installing a gear 42RE instead of 46RH on a ZJ 1995 V8 - 5.2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > installing a gear 42RE instead of 46RH on a ZJ 1995 V8 - 5.2
SPARTAN LOCKERS are on sale BIG TIME at ROCKRIDGE 4WD!FLASH SALE! Open thread to reveil the Newest Sale @ ROCKRIIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread Yesterday, 09:15 AM   #1
aeksnake
Hi Dears,
Having some complications with my gearbox 46RH on my Grand Cherokee ZJ V8 - 5.2 1995
Would like to know if I can install a 42RE gearbox and if it will work great with my engine.
And what will be the different issues
Thanks in advance for your help.
Algerian Jeeper
aeksnake is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 09:40 AM   #2
Oldfrog
Welcome to JF.
To my knowledge, the 42re is for the 4.0 only.
Others will chime in, if I'm wrong.
Cajun Recipes and Fishing tips
On my seventh PCM. Might have finally gotten a good one this time. Crossing my fingers.
Stalling? Work through Zeejay's list
Oldfrog is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 09:40 AM   #3
PolkaPower
Nope. Different bolt pattern and electronics. Rebuild or another 46RH is the only way to go. It wouldn't hold up behind the 5.2 anyway. Your 5.2 is OBDI electronics and 96+ ZJ's were OBDII.
Even if you found a 44RE that would bolt up you would still lack the electronics. The 46RH is hydraulically controlled and the 42/44RE are electric.
PolkaPower is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 09:55 AM   #4
aeksnake
Thanks PolkaPower
You confirmed my concern regarding the electronic
42RE will bolt up with my engine but the electroic side will be impossible.
Unread Yesterday, 10:18 AM   #5
PolkaPower
It will not bolt up either. The bolt pattern is different.
