Installed Grease Fittings - JeepForum.com
post #1 of 4 Old 06-20-2008, 09:24 AM Thread Starter
pigoo
Not sure how many other folks have done this, but I just finished installing grease fittings in my 99 WJ.
Did both joints on the drag link, and both tie rod ends on the tie rod.
The only joints on the my Jeeps front end that now don't have grease fittings, are the lower ball joints on the steering knuckles. Will give these a try next time I have the axle assemblies out.
Anybody install grease fitting in the lower ball joints on the steering knuckles? Looks like clearance would be tight due to the proximity of the ABS speed ring, even using a 45 or 90 degree grease fitting.
- Nick
pigoo is offline
post #2 of 4 Old 06-20-2008, 09:29 AM
LaCeS OuT
LaCeS OuT's Avatar
1994 ZJ
On my ZJ the lower Moog ball joints came with 90* fittings.
Jeep Sold! 02/2009
Need AMSOIL?
LaCeS OuT is offline
post #3 of 4 Old 06-20-2008, 10:51 AM Thread Starter
pigoo
Yeah I noticed that new parts from the local parts store (ball joints/tie rod ends) seem to come with grease fittings. Unfortunately...the OEM stuff doesn't/didn't.
Does your ZJ have ABS. The clearance for the lower steering knuckle ball joint on a 99 WJ is very tight due to the ABS speed wheel....even for a 90 degree grease fitting.
- Nick
pigoo is offline
post #4 of 4 Old 06-20-2008, 11:11 AM
LaCeS OuT
LaCeS OuT's Avatar
1994 ZJ
Yes it has ABS
Jeep Sold! 02/2009
Need AMSOIL?
WJ grease fittings JGriff99xj ZJ Grand Cherokee Forum 1 07-21-2009 11:53 AM
WJ Grease Fittings - Confirmation 00JGC00 ZJ Grand Cherokee Forum 6 07-08-2009 10:17 PM
Grease fittings? Smyrna4x4 ZJ Grand Cherokee Forum 3 06-04-2007 03:11 PM
Lube chassis, etc. How many grease fittings? blacklimited ZJ Grand Cherokee Forum 1 02-14-2005 07:11 AM
grease fittings fitzz47 WJ Grand Cherokee Forum 1 07-21-2003 01:31 PM
