like to give?
JCR 1 Ton steering
Flowmaster muffler
K&N air filter
Coleman roof rack
Old 05-01-2007, 04:14 AM   #5
TravisL1213
mine took 3hrs and 42mins.
Its playschool. the hardest thing will be figuring how to work the spring compressor.
by the way i had no experience when going in to mine and was easy as pie
Limited WJ on 31's
TravisL1213 is offline   Reply With Quote
Old 05-01-2007, 08:03 AM   #6
NewAlbanyWJ
2007 XK Commander
I just put a BB on my WJ this weekend. One thing that will save you lots of time is letting the jack do the work for you. Disconnect the sway bars and jack the axle up as high as you can. Put the spring compressor on the coil springs, tighten it, and drop the axle down. The springs will slide right out. This saved us a lot of time. Hope this helps.
NewAlbanyWJ is offline   Reply With Quote
Old 05-01-2007, 09:04 AM   #7
Chrisca
Don't even need one.
Put the Jeep on jackstands under the frame.
Disconnect the sway bar and jack up the oppopsite side of the axle.
The spring will pop right out.
If you really need to use the spring compressor, jack up the axle to compress the spring, then put on the compressor.
Let the axle down and the spring will fall out out.
2004 Grand Cherokee Laredo
Chrisca is offline   Reply With Quote
Glock Forum
