Installed My Header, WJ Intake and "703" Injectors... - JeepForum.com
post #1 of 79 Old 07-22-2012, 12:55 AM Thread Starter
torchd
2003 WJ
But now my cruise control for some odd reason will not work. I put it all back together the same way that the TB cables came off.
And now I found out that only my air will blow out the defrost only.
But now that I did my intake, header and injectors, the Jeep feels totally different. Idle is soooo much smoother, I can now accelerate on the hwy with out having to down shift. Off the line the Jeep is a lot peppier. The Jeep really feels good right at the 2K RPM mark.
Now I cannot wait to re-do my entire exhaust. Gonna be 2.5" from the header collector all the way out back.. Going with a MagnaFlow metallic spun cat, as for a muffler still havent figured one out just yet.
1998 Jeep Grand Cherokee Laredo
2" BB Pucks | SkyJacker Hydro Shocks | Rubicon Wheels | Cooper 245/75/16 Tires
2002 Trans Am
Cam, Full Exhaust, Stock Heads, Stock LS6 Intake and Stock 10 bolt with 3.42s
420 RWHP and 382 RWHTQ
torchd is offline
post #2 of 79 Old 07-22-2012, 08:48 AM
stormer1092
2005 WK
check your vaccum lines for the cruise control problem.
stormer1092 is offline
post #3 of 79 Old 07-22-2012, 09:02 AM Thread Starter
torchd
2003 WJ
Yeah I checked all the vacuum lines yesterday, everything looks in tact. Which vacuum lines does the cruise control use?
2002 Trans Am
torchd is offline
post #4 of 79 Old 07-22-2012, 09:04 AM
ZeeJay1997
Do your blower vents work okay?
ZeeJay1997 is offline
post #5 of 79 Old 07-22-2012, 09:10 AM Thread Starter
torchd
2003 WJ
You know what, haven't tried them. Let me go outside and check. BRB....
No they don't work. Everyhting is going out through the top like it is on defrost.. Great, now what?
2002 Trans Am
torchd is offline
post #6 of 79 Old 07-22-2012, 09:33 AM
kachink
Everything blowing out the defrost is the classic symptom of a vacuum leak.
kachink is offline
post #7 of 79 Old 07-22-2012, 09:40 AM
stormer1092
2005 WK
x2
post #8 of 79 Old 07-22-2012, 09:49 AM Thread Starter
torchd
2003 WJ
But where? All my lines look to be in good shape.. I will go and take some pics
2002 Trans Am
torchd is offline
post #9 of 79 Old 07-22-2012, 09:54 AM
SKorch630
Tennis ball check. I've got a write up for it around here somewhere. Perfect little tool for a vacuum leak
SKorch630 is offline
post #10 of 79 Old 07-22-2012, 09:58 AM Thread Starter
torchd
2003 WJ
First Pic - Vacuum line for cruise control
Second Pic - Vacuum line for HVAC
Third Pic - Same vaccum line for HVAC where I had to re-locate it on the side of the intake
2002 Trans Am
torchd is offline
post #11 of 79 Old 07-22-2012, 10:58 AM
ZeeJay1997
Is the check valve installed backwards?... by the brake booster?
post #12 of 79 Old 07-22-2012, 11:03 AM Thread Starter
torchd
2003 WJ
I'm not sure.. I can take it off and re-install it the other way.. I did have it off completely do lengthen it..
On a side note..
Well I took my battery and battery try out, traced the vaccum line that goes to the black vacuum box and everything was fine there.
I connected everything back up, grabbed my break cleaner and started spraying the vacuum lines with no changes in the idle of the motor.
Where is my vaccum leak? Maybe an intake leak? My jeep idles perfectly though so I am confused
2002 Trans Am
torchd is offline
post #13 of 79 Old 07-22-2012, 11:07 AM
ZeeJay1997
If the check valve is backwards, the vacuum is blocked.
post #14 of 79 Old 07-22-2012, 11:09 AM Thread Starter
torchd
2003 WJ
I flipped the check valve around and nothing changed. I left it after I flipped it..
2002 Trans Am
torchd is offline
post #15 of 79 Old 07-22-2012, 11:13 AM
ZeeJay1997
Why is the vac line running behind the behind at the heater hose on the firewall. it looks mashed. nevermind, thats a piece of foam or rubber
H.O. intake manifold and cams on "stock" 4.7 NuTone ZJ Grand Cherokee Forum 2 04-23-2014 09:58 PM
Home made "cold air intake" JeepFreak1982 ZJ Grand Cherokee Forum 17 06-27-2011 11:25 PM
ROCKY ROAD 2.25 "LIFT" iNSTALLED!!! coyote runner WK Grand Cherokee & XK Commander Forum 18 11-11-2009 09:10 PM
96 Header Panel where can i find "Levelilng device" easternkidd ZJ Grand Cherokee Forum 17 09-03-2008 08:31 PM
3" BB kit installed with 31" tires. some questions about springs and alignment! slagehammer ZJ Grand Cherokee Forum 17 04-26-2008 04:37 AM
