installing catalytic convertor backwards - JeepForum.com
post #1 of 10 Old 10-21-2016, 06:12 PM Thread Starter
brad88yj
My cat was rusted had holes and after removing found the honeycone inside is broken and chunks are rattling around inside it. I was able to find a person parting out same make etc jeep and they sold it to me. Problem is the cut it really short. The best way i can see to weld it in is to put it with the 02 facing the front of the car rather then where it originally was in rear. Will this cause any issues to put in this way?
brad88yj is offline
post #2 of 10 Old 10-21-2016, 08:52 PM
ZeeJay1997
Dont put another cat on it until you figure out what's causing the misfires. Rich exhaust kills cats.
ZeeJay1997 is offline
post #3 of 10 Old 10-22-2016, 05:16 AM Thread Starter
brad88yj
without the cat on it doesn't want to idle.
brad88yj is offline
post #4 of 10 Old 10-22-2016, 06:29 AM
Timo_90xj
Timo_90xj's Avatar
Not having a cat installed should have absolutely zero effect on your Jeep idling, issue is somewhere else.
As for the cat being backwards you will most likely get a CEL, because the after-cat (downstream) O2 sensor is sniffing if the cat converter is working. With the sniffer O2 sensor before the cat, PCM thinks cat is broken and will light up the CEL for high emissions.
It won't affect how your engine runs, because only the upstream O2 sensor is coupled to the air/ fuel ratio tuning.
***Under construction***
Timo_90xj is offline
post #5 of 10 Old 10-22-2016, 08:47 AM Thread Starter
brad88yj
The reason why I'm asking is as shown in another of my threads I am having issues misfiring when it rains. I knew cat was bad so I cut it out put the new used one in started it up and it ran awful for a minute then back fired thru the top of motor and now won't run unless I pour gas directly into throttle body?
brad88yj is offline
post #6 of 10 Old 10-22-2016, 09:13 AM
Timo_90xj
Timo_90xj's Avatar
Do you have the upstream o2- sensor connected, is it in good condition, and are the o2- sensor wires good?
Your issue has nothing to do with the cat (unless is it's almost fully clogged), this is a sensor/ fuel/ spark/ timing issue.
post #7 of 10 Old 10-22-2016, 03:00 PM Thread Starter
brad88yj
All wires and sensors are good. I think it may be the intake manifold gasket. Maybe its sucking air at the rear and causing the misfires?
brad88yj is offline
post #8 of 10 Old 10-23-2016, 05:00 AM
ZeeJay1997
Not gonna happen. Can't get there from here.
post #9 of 10 Old 10-23-2016, 05:10 AM
Timo_90xj
Timo_90xj's Avatar
If you had an intake manifold gasket eak, you'd be listening to plenty of whizzing sounds from the engine. No, I really don't think that is the reason. Intake manifold gasket leak on the Magnum V8s often also causes coolant to mix with engine oil, and/or engine to suck in coolant.
post #10 of 10 Old 10-27-2016, 04:39 PM Thread Starter
brad88yj
Well I've started pulling off intake just in case because whenever it would rain and started backfiring if I gave it a lot of gas to keep going my heat would switch to defrost as if I had a vacuum leak, I would also smell coolant whenever this backfire scenario would occur and gas mileage would drop bad! I'm doing all I can think. If any other ideas suggestions are appreciated!
brad88yj is offline
